Hi everyone, We are experiencing some troubles with production project. In first PCB we have not troubles, now we change some distances in analog interface to meet IEC requirements.
If we turn on the lead-off pull-up resistors (only pull-up) we have noise in this channel, but if we turn on the current source intead the pull-up resistor we have not noise in the correspondent channel.
The noise is in a irregular time interval, but the amplitude it seems be the same every time. If we made a diff between consecutive points the difference in noise points is the same, then we think in a digital error. It looks like the correspondant voltage point is move in a fixed voltage.
We think the PCB is not the main problem, perhaps we are using a silicon with a know trouble?
Dou you have any information about similar problems?
Dou you experiment some like this?
While we are experimenting with the PCB, if we have some new we will tell you.
Martin
