Part Number: DP83869HM
Other Parts Discussed in Thread: DP83869
We are using 8 DP83869HM PHY's in our board in SGMII to Copper mode hardware strapped and the PHY's are connected to the VSC7464 microchip ethernet switch. For that switch it doesn't support linux driver available for the DP83869. We have to write new driver w.r.t the mesa software which will support the vsc switch.
I have written the PHY driver file by reffering the other VSC PHY's, after that we are able to read and write the PHY register (0-31 main registers and extended registers). Using this we are able get the Link when respective port is connected(both by LED indication and PHY register 01 read). But the data transmission is not happening between the PHY and the MAC.
I have tried the Loopback tests. I can able to verify that Far end loopback is successfull. In near end loopback I have tried analog loopback and I am not able to verify properly. I will attach the PHY driver file that I have written and the File that I have reffered in this query. Can you help us to debug weather we have missed any register configuration or do we need to add extra delay's at any point?
// Copyright (c) 2004-2020 Microchip Technology Inc. and its subsidiaries.
// SPDX-License-Identifier: MIT
#include <microchip/ethernet/phy/api.h>
#include <mepa_driver.h>
#include <mepa_ts_driver.h>
#include <stdio.h>
#include "dp83869_registers.h"
#include "dp83869_private.h"
//extern mepa_ts_driver_t indy_ts_drivers;
static mepa_rc ti_conf_set(mepa_device_t *dev, const mepa_conf_t *config);
static mepa_rc ti_sgmii_aneg(mepa_device_t *dev, mepa_bool_t ena);
static mepa_rc ti_event_enable_set(mepa_device_t *dev, mepa_event_t event, mepa_bool_t enable);
mepa_rc ti_direct_reg_rd(mepa_device_t *dev, uint16_t addr, uint16_t *value)
phy_data_t *data = (phy_data_t *)dev->data;
mepa_port_no_t iport = data->port_no;
switch(iport)
case 0:
(void)mesa_gpio_write(NULL, 0, 24, 1);
(void)mesa_gpio_write(NULL, 0, 25, 0);
(void)mesa_gpio_write(NULL, 0, 26, 0);
(void)mesa_gpio_write(NULL, 0, 27, 0);
break;
case 1:
(void)mesa_gpio_write(NULL, 0, 26, 1);
break;
case 2:
(void)mesa_gpio_write(NULL, 0, 27, 1);
break;
case 3:
break;
case 4:
(void)mesa_gpio_write(NULL, 0, 24, 0);
(void)mesa_gpio_write(NULL, 0, 25, 1);
break;
case 5:
break;
case 6:
break;
case 7:
break;
default:
break;
if (dev->callout->miim_read(dev->callout_ctx, addr, value) != MESA_RC_OK) {
T_E(MEPA_TRACE_GRP_GEN, "Port %d miim read failed\n", dev->numeric_handle);
return MEPA_RC_OK;
mepa_rc ti_direct_reg_wr(mepa_device_t *dev, uint16_t addr, uint16_t value, uint16_t mask)
switch(iport)
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
default:
break;
uint16_t reg_val = value;
mesa_rc rc;
rc = dev->callout->miim_read(dev->callout_ctx, addr, ®_val);
if (rc == MESA_RC_OK) {
if (mask != TI_DEF_MASK) {
reg_val = (reg_val & ~mask) | (value & mask);
} else {
reg_val = value;
rc = dev->callout->miim_write(dev->callout_ctx, addr, reg_val);
if (rc != MESA_RC_OK) {
T_E(MEPA_TRACE_GRP_GEN, "Port %d miim write failed\n", dev->numeric_handle);
} else {
return MEPA_RC_OK;
// Extended page read and write functions
// Extended page numbers range : 0 - 31
/*mepa_rc indy_ext_reg_rd(mepa_device_t *dev, uint16_t page, uint16_t addr, uint16_t *value)
// Set-up to access extended page register.
MEPA_RC(indy_direct_reg_wr(dev, INDY_EXT_PAGE_ACCESS_CTRL, page, INDY_DEF_MASK));
MEPA_RC(indy_direct_reg_wr(dev, INDY_EXT_PAGE_ACCESS_ADDR_DATA, addr, INDY_DEF_MASK));
INDY_F_EXT_PAGE_ACCESS_CTRL_EP_FUNC | page, INDY_DEF_MASK));
// Read the value
MEPA_RC(indy_direct_reg_rd(dev, INDY_EXT_PAGE_ACCESS_ADDR_DATA, value));
return MEPA_RC_OK;
mepa_rc indy_ext_reg_wr(mepa_device_t *dev, uint16_t page, uint16_t addr, uint16_t value, uint16_t mask)
// write the value
MEPA_RC(indy_direct_reg_wr(dev, INDY_EXT_PAGE_ACCESS_ADDR_DATA, value, mask));
return MEPA_RC_OK;
// MMD read and write functions
// MMD device range : 0 - 31
mepa_rc ti_mmd_reg_rd(mepa_device_t *dev, uint16_t mmd, uint16_t addr, uint16_t *value)
// Set-up to MMD register.
MEPA_RC(ti_direct_reg_wr(dev, TI_MMD_ACCESS_CTRL, 0x001F, TI_DEF_MASK));
MEPA_RC(ti_direct_reg_wr(dev, TI_MMD_ACCESS_ADDR_DATA, addr, TI_DEF_MASK));
MEPA_RC(ti_direct_reg_wr(dev, TI_MMD_ACCESS_CTRL, 0x401F, TI_DEF_MASK));
// Read the value
MEPA_RC(ti_direct_reg_rd(dev, TI_MMD_ACCESS_ADDR_DATA, value));
/*MEPA_RC(ti_direct_reg_wr(dev, TI_MMD_ACCESS_CTRL, 0x001F, TI_DEF_MASK));
// Read the value
MEPA_RC(ti_direct_reg_rd(dev, TI_MMD_ACCESS_ADDR_DATA, value));*/
return MEPA_RC_OK;
mepa_rc ti_mmd_reg_wr(mepa_device_t *dev, uint16_t mmd, uint16_t addr, uint16_t value, uint16_t mask)
// write the value
MEPA_RC(ti_direct_reg_wr(dev, TI_MMD_ACCESS_ADDR_DATA, value, mask));
return MEPA_RC_OK;
static mepa_rc ti_delete(mepa_device_t *dev)
return mepa_delete_int(dev);
static mepa_rc ti_get_device_info(mepa_device_t *dev)
uint16_t id;
RD(dev, TI_DEVICE_ID_2, &id);
data->dev.model = TI_X_DEV_ID_MODEL(id);
data->dev.rev = TI_X_DEV_ID_REV(id);
printf("DEV_ID_MODEL: %02X\n",TI_X_DEV_ID_MODEL(id));
printf("DEV_ID_REV: %02X\n",TI_X_DEV_ID_REV(id));
T_I(MEPA_TRACE_GRP_GEN, "model 0x%x rev %d\n", data->dev.model, data->dev.rev);
return MEPA_RC_OK;
static void ti_phy_deb_pr_reg (mepa_device_t *dev,
const mepa_debug_print_t pr,
const char *str, uint16_t *value)
mepa_rc rc = MEPA_RC_OK;
mepa_port_no_t port_no = data->port_no;
uint16_t id=0;
if (mmd) {
id = mmd;
rc = ti_mmd_reg_rd(dev, mmd, addr, value);
} else {
rc = ti_direct_reg_rd(dev, addr, value);
if(pr && (MEPA_RC_OK == rc)) {
pr("%-45s: 0x%02x 0x%02x 0x%04x 0x%08x\n", str, to_u32(port_no), id, addr, *value);
static mepa_rc ti_reg_dump(struct mepa_device *dev,
const mepa_debug_print_t pr)
uint16_t val = 0;
//uint16_t id = 0;
//Direct registers
pr("%-45s PORT_NO REG_ADDR VALUE\n", "REG_NAME");
pr("Main Page Registers\n");
ti_phy_deb_pr_reg(dev, pr, 0, 0, "Basic Mode Control Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 1, "Basic Mode Status Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 2, "PHY Identifier Register #1", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 3, "PHY Identifier Register #2 ", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 4, "Auto-Negotiation Advertisement Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 5, "Auto-Negotiation Link Partner Ability Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 6, "Auto-Negotiate Expansion Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 7, "Auto-Negotiation Next Page Transmit Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 8, "Auto-Negotiation Link Partner Next Page Receive Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 9, "Configuration Register 1 ", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 10, "Status Register 1", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 13, "Register Control Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 14, "Address or Data Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 15, "1000BASE-T Status Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 16, "PHY Control Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 17, "PHY Status Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 18, "MII Interrupt Control Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 19, "Interrupt Status Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 20, "Configuration Register 2", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 21, "RX_ERR_CNT", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 22, "BIST Control Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 23, "Status Register 2", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 24, "LED Configuration Register 1", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 25, "LED Configuration Register 2 ", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 26, "LED Configuration Register 3 ", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 30, "Configuration Register 3", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 31, "Control Register", &val);
