TLV320AIC3256 : if the inside miniDSP Codec could be used to eliminate the AEC of echo ?
Hi, Andrew,
The miniDSP of our audio codecs does not have enough processing resources to perform an effective AEC application. The codec can be used in the system for audio capture and playback, but the AEC algorithm should run on an external DSP.
-Diego Meléndez López
Audio Applications Engineer
