Other Parts Discussed in Thread: DLPA2005, DLPC3478
Dear Member
[Intraoral scanner : Fixed patter set, Single scan mode]
we generated firmware in TI's External Pattern Mode and then created firmware in the FPGA to match it for control.
If we needed to change the pattern scanning speed, we had to regenerate and download the TI External Pattern Mode firmware and the FPGA firmware.
[Industrial scanner : Multi-scan mode using various pattern sets]
How can I operate the system without downloading each time to investigate various pattern sets? External Pattern Mode doesn't seem suitable because it can't set up multiple pattern sets. Is that correct?
After downloading a single firmware, what firmware should I use or where can I obtain it to operate in multi-scan mode?
The External Pattern Streaming Mode you mentioned—does it require downloading the External Pattern Mode firmware to the flash every time to support different scan modes?
Or is there a specific firmware that needs to be downloaded?
Please explain in detail the operational scenario to support various scan modes for different pattern sets.
