Part Number: DAC3162
Other Parts Discussed in Thread: , THS3217, OPA694
Dear community,
I'm designing a board and i wanted to use the DAC3162 to generate a single ended output between 0V and 1V to feed into a 50Ohm load. I have never worked with DAC so I'm not sure on how to achieve this correctly.
I'm taking the DAC3162 datasheet and DAC3162EVM schematics as reference. I get that I need to use a 4:1 transformer to achieve a 1Vpp but I have doubts on how to change the CM level.
Just connecting the central tap of the secondary to a 0.5V reference do the trick? Is there an already working solution to this problem?
Thank you for any help,
Ian
