Part Number: PCA9546A
Dear Sirs:
There is one question about I2C mux application, would like to clarify that, on our product, applied for 2 cases situation, as below show situation1 & situation2.
For situation1, discovered symptom when try enable all channels “ON” to PCA9544 devices in the same time, if n counts >=4, try to scan this bus will appear BMC hang or some of devices missed.
For situation2, also try enable all channels “ON” in the same time, in this moment, BMC will hang.
Above 2 situations, if channel counts less, seems won't appear hang symptom!
So, question for I2C mux application, multiple devices cascade or parallel connection topology, enable all channels “ON” in the same time then do access is this appropriated/suggested usage? We guess that seems channel counts or capacitive effect limitation, but not sure!
We access mux each channel by sequentially, seems didn't any problems but enable channels "ON" in the same time then access, will appear hang problems, either cascade or parallel situations, are there any limited when I2C mux usage?
Sam.T
