Hello team
I am having trouble getting my LMK03328 to put out the clocks on its outputs. I am able to program the device from the default mode and obtain the desired outputs after the first programming of the registers, but after I committed these same registers to EEPROM, the outputs no longer appear and I am unable to get the outputs to enable again. In other words, I cannot even get a new register write to output the clocks even though those same register writes successfully worked before. I can see that the EEPROM programming is successful by checking the programming counter register. Does anyone have any idea where to start debugging this?
Kind regards,
Stuart Smith
