Other Parts Discussed in Thread: PCM5102A, PCM1794A
hi,
i am looking for functioning pcm5142 hardwired mode dac configuration circuit. i can not find it anywhere.
What do you mean? Each pin has an SPI, I2C, and hardwired function. If you connect the MODE pins correctly, you can then set each pin.
If you are exclusively working in HW mode, then you could also consider using the PCM5102A.
Paul
hi,
thank you for your reply
i have not used dac chips before . pcm1794a has clear circuit with hardwired jumper setting explanations in website
http://electronics-diy.com/schematics/831/en_pcm1794a.html
i am looking for this kind of documentation for pcm5142pwr
The power supply and analog pins can be configured as they are shown in the PCM5142EVM schematic. That is static for all configuration. The digital IO pins depend on the requirements of the system, for example, if you are attenuating the output, using de-emphasis, and selecting the correct I2S interface format.
https://www.ti.com/tool/PCM5142EVM-U
Paul
