Hello E2E Support,
I am attempting to collect data from an analog sensor with the ADS1256 through the attached PCB schematic (see attached datasheet for analog sensor specifications). I am performing a static Allan Variance analysis on the sensor data to see if my analog to digital conversion is sufficient to provide the same specifications as stated on the datasheet. Unfortunately the ADev plots do not seem to line up with what I would expect based on the sensor's datasheet. Is it possible that I need to improve the analog interface to the ADS1256 based on the PCB schematic and sensor recommendations?
Here are the connections between the sensor to the ADS1256 PCB:
