Other Parts Discussed in Thread: CDCLVD1208
Please advise on how a 3.3V clock input can be fed to the device.
[Part in Question: CDCLVP1204]
A 3.3V clock input can be fed if your VCC is 3.3V.
Jennifer
Hello Jennifer,
The device power supply is 2.5V and Pg 12 of the datasheet of CDCLVD1208/04 says the following:
Figure 15 illustrates how to couple a 2.5-V LVCMOS clock input to the CDCLVD1208 directly. The series resistance, RS, must be placed close to the LVCMOS driver if required. 3.3-V LVCMOS clock input swing must be limited to VIH ≤ VCC.
May I ask you to please help us clear the doubt.
[Part in question: CDCLVD1208]
Hi SM,
Using a 3.3V LVCMOS clock input would require the signal to be attenuated by a resistor divider to meet datasheet specifications.
See this e2e post for further explanation on how to add a 3.3V LVCMOS.
Jennifer
Hi SM,
That circuit should work. You can test your design with our IBIS model under Design Tools & Simulation.
Also, please keep threads to one topic/part for clarity. For future questions, make another e2e post.
Jennifer