/*ti_phy_deb_pr_reg(dev, pr, 0, 29, "Digital Debug Control 2 Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 30, "Reserved Register", &val);
ti_phy_deb_pr_reg(dev, pr, 0, 31, "Control Register", &val);*/
//Extended page-0,1,2,3,4,5,7,28,29,31 registers
/* pr("Extended Page-0 Registers\n");
indy_phy_deb_pr_reg(dev, pr, 0, 1, 0, "Debug-Mode First-Level-Select Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 1, "Debug-Mode Second-Level-Select for DIGITOP Part 1 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 2, "Debug-Mode Second-Level-Select for DIGITOP Part 2 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 3, "Auto-Negotiation Timer Register 1", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 4, "Auto-Negotiation Timer Register 2", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 5, "Auto-Negotiation Timer Register 3", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 6, "Auto-Negotiation Timer Register 4", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 7, "Auto-Negotiation Timer Register 5", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 8, "Auto-Negotiation Timer Register 6", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 9, "Auto-Negotiation Timer Register 7", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 10, "MDIX Select Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 11, "Max-Timer for 1.24 Millisecond Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 12, "Auto-Negotiation Wait Timer Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 13, "Max Link Timer Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 14, "Debug Bus Option Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 15, "Fast Link Fail (FLF) Configuration and Status Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 1, 16, "Link Partner Force FD Override Register", &val);
pr("Extended Page-1 Registers\n");
for(id = 0; id < 239; id++) {
indy_phy_deb_pr_reg(dev, pr, 0, 2, id, "Extended Page 1 Registers", &val);
pr("Extended Page-2 Registers\n");
for(id = 0; id < 111; id++) {
indy_phy_deb_pr_reg(dev, pr, 0, 3, id, "Extended Page 2 Registers", &val);
pr("Extended Page-3 Registers\n");
for(id = 0; id < 28; id++) {
indy_phy_deb_pr_reg(dev, pr, 0, 4, id, "Extended Page 3 Registers", &val);
pr("Extended Page-4 Registers\n");
for(id = 0; id < 772; id++) {
indy_phy_deb_pr_reg(dev, pr, 0, 5, id, "Extended Page 4 Registers", &val);
pr("Extended Page-5 Registers\n");
for(id = 0; id < 708; id++) {
indy_phy_deb_pr_reg(dev, pr, 0, 6, id, "Extended Page 5 Registers", &val);
pr("Extended Page-7 Registers\n");
indy_phy_deb_pr_reg(dev, pr, 0, 8, 58, "EP7 Register 58", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 8, 59, "EP7 Register 59", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 8, 62, "EEE Link Partner Ability Override Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 8, 63, "EEE Message Code Register", &val);
pr("Extended Page-28 Registers\n");
for(id = 0; id < 80; id++) {
indy_phy_deb_pr_reg(dev, pr, 0, 29, id, "Extended Page 28 Registers", &val);
pr("Extended Page-29 Registers\n");
indy_phy_deb_pr_reg(dev, pr, 0, 30, id, "Extended Page 29 Registers", &val);
pr("Extended Page-31 Registers\n");
indy_phy_deb_pr_reg(dev, pr, 0, 32, 0, "Speed Mode with TESTBUS Control Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 8, "Clock Management Mode 0", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 9, "Clock Management Mode 1", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 10, "Clock Management Mode 2", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 11, "Clock Management Mode 3", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 12, "Clock Management Mode 4", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 13, "Clock Management Mode 5", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 14, "Clock Management Mode 6", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 15, "Clock Management Mode 7", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 16, "Clock Management Mode 8", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 32, 17, "Clock Management Mode 9", &val);
//MMD-3,7 registers
pr("%-45s PORT_NO DEV_ID REG_ADDR VALUE\n", "REG_NAME");
pr("MMD-3 Registers\n");
indy_phy_deb_pr_reg(dev, pr, 3, 0x0, 0, "PCS Control 1 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 3, 0x0, 1, "PCS Status 1 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 3, 0x0, 20,"EEE Control and Capability Register", &val);
pr("MMD-7 Registers\n");
indy_phy_deb_pr_reg(dev, pr, 7, 0x0, 60,"EEE Advertisement Register", &val);
indy_phy_deb_pr_reg(dev, pr, 7, 0x0, 61,"EEE Link Partner Ability Register", &val);*/
return MEPA_RC_OK;
static mepa_rc ti_debug_info_dump(struct mepa_device *dev,
const mepa_debug_info_t *const info)
//PHY Debugging
switch(info->group)
case MEPA_DEBUG_GROUP_ALL:
case MEPA_DEBUG_GROUP_PHY:
MEPA_ENTER(dev);
rc = ti_reg_dump(dev, pr);
MEPA_EXIT(dev);
break;
default:
rc = MEPA_RC_OK;
//PHY_TS Debugging
//ti_ts_debug_info_dump(dev, pr, info);
return rc;
static mepa_rc ti_init_conf(mepa_device_t *dev)
phy_data_t *data = (phy_data_t *) dev->data;
uint16_t val;
ti_get_device_info(dev);
// Set config only for base port of phy.
//if (data->dev.model == 0x26) {
/*if (data->packet_idx == 0) {
//EP_WR(dev, INDY_CHIP_HARD_RESET, 1);
MEPA_MSLEEP(1);
if (!data->qsgmii_phy_aneg_dis) {
// Disable QSGMII auto-negotiation common for 4 ports.
WRM(dev, TI_GEN_CFG2, 0, TI_F_SGMII_AUTONEG_EN);
data->qsgmii_phy_aneg_dis = TRUE;
// Enable Fast link config
//val = INDY_FLF_CFG_STAT_LINK_DOWN | INDY_FLF_CFG_STAT_FLF_ENABLE;
//EP_WRM(dev, INDY_FLF_CONFIG_STATUS, val, val);
// Clear all GPHY interrupts during initialisation
WR(dev, TI_INTERRUPT_MASK, 0);
//WRM(dev, INDY_PTP_TSU_INT_EN, 0, INDY_DEF_MASK);
RD(dev, TI_INTR_STATUS, &val);
// Enable chip level interrupt
//EP_WRM(dev, INDY_INTR_CTRL, INDY_INTR_CTRL_CHIP_LVL_ENA, INDY_INTR_CTRL_CHIP_LVL_ENA);*/
return MEPA_RC_OK;
// Configure qsgmii aneg advertisement capabilities
static void ti_sgmii_tx_abilities(mepa_device_t *dev, mepa_port_speed_t speed, mepa_bool_t duplex)
uint16_t value = 0x1; // default disable EEE enable & EEE clock stop
uint16_t eee_val;
MMD_RD(dev, TI_GEN_STATUS1, &eee_val);
/*if (speed == MEPA_SPEED_1G) {
value |= (eee_val & TI_F_GEN_STATUS1_1000_T_FULL_DUP) ? 0x180 : 0;
} else if (speed == MEPA_SPEED_100M) {
value |= (eee_val & INDY_F_LP_EEE_ABILITY_100_BT) ? 0x180 : 0;
if (duplex) {
value |= INDY_BIT(12);
value |= (speed == MEPA_SPEED_1G) ? INDY_BIT(10) : (speed == MEPA_SPEED_100M) ? INDY_BIT(9) : 0;
value |= INDY_BIT(14);
EP_WR(dev, INDY_QSGMII_PCS1G_ANEG_TX_ADVERTISE_CAP, value);
EP_WRM(dev, INDY_QSGMII_PCS1G_ANEG_CONFIG, INDY_F_QSGMII_PCS1G_ANEG_CONFIG_ANEG_RESTART, INDY_F_QSGMII_PCS1G_ANEG_CONFIG_ANEG_RESTART);*/
WRM(dev, TI_FX_CTRL,TI_CTRL0_RESTART_AN, TI_CTRL0_RESTART_AN);
printf("ti_sgmii_aneg 1\n");
if (data->dev.model != 0x0F) {
//printf("MODEL_NUM(if) = %02X\n",data->dev.model);
return MEPA_RC_OK;
printf("MODEL_NUM = %02X\n",data->dev.model);
T_I(MEPA_TRACE_GRP_GEN, "sgmii aneg ena %d", ena);
if (!ena) {
// Disable SGMII auto-negotiation
printf("Disable SGMII auto-negotiation\n");
WRM(dev, TI_GEN_CFG2, 0,TI_F_SGMII_AUTONEG_EN);
WRM(dev, TI_GEN_CFG2,TI_F_SGMII_SOFT_RESET, TI_F_SGMII_SOFT_RESET);
} else {
// Enable SGMII auto-negotiation.
printf("Enable SGMII auto-negotiation.\n");
WRM(dev, TI_GEN_CFG2,TI_F_SGMII_AUTONEG_EN, TI_F_SGMII_AUTONEG_EN);
//WRM(dev, TI_GEN_CFG2,TI_F_SGMII_AUTONEG_EN, TI_F_SGMII_AUTONEG_EN);
//WRM(dev, TI_GEN_CFG2,TI_F_SGMII_SOFT_RESET, TI_F_SGMII_SOFT_RESET);
return MEPA_RC_OK;
/*static mepa_rc indy_rev_workaround(mepa_device_t *dev)
uint16_t val;
// work-arounds applicable for both models 0x26 & 0x27
do {
// work-around for Rev C done.
if (data->dev.rev >= 2) {
break;
// MDI-X setting for swap A,B transmit
EP_WRM(dev, INDY_ALIGN_SWAP, INDY_F_ALIGN_TX_A_B_SWAP, INDY_M_ALIGN_TX_SWAP);
} while (0);
// work-around for model 0x27 only
if (data->dev.model == 0x27 && data->dev.rev <= 2) {
// In Indy internal phy clock generation stops when link goes down.
