Other Parts Discussed in Thread: DLPA200,
The datasheet does not specify thermal pin dimension and recommended stencil. Our PCB manufacturer said 10x10mm thermal pad with 60% stencil coverage is too big for the thermal pin it will cause arc solder joint issue. Can you please provide an updated package drawing with thermal pin dimension, pad and stencil recommendation?
