Other Parts Discussed in Thread: LMX2492
Hi TI team,
I would like to know the maximum and minimum power that can be fed differentially into the Fin and Fin* terminals. In the datasheet, for a single ended operation it is mentioned to be between -5dBm to 5dBm.
In my system, the VCO divider output has a differential power between -9dBm and 0dBm at 200Ohm output impedance. Would it be possible to feed such a signal into Fin and Fin* pins of LMX2492. If not, do you recommend some suggestions here?
BR
Nikhil
