Other Parts Discussed in Thread: ONET4201LD, ONET4201PA,
I am using a DP83869HM with a ONET4201LD (for emitting) and a ONET4201PA (receiving) to send data with fiber. I have some questions :
- Should I place some termination resistance (100ohm or pull up) or all is included in the IC ?
- Is the ONET4201LD usable with frequency below 1Ghz ? (to do some test at 10Mbps)
- Which configuration should I use with the DP83869HM ? SGMII to copper mode, or Fiber mode ? (1000Base-T to 1000Base-X)
Thank you !
