Hi team,
Is TAS2110 internal tone generator able to generate longer tone than default duration?
Itoh
Hi team,
Itoh
Hi Kazuki-san,
The internal tone generator is not set to a specific duration. The tone is enabled and disabled by either TG1_EN register or a selected digital pin.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Ivan-san,
Can TG1_EN controlled by PPC3?
I found TG1_EN on PPC3 register map. I just want to make sure it can enable/disable the tone on EVM.
Itoh
Hi Itoh-san,
Yes, this control is available at the Device Control panel of TAS2110 app. You can use the advanced mode for more configuration options as below:
-Ivan Salazar
Hi Ivan-san,
I cannot see the image.
Could you please attach the image again?
Itoh
