Part Number: LMX2492EVM
Other Parts Discussed in Thread: PLLATINUMSIM-SW
Hi all!
I'm using a DDS to generate a 50 MHz sine wave that I provide to my LMX2492EVM OSCin. I use the internal doubler to get the signal up to the required 100 MHz phase detector frequency.
This has worked well up until now, however another part of my project would be significantly improved if I generated a 51.282 MHz sine wave instead, leading to a 102.564 MHz phase detector frequency.
Is this tolerable and what are the ramifications in terms of performance? I appreciate that there are passive filters on the evaluation board that will only work within a particular band.
Thanks for the help!