EP_WR(dev, INDY_CLOCK_MANAGEMENT_MODE_5, 0x27e);
EP_RD(dev, INDY_LINK_QUALITY_MONITOR_SETTING, &val);
// work-around for model 0x27 done.
if (data->dev.model != 0x26) {
return MEPA_RC_OK;
// work-arounds applicable for only model 0x26
// Rev A, B, C
// PLL trim
EP_WR(dev, INDY_ANALOG_CONTROL_1, 0x40);
EP_WR(dev, INDY_ANALOG_CONTROL_10, 0x1);
// Rev C work-around done.
return MEPA_RC_OK;
// Rev B work-around done.
if (data->dev.rev >= 1) {
return MEPA_RC_OK;
EP_WR(dev, INDY_OPERATION_MODE_STRAP_LOW, 0x2);
EP_WR(dev, INDY_OPERATION_MODE_STRAP_HIGH, 0xc001);
T_D(MEPA_TRACE_GRP_GEN, "rev A work-around configured");
return MEPA_RC_OK;
/*static mepa_rc indy_workaround_after_reset(mepa_device_t *dev)
// Improve cable reach beyond 130m
EP_WR(dev, INDY_PD_CONTROLS, 0x248b);
EP_WR(dev, INDY_DFE_INIT2_100, 0x3c30);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_0, 0x10a);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_1, 0xed);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_2, 0xd3);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_3, 0xbc);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_4, 0xa8);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_5, 0x96);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_6, 0x85);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_7, 0x77);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_8, 0x6a);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_9, 0x5e);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_10, 0x54);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_11, 0x4b);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_12, 0x43);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_13, 0x3c);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_14, 0x35);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_15, 0x2f);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_16, 0x2a);
EP_WR(dev, INDY_PGA_TABLE_1G_ENTRY_17, 0x26);
// Set Rx-clk to avoid crc errors in near-end loopback
WRM(dev, INDY_UNH_TEST, INDY_F_TEST_RX_CLK, INDY_F_TEST_RX_CLK);
// Magjack center tapped ports
EP_WR(dev, INDY_POWER_MGMT_MODE_3, 0x6677);
EP_WR(dev, INDY_POWER_MGMT_MODE_4, 0x6677);
EP_WR(dev, INDY_POWER_MGMT_MODE_5, 0x6677);
EP_WR(dev, INDY_POWER_MGMT_MODE_6, 0x6677);
EP_WR(dev, INDY_POWER_MGMT_MODE_7, 0x0077);
EP_WR(dev, INDY_POWER_MGMT_MODE_8, 0x4377);
EP_WR(dev, INDY_POWER_MGMT_MODE_9, 0x4377);
EP_WR(dev, INDY_POWER_MGMT_MODE_10, 0x6777);
EP_WR(dev, INDY_POWER_MGMT_MODE_11, 0x0777);
EP_WR(dev, INDY_POWER_MGMT_MODE_12, 0x0777);
EP_WR(dev, INDY_POWER_MGMT_MODE_13, 0x6777);
EP_WR(dev, INDY_POWER_MGMT_MODE_14, 0x6777);
return MEPA_RC_OK;
/*static mepa_rc ti_reset(mepa_device_t *dev, const mepa_reset_param_t *rst_conf)
//uint32_t status;
MEPA_ENTER(dev);
if (!data->init_done) {
ti_init_conf(dev);
ti_sgmii_aneg(dev, FALSE);
data->init_done = TRUE;
//WRM(dev, TI_GEN_CTRL, TI_F_SW_RESET, TI_F_SW_RESET);
//WRM(dev, TI_GEN_CTRL, TI_F_SW_RESTART, TI_F_SW_RESTART);
printf("ti_reset\n");
if (rst_conf->reset_point == MEPA_RESET_POINT_DEFAULT) {
//WRM(dev, TI_BMCR, TI_F_BMCR_SOFT_RESET, TI_F_BMCR_SOFT_RESET);
} else if (rst_conf->reset_point == MEPA_RESET_POINT_POST_MAC) {
// To avoid qsgmii serdes and Gphy blocks settling in different speeds, use qsgmii soft reset and restart aneg.
// This must be applied after Mac serdes is configured.
WR(dev, TI_F_SGMII_SOFT_RESET, 0x1);
WRM(dev, TI_BMCR, TI_F_BMCR_RESTART_ANEG, TI_F_BMCR_RESTART_ANEG);
MEPA_MSLEEP(1);
// Some of the work-around registers get cleared after reset. So, they are called here
// after every reset.
//indy_workaround_after_reset(dev);
MEPA_EXIT(dev);
T_I(MEPA_TRACE_GRP_GEN, "Reconfiguring the phy after reset");
// Reconfigure the phy after reset
ti_conf_set(dev, &data->conf);
if (data->events) {
ti_event_enable_set(dev, data->events, TRUE);
return MEPA_RC_OK;
MEPA_ENTER(dev);
MEPA_MSLEEP(10);
MEPA_EXIT(dev);
static mepa_rc ti_poll(mepa_device_t *dev, mepa_status_t *status)
uint16_t val, val2 = 0;
//printf("ti_poll\n");
MEPA_ENTER(dev);
RD(dev, TI_BMSR, &val);
status->link = (val & TI_F_BMSR_LINK_STATUS) ? 1 : 0;
/*if (data->loopback.near_end_ena == TRUE) {
// loops back to Mac. Ignore Line side status to Link partner.
status->link = 1;
if (data->conf.speed == MEPA_SPEED_AUTO || data->conf.speed == MEPA_SPEED_1G) {
uint16_t lp_sym_pause = 0, lp_asym_pause = 0;
// Default values
status->speed = MEPA_SPEED_1G;
status->fdx = 1;
// check if auto-negotiation is completed or not.
if (status->link && !(val & TI_F_BMSR_ANEG_COMPLETE)) {
T_I(MEPA_TRACE_GRP_GEN, "Aneg is not completed for port %d", data->port_no);
status->link = 0;
} else if (data->loopback.near_end_ena) {
if (!status->link || data->loopback.near_end_ena) {
// No need to read aneg values when link is down or when near-end loopback enabled.
goto end;
// Obtain speed and duplex from link partner's advertised capability.
RD(dev, TI_ALNPAR_LP_BASE, &val);
RD(dev, TI_GEN_STATUS1, &val2);
// 1G half duplex is not supported. Refer direct register - 9
if ((val2 & TI_F_GEN_STATUS1_1000_T_FULL_DUP) &&
data->conf.aneg.speed_1g_fdx) {
status->fdx = 1;
} else if ((val & TI_F_ALNPAR_LP_BASE_100_X_FULL_DUP) &&
data->conf.aneg.speed_100m_fdx) {
status->speed = MEPA_SPEED_100M;
status->fdx = 1;
} else if ((val & TI_F_ALNPAR_LP_BASE_100_X_HALF_DUP) &&
data->conf.aneg.speed_100m_hdx) {
status->fdx = 0;
} else if ((val & TI_F_ALNPAR_LP_BASE_10_T_FULL_DUP) &&
data->conf.aneg.speed_10m_fdx) {
status->speed = MEPA_SPEED_10M;
status->fdx = 1;
} else if ((val & TI_F_ALNPAR_LP_BASE_10_T_HALF_DUP) &&
data->conf.aneg.speed_10m_hdx) {
status->fdx = 0;
// Get flow control status
lp_sym_pause = (val & TI_F_ALNPAR_LP_BASE_SYM_PAUSE) ? 1 : 0;
lp_asym_pause = (val & TI_F_ALNPAR_LP_BASE_ASYM_PAUSE) ? 1 : 0;
status->aneg.obey_pause = data->conf.flow_control && (lp_sym_pause || lp_asym_pause);
status->aneg.generate_pause = data->conf.flow_control && lp_sym_pause;
} else {
uint8_t speed;
// Forced speed
RD(dev, TI_BMCR, &val2);
speed = (!!(val2 & TI_F_BMCR_SPEED_SEL_BIT_0)) |
(!!(val2 & TI_F_BMCR_SPEED_SEL_BIT_1) << 1);
status->speed = (speed == 0) ? MEPA_SPEED_10M :
(speed == 1) ? MEPA_SPEED_100M :
(speed == 2) ? MEPA_SPEED_1G : MEPA_SPEED_UNDEFINED;
status->fdx = !!(val2 & TI_F_BMCR_DUP_MODE);
//check that aneg is not enabled.
