Hi team,
I am not familiar with high-speed data conversion devices, could you help answer the following customer questions?
The NCO mode of the DAC38J84, can the phase between A and B outputs be adjusted? How can we adjust this? Could you please explain in detail?
Amy
Hi Amy,
We've received your question and will get back to you as soon as possible. Due to the holiday season, please allow for a delay in response.
Aman
Hi Kang,
Thank you for your reply.
The customer has another question that requires your assistance, could you please give your comments:
I'm using NCO output now, and then I still want to get a negative frequency? How does this need come true? Is this achieved by adjusting the phase between A and B?
Amy
Hi Amy,
If the user is using the DAC38J84 along with a RF modulator (i.e. TRF3705), then the NCO can be programmed as a "negative frequency" with I/Q phase in -180 degree fashion. The user can then see the output of the RF modulator with the signal on the "left side" or negative side of the Local Oscillator of the RF modulator.
-Kang
