Other Parts Discussed in Thread: AFE20408, AMC7908
We are evaluating AFE20408 as PA bias and would like to know what is the expected voltage ripple on the DAC output.
Thanks!
Yang
Thanks!
Yang
Hi Yang Fan,
The DAC output noise is around 70µVpp, and an output noise density of 700 nV/sqrt(Hz). Let me know if you have any other questions.
Erin
Hi Yang Fan,
What voltage supplies are you using for the inputs? The DACs have around 60db of rejection to input noise, but if your inputs are particularly noisy the DACs will reflect this.
Erin
Hi Yang Fan,
The AFE20408 is an expanded industrial range device that can operate from -55C to 150C. In addition, it has a "power good" pin called PAON.
The AMC7908 is rated for -40 to 150C and does not have this PAON pin.
Erin
Hi Yang Fan,
You can request access to view the AMC7908 datasheet and other information using this link:
ti.com/secureresources/AMC7908-DESIGN
Erin