if (val2 & TI_F_BMCR_ANEG_ENA) {
T_W(MEPA_TRACE_GRP_GEN, "Aneg is enabled for forced speed config on port %d", data->port_no);
end:
if ( data->conf.speed == MEPA_SPEED_AUTO &&
data->conf.mac_if_aneg_ena) {
if (status->link && status->link != data->link_status) {
// copy the capabilities on host side
ti_sgmii_tx_abilities(dev, status->speed, status->fdx);
data->link_status = status->link;
MEPA_EXIT(dev);
T_D(MEPA_TRACE_GRP_GEN, "port %d status link %d, speed %d, fdx %d", data->port_no, status->link, status->speed, status->fdx);
return MEPA_RC_OK;
uint16_t new_value, mask, old_value,new_reg_value;
uint16_t status1,status2,status3,status4,status5,status6;
int phy_ctrl_val;
uint16_t val;
mepa_bool_t restart_aneg = FALSE;
mepa_bool_t sgmii_aneg = config->speed != MEPA_SPEED_AUTO ? FALSE : config->mac_if_aneg_ena;
MEPA_ENTER(dev);
/* Force speed optimization for the PHY even if it strapped */
WRM(dev, TI_GEN_CFG2, TI_F_SPEED_OPT_EN, TI_F_SPEED_OPT_EN);
/*Configure mode*/
WRM(dev, TI_OP_MODE_DECODE, TI_SGMII_COPPER_ETHERNET, TI_SGMII_COPPER_ETHERNET);
WRM(dev, TI_BMCR, TI_DP83869_BMCR_DEFAULT,TI_DP83869_BMCR_DEFAULT);
phy_ctrl_val = (TI_F_RX_FIFO_DEPTH | TI_F_TX_FIFO_DEPTH | DP83869_PHY_CTRL_DEFAULT);
printf("TI_PHY_CONTROL-%02X\n",phy_ctrl_val);
WRM(dev, TI_PHY_CONTROL , phy_ctrl_val,phy_ctrl_val);
WRM(dev, TI_GEN_CFG1 , TI_CFG1_DEFAULT, TI_CFG1_DEFAULT);
RD(dev, TI_GEN_CFG1, &val);
printf("TI_GEN_CFG1-%02X\n",val);
WRM(dev, TI_FX_CTRL , TI_FX_CTRL_DEFAULT, TI_FX_CTRL_DEFAULT);
WRM(dev, TI_GEN_CTRL , TI_F_SW_RESTART,TI_F_SW_RESTART);
/* Enable Interrupt output INT_OE in CFG4 register */
//RD(dev, TI_GEN_CFG4, &val);
//val |= DP83869_INT_OE;
WRM(dev, TI_GEN_CFG4, TI_F_INT_OE,TI_F_INT_OE);
/* Clock output selection if muxing property is set */
//WRM(dev, TI_IO_MUX_CFG, DP83869_IO_MUX_CFG_CLK_O_SEL_MASK , DP83869_IO_MUX_CFG_CLK);
if (config->admin.enable) {
if (sgmii_aneg != data->conf.mac_if_aneg_ena) {
ti_sgmii_aneg(dev, sgmii_aneg);
printf("sgmii_aneg != data->conf.mac_if_aneg_ena\n");
if (config->speed == MEPA_SPEED_AUTO || config->speed == MEPA_SPEED_1G) {
printf("config->speed == MEPA_SPEED_AUTO || config->speed == MEPA_SPEED_1G\n");
/*if (data->conf.admin.enable != config->admin.enable) {
printf("data->conf.admin.enable != config->admin.enable\n");
restart_aneg = TRUE;
// 1G manual negotiation & speed
/* Setup register 9 for 1G advertisement */
RD(dev, TI_GEN_CFG1, &new_value);
new_reg_value = 0;
if (config->aneg.speed_1g_fdx) {
new_reg_value |= TI_F_GEN_CFG1_G_1000BT_FD_ADV;
printf("man_neg\n");
new_reg_value |= TI_F_GEN_CFG1_G_PORT_TYPE;
new_reg_value |= TI_F_GEN_CFG1_CFG_MAN_CFG_VAL;
mask = TI_F_GEN_CFG1_G_1000BT_FD_ADV;
if (config->aneg.speed_1g_hdx) {
new_reg_value |= TI_F_GEN_CFG1_G_1000BT_HD_ADV;
if (config->man_neg) {
printf("config->man_neg\n");
new_reg_value |= TI_F_GEN_CFG1_CFG_MAN_CFG_ENA;
new_reg_value |= config->man_neg == MEPA_MANUAL_NEG_REF ? TI_F_GEN_CFG1_CFG_MAN_CFG_VAL : 0;
mask |= (TI_F_GEN_CFG1_CFG_MAN_CFG_VAL | TI_F_GEN_CFG1_CFG_MAN_CFG_ENA);
/*if (config->aneg.speed_1g_fdx != data->conf.aneg.speed_1g_fdx ||
(config->man_neg && (config->man_neg != data->conf.man_neg))) {
printf("config->aneg.speed_1g_fdx != data->conf.aneg.speed_1g_fdx || (config->man_neg && (config->man_neg != data->conf.man_neg\n");
WRM(dev, TI_GEN_CFG1, new_reg_value, mask);
/*if ((new_value & (TI_F_GEN_CFG1_G_1000BT_FD_ADV | TI_F_GEN_CFG1_G_1000BT_HD_ADV)) != new_reg_value) {
// Set up auo-negotiation advertisement in register 4
new_value = (((config->aneg.tx_remote_fault ? 1 : 0) << 13) |
((config->flow_control ? 1 : 0) << 11) |
((config->flow_control ? 1 : 0) << 10) |
((config->aneg.speed_100m_fdx ? 1 : 0) << 8) |
((config->aneg.speed_100m_hdx ? 1 : 0) << 7) |
((config->aneg.speed_10m_fdx ? 1 : 0) << 6) |
((config->aneg.speed_10m_hdx ? 1 : 0) << 5) |
(1 << 0)); // default selector field - 1
RD(dev, TI_ANEG_ADVERTISEMENT, &old_value);
/*if (old_value != new_value) {
WR(dev, TI_ANEG_ADVERTISEMENT, new_value);
// Enable & restart auto-negotiation
new_value = TI_F_BMCR_ANEG_ENA;
WRM(dev, TI_BMCR, new_value, new_value | TI_F_BMCR_SOFT_POW_DOWN);
if (restart_aneg) {
printf("restart_aneg\n");
T_I(MEPA_TRACE_GRP_GEN, "Aneg restarted on port %d", data->port_no);
} else if (config->speed != MEPA_SPEED_UNDEFINED) {
printf("config->speed != MEPA_SPEED_UNDEFINED\n");
T_I(MEPA_TRACE_GRP_GEN, "forced speed %d configured\n", config->speed);
new_value = ((config->speed == MEPA_SPEED_100M ? 1 : 0) << 13) | (0 << 12) |
((config->fdx ? 1 : 0) << 8) |
((config->speed == MEPA_SPEED_1G ? 1 : 0) << 6);
mask = TI_BIT(13) | TI_BIT(12) | TI_BIT(8) | TI_BIT(6) | TI_F_BMCR_SOFT_POW_DOWN | TI_F_BMCR_ANEG_ENA;
WRM(dev, TI_BMCR, new_value, mask);
} else {
printf("else power down\n");
T_I(MEPA_TRACE_GRP_GEN, "set power down\n");
// set soft power down bit
WRM(dev, TI_BMCR, TI_F_BMCR_SOFT_POW_DOWN, TI_F_BMCR_SOFT_POW_DOWN);
data->conf = *config;
data->conf.mac_if_aneg_ena = sgmii_aneg;
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_rc ti_conf_get(mepa_device_t *dev, mepa_conf_t *const config)
//printf("ti_conf_get\n");
MEPA_ENTER(dev);
*config = data->conf;
MEPA_EXIT(dev);
T_D(MEPA_TRACE_GRP_GEN, "returning phy config on port %d", data->port_no);
return MEPA_RC_OK;
/*static mepa_rc mas_if_set(mepa_device_t *dev,
mepa_port_interface_t mac_if)
if (mac_if != MESA_PORT_INTERFACE_SGMII) {
return MEPA_RC_ERROR;
return MEPA_RC_OK;
static mepa_rc mas_if_get(mepa_device_t *dev, mepa_port_speed_t speed,
mepa_port_interface_t *mac_if)
*mac_if = MESA_PORT_INTERFACE_SGMII;
return MEPA_RC_OK;
static mepa_rc ti_if_set(mepa_device_t *dev,
if (mac_if == MESA_PORT_INTERFACE_SGMII) {
//return MEPA_RC_ERROR;
return MEPA_RC_OK;
static mepa_rc ti_if_get(mepa_device_t *dev, mepa_port_speed_t speed,
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return MEPA_RC_OK;
// wait in loop while cable diagnostics is running.
/*static mepa_bool_t indy_wait_for_cable_diagnostics(mepa_device_t *dev)
uint8_t cnt = 0;
uint16_t value;
mepa_bool_t ret = FALSE;
while (cnt < 100) { // wait for utmost 1 second
RD(dev, INDY_CABLE_DIAG, &value);
if (value & INDY_F_CABLE_DIAG_TEST_ENA) {
MEPA_MSLEEP(10);
cnt++;
} else {
ret = TRUE;
break;
T_D(MEPA_TRACE_GRP_GEN, "ret = %d cnt= %d value=0x%x\n", ret, cnt, value);
return ret;
//Before starting cable diagnostics, do necessary phy configuration like reset speed config.
/*static mepa_rc indy_cab_diag_enter_config(mepa_device_t *dev)
WRM(dev, TI_BMCR, INDY_F_BASIC_CTRL_SOFT_RESET, INDY_F_BASIC_CTRL_SOFT_RESET);
MEPA_MSLEEP(1);
WR(dev, TI_BMCR, 0x140);
MEPA_MSLEEP(50);
return MEPA_RC_OK;
// After exiting cable diagnostics, restore phy configuration.
