Part Number: BQ4802Y
Hi team,
I am using BQ4802Y in my design. i had connected CEIN with VCC.
Datasheet describe this pin as a chip enable input.
I have a doute that if it is a chip enable than it should be logic high in both mode (Powered by VCC & Battery backup), but as per power sequence when VCC is absent, CEIN pin voltage does not effect.
Also, in the power sequence as per my understanding CSIN goes high after VCC reach its max level. but what will happen if both pins are connected togater.
