this is what I call
url: https://transact.ti.com/v2/store/products/UCC27512DRSR?currency=USD&exclude-evms=true
Reuslt is :
"fault": {
"faultstring": "Invalid API call as no apiproduct match found",
"detail": {
"errorcode": "keymanagement.service.InvalidAPICallAsNoApiProductMatchFound"
It look like I don't have promession to access it. but my request all approved (below)
Can you help me solve this problem, thanks
Kiki:
Thanks for reaching out to API support.
Let me look into this issue and get back to you in next few hours.
~Samip
Kiki:
I just tried using your key/secret and its working for me. So I am going to assume, that when you tried to make the call your API access was not yet enabled. I So please give it a try and see if that works.
Side note... Bearer token route works but you could also try out "OAuth2"... as outlined below... which would help you to avoid taking the generated token and putting it under "bearer token".
Hope this helps.
~Samip
