LMX2595EVM: LMX2595 certain output frequencies close in spurs
Part Number:
Hi TI Experts,
I’m currently using TICS Pro to control the LMX2595 and am facing a problem which I hope you can help me with:
Problem:
At certain output frequencies especially when a fraction is used, close in spurs were seen with their severity depending on the order of modulator selected.
Do you have any suggestions to remove close in spurs within 10MHz offset from the carrier?
Example:
At 7500.2MHz VCO output
1st order modulator
Spectrum and Phase Noise
2nd order modulator
3rd order modulator
*Remark:
-1st and 3rd Order Modulators give very bad phase noise.
-While the 2nd order modulator gives better performance, close in spurs are still present
- This issue does not occur at 7500MHz or whole number frequencies where fractions are not used
At 7500MHz via VCO
1st Order Modulator
2nd Order Modulator
3rd Order Modulator
Phase noise measurement
Br,
Teach Me
  • Data.docx
    Insert File
    Part Number: LMX2595EVM
    Hi TI Experts,
    Problem:
    Example:
    1st order modulator
    2nd order modulator
    3rd order modulator
    *Remark:
    At 7500MHz via VCO
    1st Order Modulator
    2nd Order Modulator
    3rd Order Modulator
    Br,
    Teach Me
  • Dear Teach me,
    All pictures you have placed in your question are not visible. We can answer your question but it would be helpful if you could upload the pictures.
    Regards, Simon.
  • Teach me,
    The pictures would be helpful, but some other things you can do:
    1. Be sure to check out our PLLatinum Sim software at www.ti.com/.../PLLATINUMSIM-SW
    2. You can check out our online PLL book that discusses PLLs and fractional sprus in depth at www.ti.com/.../PLL_Book
    In regards to the LMX2594 EVM, this has a very wide loop bandwidth for optimal Jitter/EVM for integer channels. As the bandwidth is wider the offset of your fractional spurs, you will likely see some spurs. So some things to consider are:
    1. Lower the loop bandwidth for better spur attenuation
    2. Use the tools above for better idea of how spurs behave.
    3. If you are using 200 MHz phase detector frequency, maybe the reason for the higher spurs is the N divider is lower. This might be why 2nd order is better. Also, be sure that you set PFD_DLY_SEL correctly in TICSPRO. Boxes will turn orange to alert you; if you ignore these warnings, it could hurt spur perform,ance.
    4. If using your own reference, higher frequency and higher slew rate is better for spurs.
    Dean