/*static mepa_rc indy_cab_diag_exit_config(mepa_device_t *dev)
mepa_reset_param_t rst_cfg = {};
rst_cfg.reset_point = MEPA_RESET_POINT_DEFAULT;
// Restore configuration after cable diagnostics.
indy_reset(dev, &rst_cfg);
return MEPA_RC_OK;
// Indy phy dignostics is calculated only when there is no remote link partner for the port.
// For mode values {0,1} corresponding to {VTSS_PHY_MODE_ANEG, VTSS_PHY_MODE_FORCED}, diagnostics is calculated.
// For power down mode(2), diagnostics is not calculated.
/*static mepa_rc indy_cab_diag_start(mepa_device_t *dev, int mode)
uint16_t value, mask = 0, pair, status;
mepa_cable_diag_result_t *res = &data->cable_diag;
T_I(MEPA_TRACE_GRP_GEN, "port=%d mode=%d\n", data->port_no, mode);
MEPA_ENTER(dev);
// Initialize diagnostics
for (pair = 0; pair < 4; pair++) {
res->status[pair] = MEPA_CABLE_DIAG_STATUS_UNKNOWN;
res->length[pair] = 0;
res->link = FALSE;
// return for power down mode
if (mode == INDY_CABLE_MODE_POWER_DOWN) {
MEPA_EXIT(dev);
indy_cab_diag_enter_config(dev);
// clear diag test ena before starting
WRM(dev, INDY_CABLE_DIAG, 0, INDY_F_CABLE_DIAG_TEST_ENA);
value = mask = status = 0;
value |= INDY_F_CABLE_DIAG_TEST_ENA;
value |= INDY_F_CABLE_TEST_PAIR(pair);
mask |= INDY_F_CABLE_DIAG_TEST_ENA | INDY_M_CABLE_TEST_PAIR;
WRM(dev, INDY_CABLE_DIAG, value, mask);
if (indy_wait_for_cable_diagnostics(dev)) {
status = INDY_X_CABLE_DIAG_STATUS(value);
if ((status == INDY_CABLE_OPEN) || (status == INDY_CABLE_SHORT)) {
res->status[pair] = (status == INDY_CABLE_SHORT) ? MEPA_CABLE_DIAG_STATUS_SHORT : MEPA_CABLE_DIAG_STATUS_OPEN;
res->length[pair] = 0.8 * (INDY_X_CABLE_DIAG_DATA(value) - 22);
res->link = TRUE;
T_I(MEPA_TRACE_GRP_GEN, "pair=%d status=%d length=%d\n", pair, res->status[pair], res->length[pair]);
} else if (status == INDY_CABLE_FAIL) {
res->status[pair] = MEPA_CABLE_DIAG_STATUS_ABNORM;
res->link = FALSE;
T_I(MEPA_TRACE_GRP_GEN, "link status failed for pair %d \n", pair);
} else { // status as INDY_CABLE_NORMAL
res->link = TRUE;
T_I(MEPA_TRACE_GRP_GEN, "pair=%d status=%d \n", pair, status);
MEPA_EXIT(dev);
indy_cab_diag_exit_config(dev);
return MEPA_RC_OK;
static mepa_rc indy_cab_diag_get(mepa_device_t *dev, mepa_cable_diag_result_t *res)
MEPA_ENTER(dev);
*res = data->cable_diag;
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_rc ti_aneg_status_get(mepa_device_t *dev, mepa_aneg_status_t *status)
//printf("ti_aneg_status_get\n");
uint16_t val;
MEPA_ENTER(dev);
RD(dev, TI_GEN_STATUS1, &val);
status->master_cfg_fault = (val & TI_F_GEN_STATUS1_CFG_FAULT) ? TRUE : FALSE;
status->master = val & TI_F_GEN_STATUS1_CFG_RES ? TRUE : FALSE;
MEPA_EXIT(dev);
T_I(MEPA_TRACE_GRP_GEN, "aneg status get mstr %d", status->master);
return MEPA_RC_OK;
// read direct registers for debugging
static mepa_rc ti_direct_reg_read(mepa_device_t *dev, uint32_t address, uint16_t *const value)
mepa_rc rc;
uint16_t addr = address & 0x1f;
//printf("ti_direct_reg_read\n");
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return rc;
// write direct registers. Used for debugging.
static mepa_rc ti_direct_reg_write(mepa_device_t *dev, uint32_t address, uint16_t value)
mepa_rc rc;
//printf("ti_direct_reg_write\n");
MEPA_ENTER(dev);
rc = ti_direct_reg_wr(dev, addr, value, 0xFFFF);
MEPA_EXIT(dev);
return rc;
// read extended page/mmd register for debugging
static mepa_rc ti_mmd_reg_read(mepa_device_t *dev, uint32_t address, uint16_t *const value)
mepa_rc rc;
uint16_t page_mmd = (address >> 16) & 0xffff;
uint16_t addr = address & 0xffff;
uint16_t mmd = (page_mmd >> 11);
//printf("ti_mmd_reg_read\n");
MEPA_ENTER(dev);
//if (mmd) {
//printf("ti_mmd_reg_read");
//} /*else {
//rc = indy_ext_reg_rd(dev, page_mmd, addr, value);
MEPA_EXIT(dev);
return rc;
// write extended page/mmd register. Used for debugging.
static mepa_rc ti_mmd_reg_write(mepa_device_t *dev, uint32_t address, uint16_t value)
mepa_rc rc;
//printf("ti_mmd_reg_write\n");
MEPA_ENTER(dev);
//if (mmd) {
rc = ti_mmd_reg_wr(dev, mmd, addr, value, 0xFFFF);
/*else {
rc = indy_ext_reg_wr(dev, page_mmd, addr, value, 0xFFFF);
MEPA_EXIT(dev);
return rc;
// Enable events
uint16_t ev_mask = 0, i;
data->events = enable ? (data->events | event) :
(data->events & ~event);
//printf("ti_event_enable_set\n");
MEPA_ENTER(dev);
for (i = 0; i < sizeof(mepa_event_t) * 8; i++) {
switch (event & (1 << i)) {
case MEPA_LINK_LOS:
ev_mask = ev_mask | TI_F_INTERRUPT_MASK_LINK_STATUS;
break;
/*case MEPA_FAST_LINK_FAIL:
ev_mask = ev_mask | INDY_F_GPHY_INTR_ENA_FLF_INTR;
break;*/
default:
// Not yet implemented
break;
WRM(dev, TI_INTERRUPT_MASK, enable ? ev_mask : 0, ev_mask);
T_I(MEPA_TRACE_GRP_GEN, "events enabled 0x%x \n", data->events);
MEPA_EXIT(dev);
return rc;
// Get current enabled events
static mepa_rc ti_event_enable_get(mepa_device_t *dev, mepa_event_t *const event)
//printf("ti_event_enable_get\n");
MEPA_ENTER(dev);
*event = data->events;
MEPA_EXIT(dev);
return rc;
// Poll the status of currently enabled events
static mepa_rc ti_event_status_poll(mepa_device_t *dev, mepa_event_t *const status)
uint16_t val;
*status = 0;
//printf("ti_event_status_poll\n");
MEPA_ENTER(dev);
rc = RD(dev, TI_INTR_STATUS, &val);
if (val & TI_F_INTERRUPT_MASK_LINK_STATUS) {
*status |= data->events & MEPA_LINK_LOS;
/*if (val & INDY_F_GPHY_INTR_ENA_FLF_INTR) {
*status |= data->events & MEPA_FAST_LINK_FAIL;
MEPA_EXIT(dev);
T_I(MEPA_TRACE_GRP_GEN, " port %d events polled 0x%x val %x\n", data->port_no, *status, val);
return rc;
// Set loopback modes in phy
/*static mepa_rc ti_loopback_set(mepa_device_t *dev, const mepa_loopback_t *loopback)
//printf("ti_loopback_set\n");
if ((loopback->mac_serdes_input_ena == TRUE) || (loopback->mac_serdes_facility_ena == TRUE) ||
(loopback->mac_serdes_equip_ena == TRUE) || (loopback->media_serdes_input_ena == TRUE) ||
(loopback->media_serdes_facility_ena == TRUE) || (loopback->media_serdes_equip_ena == TRUE)) {
// Not supported on Indy
return MEPA_RC_NOT_IMPLEMENTED;
MEPA_ENTER(dev);
if (loopback->near_end_ena == TRUE) {
WRM(dev, TI_BMCR, TI_F_BMCR_LOOPBACK, TI_F_BMCR_LOOPBACK);
// Set 1000mbps speed for loopback when there is auto-negotiation mode. While removing loopback, restore the original mode.
// Disable auto-negotiation
WRM(dev, TI_BMCR, 0, TI_F_BMCR_ANEG_ENA);
WRM(dev, TI_BMCR, TI_F_BMCR_SPEED_SEL_BIT_1, TI_F_BMCR_SPEED_SEL_BIT_1 | TI_F_BMCR_SPEED_SEL_BIT_0);
} else if (data->loopback.near_end_ena == TRUE) {
WRM(dev, TI_BMCR, 0, TI_F_BMCR_LOOPBACK);
// Remove 1000mbps config applied while setting loopback.
WRM(dev, TI_GEN_CFG1, 0, TI_F_GEN_CFG1_CFG_MAN_CFG_ENA |
TI_F_GEN_CFG1_CFG_MAN_CFG_VAL);
// Enable aneg
WRM(dev, TI_BMCR, TI_F_BMCR_ANEG_ENA | TI_F_BMCR_RESTART_ANEG,
TI_F_BMCR_ANEG_ENA | TI_F_BMCR_RESTART_ANEG);
data->loopback = *loopback;
MEPA_EXIT(dev);
T_I(MEPA_TRACE_GRP_GEN, "loopback enabled\n");
return MEPA_RC_OK;
//printf("ti_loopback_get\n");
MEPA_ENTER(dev);
*loopback = data->loopback;
MEPA_EXIT(dev);
return MEPA_RC_OK;
// Returns gpio using port number and led number
/*static uint8_t led_num_to_gpio_mapping(mepa_device_t *dev, mepa_led_num_t led_num)
uint8_t gpio = 11;// port 0 as default.
switch (data->packet_idx) {
case 0:
gpio = led_num == MEPA_LED0 ? 11 : 12;
break;
case 1:
gpio = led_num == MEPA_LED0 ? 17 : 18;
break;
case 2:
gpio = led_num == MEPA_LED0 ? 19 : 20;
break;
case 3:
gpio = led_num == MEPA_LED0 ? 13 : 14;
break;
default:
// invalid.
break;
T_I(MEPA_TRACE_GRP_GEN, "gpio mapped %d\n", gpio);
return gpio;
static uint8_t led_mepa_mode_to_indy(mepa_gpio_mode_t mode)
uint8_t ret = 0;
switch (mode) {
case MEPA_GPIO_MODE_LED_LINK_ACTIVITY:
ret = 0;
break;
case MEPA_GPIO_MODE_LED_LINK1000_ACTIVITY:
ret = 1;
break;
case MEPA_GPIO_MODE_LED_LINK100_ACTIVITY:
ret = 2;
break;
case MEPA_GPIO_MODE_LED_LINK10_ACTIVITY:
ret = 3;
break;
case MEPA_GPIO_MODE_LED_LINK100_1000_ACTIVITY:
ret = 4;
break;
case MEPA_GPIO_MODE_LED_LINK10_1000_ACTIVITY:
ret = 5;
break;
case MEPA_GPIO_MODE_LED_LINK10_100_ACTIVITY:
ret = 6;
break;
case MEPA_GPIO_MODE_LED_DUPLEX_COLLISION:
ret = 8;
break;
case MEPA_GPIO_MODE_LED_COLLISION:
ret = 9;
break;
case MEPA_GPIO_MODE_LED_ACTIVITY:
ret = 10;
break;
case MEPA_GPIO_MODE_LED_AUTONEGOTIATION_FAULT:
ret = 12;
break;
case MEPA_GPIO_MODE_LED_FORCE_LED_OFF:
ret = 14;
break;
case MEPA_GPIO_MODE_LED_FORCE_LED_ON:
ret = 15;
break;
case MEPA_GPIO_MODE_LED_DISABLE_EXTENDED:
ret = 0xf0;
break;
default:
ret = 0xff; // Not valid for indy
break;
return ret;
// In Indy, LED0 of software Api maps to LED1 of hardware,
// LED1 of software Api maps to LED2 of hardware.
static mepa_rc indy_led_mode_set(mepa_device_t *dev, mepa_gpio_mode_t led_mode, mepa_led_num_t led_num)
uint16_t mode;
// Indy supports only LED0 and LED1
if ((led_num != MEPA_LED0) && (led_num != MEPA_LED1)) {
T_W(MEPA_TRACE_GRP_GEN, "8814 supports only leds 0 & 1\n");
if ((mode = led_mepa_mode_to_indy(led_mode)) == 0xff) {// Not valid
T_W(MEPA_TRACE_GRP_GEN, "Not valid led mode");
if (mode == MEPA_GPIO_MODE_LED_DISABLE_EXTENDED) {
// Normal operation
EP_WRM(dev, INDY_LED_CONTROL_REG1, INDY_F_LED_CONTROL_KSZ_LED_MODE, INDY_F_LED_CONTROL_KSZ_LED_MODE);
} else { // extended mode
EP_WRM(dev, INDY_LED_CONTROL_REG1, 0, INDY_F_LED_CONTROL_KSZ_LED_MODE);
EP_WRM(dev, INDY_LED_CONTROL_REG2, INDY_ENCODE_BITFIELD(mode, led_num * 4, 4), INDY_ENCODE_BITMASK(led_num * 4, 4));
return MEPA_RC_OK;
static mepa_rc indy_gpio_mode_private(mepa_device_t *dev, const mepa_gpio_conf_t *data)
uint16_t gpio_en = 0, dir, val = 0, gpio_no = data->gpio_no;
mepa_gpio_mode_t mode = data->mode;
if (mode == MEPA_GPIO_MODE_OUT || mode == MEPA_GPIO_MODE_IN) {
gpio_en = 1;
dir = mode == MEPA_GPIO_MODE_OUT ? 1 : 0;
} else if (mode >= MEPA_GPIO_MODE_LED_LINK_ACTIVITY && mode <= MEPA_GPIO_MODE_LED_DISABLE_EXTENDED) {
MEPA_RC(indy_led_mode_set(dev, mode, data->led_num));
// Enable alternative gpio mode for led.
gpio_no = led_num_to_gpio_mapping(dev, data->led_num);
} else if (mode == MEPA_GPIO_MODE_RCVRD_CLK_OUT1 || mode == MEPA_GPIO_MODE_RCVRD_CLK_OUT2) {
gpio_no = mode == MEPA_GPIO_MODE_RCVRD_CLK_OUT1 ? 9 : 10;
if (gpio_no < 16) {
val = 1 << gpio_no;
dir = dir << gpio_no;
EP_WRM(dev, INDY_GPIO_EN2, gpio_en ? val : 0, val);
if (gpio_en) {
EP_WRM(dev, INDY_GPIO_DIR2, dir, val);
} else if (gpio_no < 24) {
val = 1 << (gpio_no - 16);
dir = dir << (gpio_no - 16);
EP_WRM(dev, INDY_GPIO_EN1, gpio_en ? val : 0, val);
if (gpio_en) {
EP_WRM(dev, INDY_GPIO_DIR1, dir, val);
} else {
// Not supported. Illegal for Indy.
T_W(MEPA_TRACE_GRP_GEN, "Not valid gpio on 8814 phy");
return MEPA_RC_OK;
// Set gpio mode to input, output or alternate function
static mepa_rc indy_gpio_mode_set(mepa_device_t *dev, const mepa_gpio_conf_t *gpio_conf)
// Indy has 0-23 gpios.
if (gpio_conf->gpio_no > 23) {
MEPA_ENTER(dev);
rc = indy_gpio_mode_private(dev, gpio_conf);
MEPA_EXIT(dev);
return rc;
// Set Isolate mode
static mepa_rc ti_isolate_mode_conf(mepa_device_t *dev, const mepa_bool_t iso_en)
//printf("ti_isolate_mode_conf\n");
MEPA_ENTER(dev);
if (iso_en == TRUE) {
WRM(dev, TI_BMCR, TI_F_BMCR_ISO_MODE_EN, TI_F_BMCR_ISO_MODE_EN);
} else {
WRM(dev, TI_BMCR, 0, TI_F_BMCR_ISO_MODE_EN);
MEPA_EXIT(dev);
return MEPA_RC_OK;
/*static mepa_rc indy_gpio_out_set(mepa_device_t *dev, uint8_t gpio_no, mepa_bool_t value)
uint16_t val = 0;
if (gpio_no > 23) {
MEPA_ENTER(dev);
if (gpio_no < 16) {
val = 1 << gpio_no;
EP_WRM(dev, INDY_GPIO_DATA2, value ? val : 0, val);
EP_WRM(dev, INDY_GPIO_DATA1, value ? val : 0, val);
} else {
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_rc indy_gpio_in_get(mepa_device_t *dev, uint8_t gpio_no, mepa_bool_t *const value)
uint16_t val = 0;
if (gpio_no > 23) {
MEPA_ENTER(dev);
if (gpio_no < 16) {
EP_RD(dev, INDY_GPIO_DATA2, &val);
*value = (val >> gpio_no) & 0x1 ? TRUE : FALSE;
EP_RD(dev, INDY_GPIO_DATA1, &val);
*value = ((val >> (gpio_no - 16)) & 0x1) ? TRUE : FALSE;
MEPA_EXIT(dev);
return MEPA_RC_OK;
/*static mepa_rc indy_recovered_clk_set(mepa_device_t *dev, const mepa_synce_clock_conf_t *conf)
mepa_gpio_conf_t gpio_conf;
uint16_t divider = 1;
uint16_t clkout_src = 7;
MEPA_ENTER(dev);
// Enable recovered clock outputs in gpio
gpio_conf.mode = (conf->dst == MEPA_SYNCE_CLOCK_DST_1) ? MEPA_GPIO_MODE_RCVRD_CLK_OUT1 : MEPA_GPIO_MODE_RCVRD_CLK_OUT2;
rc = indy_gpio_mode_private(dev, &gpio_conf);
switch (conf->freq) {
case MEPA_FREQ_25M:
divider = 5; // 125Mhz/25Mhz = 5
break;
case MEPA_FREQ_31_25M:
divider = 4; // 125Mhz/31.25Mhz = 4
break;
case MEPA_FREQ_125M:
default:
divider = 1; // 125Mhz/125Mhz = 1
break;
switch (conf->src) {
case MEPA_SYNCE_CLOCK_SRC_DISABLED:
clkout_src = 7; // Forces Recovered Clock Output to 0
break;
case MEPA_SYNCE_CLOCK_SRC_COPPER_MEDIA:
clkout_src = data->packet_idx % 4;
break;
case MEPA_SYNCE_CLOCK_SRC_CLOCK_IN_1:
clkout_src = 0b100; // Recovered Clock Input 1
break;
case MEPA_SYNCE_CLOCK_SRC_CLOCK_IN_2:
clkout_src = 0b101; // Recovered Clock Input 2
break;
case MEPA_SYNCE_CLOCK_SRC_SERDES_MEDIA:
default:
T_W(MEPA_TRACE_GRP_GEN, "Invalid valid clock source, port-no : %d\n", dev->numeric_handle);
break;
T_I(MEPA_TRACE_GRP_GEN, "port_ena %d divider %d\n", clkout_src, divider);
if (conf->dst == MEPA_SYNCE_CLOCK_DST_1) {
EP_WR(dev, INDY_RCVRD_CLK_OUT_SEL_1, clkout_src);
EP_WR(dev, INDY_RCVRD_CLK_OUT_DIV_1, divider);
} else if (conf->dst == MEPA_SYNCE_CLOCK_DST_2) {
EP_WR(dev, INDY_RCVRD_CLK_OUT_SEL_2, clkout_src);
EP_WR(dev, INDY_RCVRD_CLK_OUT_DIV_2, divider);
MEPA_EXIT(dev);
data->synce_conf = *conf;
return rc;
// Link the base port
static mepa_rc ti_link_base_port(mepa_device_t *dev, mepa_device_t *base_dev, uint8_t packet_idx)
//printf("ti_link_base_port\n");
MEPA_ENTER(dev);
data->base_dev = base_dev;
data->packet_idx = packet_idx;
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_device_t *ti_probe(mepa_driver_t *drv,
const mepa_callout_t MEPA_SHARED_PTR *callout,
struct mepa_callout_ctx MEPA_SHARED_PTR *callout_ctx,
struct mepa_board_conf *board_conf)
mepa_device_t *dev;
phy_data_t *data;
dev = mepa_create_int(drv, callout, callout_ctx, board_conf, sizeof(phy_data_t));
if (!dev) {
return 0;
data = dev->data;
data->port_no = board_conf->numeric_handle;
data->events = 0;
#ifdef REG_DBG
(void) ti_reg_dump(dev);
#endif
(void) ti_init_conf(dev);
(void) ti_conf_set(dev, &data->conf);
T_I(MEPA_TRACE_GRP_GEN, "ti driver probed for port %d", data->port_no);
return dev;
static mepa_rc ti_info_get(mepa_device_t *dev, mepa_phy_info_t *const phy_info)
phy_data_t *data = (phy_data_t *)(dev->data);
phy_data_t *base_data = data->base_dev ? ((phy_data_t *)(data->base_dev->data)) : NULL;
//printf("ti_info_get\n");
phy_info->cap = 0;
phy_info->part_number = 83869;
phy_info->revision = data->dev.rev;
phy_info->cap |= MEPA_CAP_SPEED_MASK_1G;
phy_info->cap |= MEPA_CAP_TS_MASK_NONE;
phy_info->ts_base_port = base_data ? base_data->port_no : 0;
return MEPA_RC_OK;
mepa_drivers_t mepa_dp83869_driver_init()
static const int nr_ti_drivers = 1;
static mepa_driver_t ti_drivers[] = {
.id = 0x2000a0f1, // DP83869 standalone PHY
.mask = 0xfffff0,
.mepa_driver_delete = ti_delete,
.mepa_driver_reset = ti_reset,
.mepa_driver_poll = ti_poll,
.mepa_driver_conf_set = ti_conf_set,
.mepa_driver_conf_get = ti_conf_get,
.mepa_driver_if_set = ti_if_set,
.mepa_driver_if_get = ti_if_get,
//.mepa_driver_cable_diag_start = indy_cab_diag_start,
//.mepa_driver_cable_diag_get = indy_cab_diag_get,
.mepa_driver_probe = ti_probe,
.mepa_driver_aneg_status_get = ti_aneg_status_get,
.mepa_driver_clause22_read = ti_direct_reg_read,
.mepa_driver_clause22_write = ti_direct_reg_write,
.mepa_driver_clause45_read = ti_mmd_reg_read,
.mepa_driver_clause45_write = ti_mmd_reg_write,
.mepa_driver_event_enable_set = ti_event_enable_set,
.mepa_driver_event_enable_get = ti_event_enable_get,
//.mepa_driver_event_poll = ti_event_status_poll,
//.mepa_driver_loopback_set = ti_loopback_set,
//.mepa_driver_loopback_get = ti_loopback_get,
//.mepa_driver_gpio_mode_set = indy_gpio_mode_set,
//.mepa_driver_gpio_out_set = indy_gpio_out_set,
//.mepa_driver_gpio_in_get = indy_gpio_in_get,
.mepa_driver_link_base_port = ti_link_base_port,
//.mepa_ts = &indy_ts_drivers,
//.mepa_driver_synce_clock_conf_set = indy_recovered_clk_set,
.mepa_driver_phy_info_get = ti_info_get,
.mepa_driver_isolate_mode_conf = ti_isolate_mode_conf,
.mepa_debug_info_dump = ti_debug_info_dump,
mepa_drivers_t result;
result.phy_drv = ti_drivers;
result.count = nr_ti_drivers;
return result;
#include "lan8814_registers.h"
#include "lan8814_ts_registers.h"
#include "lan8814_private.h"
static mepa_rc indy_conf_set(mepa_device_t *dev, const mepa_conf_t *config);
static mepa_rc indy_qsgmii_aneg(mepa_device_t *dev, mepa_bool_t ena);
static mepa_rc indy_event_enable_set(mepa_device_t *dev, mepa_event_t event, mepa_bool_t enable);
mepa_rc indy_direct_reg_rd(mepa_device_t *dev, uint16_t addr, uint16_t *value)
return MEPA_RC_OK;
mepa_rc indy_direct_reg_wr(mepa_device_t *dev, uint16_t addr, uint16_t value, uint16_t mask)
mesa_rc rc;
if (mask != INDY_DEF_MASK) {
} else {
reg_val = value;
} else {
return MEPA_RC_OK;
// Read the value
return MEPA_RC_OK;
// write the value
return MEPA_RC_OK;
mepa_rc indy_mmd_reg_rd(mepa_device_t *dev, uint16_t mmd, uint16_t addr, uint16_t *value)
MEPA_RC(indy_direct_reg_wr(dev, INDY_MMD_ACCESS_CTRL, mmd, INDY_DEF_MASK));
MEPA_RC(indy_direct_reg_wr(dev, INDY_MMD_ACCESS_ADDR_DATA, addr, INDY_DEF_MASK));
INDY_F_MMD_ACCESS_CTRL_MMD_FUNC | mmd, INDY_DEF_MASK));
// Read the value
MEPA_RC(indy_direct_reg_rd(dev, INDY_MMD_ACCESS_ADDR_DATA, value));
return MEPA_RC_OK;
mepa_rc indy_mmd_reg_wr(mepa_device_t *dev, uint16_t mmd, uint16_t addr, uint16_t value, uint16_t mask)
// write the value
MEPA_RC(indy_direct_reg_wr(dev, INDY_MMD_ACCESS_ADDR_DATA, value, mask));
return MEPA_RC_OK;
static mepa_rc indy_delete(mepa_device_t *dev)
static mepa_rc indy_get_device_info(mepa_device_t *dev)
uint16_t id;
RD(dev, INDY_DEVICE_ID_2, &id);
data->dev.model = INDY_X_DEV_ID_MODEL(id);
data->dev.rev = INDY_X_DEV_ID_REV(id);
return MEPA_RC_OK;
static void indy_phy_deb_pr_reg (mepa_device_t *dev,
uint16_t mmd, uint16_t page, uint16_t addr,
uint16_t id = page;
if (mmd) {
id = mmd;
rc = indy_mmd_reg_rd(dev, mmd, addr, value);
} else if (page) {
rc = indy_ext_reg_rd(dev, (page-1), addr, value);
} else {
rc = indy_direct_reg_rd(dev, addr, value);
static mepa_rc indy_reg_dump(struct mepa_device *dev,
uint16_t val = 0;
uint16_t id = 0;
//Direct registers
pr("%-45s PORT_NO PAGE_ID REG_ADDR VALUE\n", "REG_NAME");
indy_phy_deb_pr_reg(dev, pr, 0, 0, 0, "Basic Control Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 1, "Basic Status Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 2, "Device Identifier 1 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 3, "Device Identifier 2 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 4, "Auto-Negotiation Advertisement Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 5, "Auto-Negotiation Link Partner Base Page Ability Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 6, "Auto-Negotiation Expansion Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 7, "Auto-Negotiation Next Page TX Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 8, "Auto-Negotiation Next Page RX Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 9, "Auto-Negotiation Master Slave Control Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 10, "Auto-Negotiation Master Slave Status Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 13, "MMD Access Control Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 14, "MMD Access Address/Data Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 15, "Extended Status Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 16, "PCS Loop-back Lane Skew Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 17, "PCS Loop-back Swap/Polarity Control Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 18, "Cable Diagnostic Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 19, "Digital PMA/PCS Status Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 20, "Digital AX/AN Status Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 21, "RXER Counter Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 22, "EP Access Control Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 23, "EP Access Address/Data Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 24, "GPHY Interrupt Enable Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 25, "GPHY Revision Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 26, "UNH Test Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 27, "GPHY Interrupt Status Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 28, "Digital Debug Control 1 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 29, "Digital Debug Control 2 Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 30, "Reserved Register", &val);
indy_phy_deb_pr_reg(dev, pr, 0, 0, 31, "Control Register", &val);
//MMD-3,7 registers
return MEPA_RC_OK;
static mepa_rc indy_debug_info_dump(struct mepa_device *dev,
//PHY Debugging
switch(info->group)
MEPA_ENTER(dev);
rc = indy_reg_dump(dev, pr);
MEPA_EXIT(dev);
break;
default:
rc = MEPA_RC_OK;
//PHY_TS Debugging
indy_ts_debug_info_dump(dev, pr, info);
return rc;
static mepa_device_t *indy_probe(mepa_driver_t *drv,
mepa_device_t *dev;
phy_data_t *data;
if (!dev) {
return 0;
data = dev->data;
data->events = 0;
#ifdef REG_DBG
(void) indy_reg_dump(dev);
#endif
T_I(MEPA_TRACE_GRP_GEN, "indy driver probed for port %d", data->port_no);
return dev;
static mepa_rc indy_init_conf(mepa_device_t *dev)
uint16_t val;
indy_get_device_info(dev);
MEPA_MSLEEP(1);
EP_WRM(dev, INDY_QSGMII_AUTO_ANEG, 0, INDY_F_QSGMII_AUTO_ANEG_AUTO_ANEG_ENA);
WR(dev, INDY_GPHY_INTR_ENA, 0);
EP_WRM(dev, INDY_PTP_TSU_INT_EN, 0, INDY_DEF_MASK);
RD(dev, INDY_GPHY_INTR_STATUS, &val);
return MEPA_RC_OK;
static void indy_qsgmii_tx_abilities(mepa_device_t *dev, mepa_port_speed_t speed, mepa_bool_t duplex)
uint16_t eee_val;
MMD_RD(dev, INDY_LINK_PARTNER_EEE_ABILITY, &eee_val);
value |= (eee_val & INDY_F_LP_EEE_ABILITY_1000_BT) ? 0x180 : 0;
if (duplex) {
return MEPA_RC_OK;
T_I(MEPA_TRACE_GRP_GEN, "qsgmii aneg ena %d", ena);
if (!ena) {
EP_WRM(dev, INDY_QSGMII_PCS1G_ANEG_CONFIG, 0, INDY_F_QSGMII_PCS1G_ANEG_CONFIG_ANEG_ENA);
} else {
// Enable QSGMII auto-negotiation.
EP_WRM(dev, INDY_QSGMII_PCS1G_ANEG_CONFIG, INDY_F_QSGMII_PCS1G_ANEG_CONFIG_ANEG_ENA, INDY_F_QSGMII_PCS1G_ANEG_CONFIG_ANEG_ENA);
return MEPA_RC_OK;
uint16_t val;
do {
break;
} while (0);
return MEPA_RC_OK;
// Rev A, B, C
// PLL trim
return MEPA_RC_OK;
return MEPA_RC_OK;
return MEPA_RC_OK;
return MEPA_RC_OK;
static mepa_rc indy_reset(mepa_device_t *dev, const mepa_reset_param_t *rst_conf)
MEPA_ENTER(dev);
indy_init_conf(dev);
indy_rev_workaround(dev);
indy_qsgmii_aneg(dev, FALSE);
WRM(dev, INDY_BASIC_CONTROL, INDY_F_BASIC_CTRL_SOFT_RESET, INDY_F_BASIC_CTRL_SOFT_RESET);
EP_WR(dev, INDY_QSGMII_SOFT_RESET, 0x1);
WRM(dev, INDY_BASIC_CONTROL, INDY_F_BASIC_CTRL_RESTART_ANEG, INDY_F_BASIC_CTRL_RESTART_ANEG);
MEPA_MSLEEP(1);
MEPA_EXIT(dev);
indy_conf_set(dev, &data->conf);
if (data->events) {
indy_event_enable_set(dev, data->events, TRUE);
return MEPA_RC_OK;
static mepa_rc indy_poll(mepa_device_t *dev, mepa_status_t *status)
MEPA_ENTER(dev);
RD(dev, INDY_BASIC_STATUS, &val);
status->link = (val & INDY_F_BASIC_STATUS_LINK_STATUS) ? 1 : 0;
status->link = 1;
// Default values
status->speed = MEPA_SPEED_UNDEFINED;
status->fdx = 1;
if (!data->loopback.near_end_ena && status->link && !(val & INDY_F_BASIC_STATUS_ANEG_COMPLETE)) {
status->link = 0;
goto end;
RD(dev, INDY_ANEG_LP_BASE, &val);
RD(dev, INDY_ANEG_MSTR_SLV_STATUS, &val2);
if ((val2 & INDY_F_ANEG_MSTR_SLV_STATUS_1000_T_FULL_DUP) &&
status->fdx = 1;
} else if ((val & INDY_F_ANEG_LP_BASE_100_X_FULL_DUP) &&
status->fdx = 1;
} else if ((val & INDY_F_ANEG_LP_BASE_100_X_HALF_DUP) &&
status->fdx = 0;
} else if ((val & INDY_F_ANEG_LP_BASE_10_T_FULL_DUP) &&
status->fdx = 1;
} else if ((val & INDY_F_ANEG_LP_BASE_10_T_HALF_DUP) &&
status->fdx = 0;
lp_sym_pause = (val & INDY_F_ANEG_LP_BASE_SYM_PAUSE) ? 1 : 0;
lp_asym_pause = (val & INDY_F_ANEG_LP_BASE_ASYM_PAUSE) ? 1 : 0;
} else {
uint8_t speed;
// Forced speed
RD(dev, INDY_BASIC_CONTROL, &val2);
speed = (!!(val2 & INDY_F_BASIC_CTRL_SPEED_SEL_BIT_0)) |
(!!(val2 & INDY_F_BASIC_CTRL_SPEED_SEL_BIT_1) << 1);
status->fdx = !!(val2 & INDY_F_BASIC_CTRL_DUP_MODE);
if (val2 & INDY_F_BASIC_CTRL_ANEG_ENA) {
end:
if (data->dev.model == 0x26 && data->conf.speed == MEPA_SPEED_AUTO &&
indy_qsgmii_tx_abilities(dev, status->speed, status->fdx);
MEPA_EXIT(dev);
return MEPA_RC_OK;
uint16_t new_value, mask, old_value;
mepa_bool_t qsgmii_aneg = config->speed != MEPA_SPEED_AUTO ? FALSE : config->mac_if_aneg_ena;
MEPA_ENTER(dev);
if (qsgmii_aneg != data->conf.mac_if_aneg_ena) {
indy_qsgmii_aneg(dev, qsgmii_aneg);
new_value = config->aneg.speed_1g_fdx ? INDY_F_ANEG_MSTR_SLV_CTRL_1000_T_FULL_DUP : 0;
mask = INDY_F_ANEG_MSTR_SLV_CTRL_1000_T_FULL_DUP;
new_value |= INDY_F_ANEG_MSTR_SLV_CTRL_CFG_ENA;
new_value |= config->man_neg == MEPA_MANUAL_NEG_REF ? INDY_F_ANEG_MSTR_SLV_CTRL_CFG_VAL : 0;
mask |= (INDY_F_ANEG_MSTR_SLV_CTRL_CFG_VAL | INDY_F_ANEG_MSTR_SLV_CTRL_CFG_ENA);
WRM(dev, INDY_ANEG_MSTR_SLV_CTRL, new_value, mask);
RD(dev, INDY_ANEG_ADVERTISEMENT, &old_value);
WR(dev, INDY_ANEG_ADVERTISEMENT, new_value);
new_value = INDY_F_BASIC_CTRL_ANEG_ENA;
WRM(dev, INDY_BASIC_CONTROL, new_value, new_value | INDY_F_BASIC_CTRL_SOFT_POW_DOWN);
if (restart_aneg) {
mask = INDY_BIT(13) | INDY_BIT(12) | INDY_BIT(8) | INDY_BIT(6) | INDY_F_BASIC_CTRL_SOFT_POW_DOWN | INDY_F_BASIC_CTRL_ANEG_ENA;
WRM(dev, INDY_BASIC_CONTROL, new_value, mask);
} else {
WRM(dev, INDY_BASIC_CONTROL, INDY_F_BASIC_CTRL_SOFT_POW_DOWN, INDY_F_BASIC_CTRL_SOFT_POW_DOWN);
data->conf.mac_if_aneg_ena = qsgmii_aneg;
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_rc indy_conf_get(mepa_device_t *dev, mepa_conf_t *const config)
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return MEPA_RC_OK;
return MEPA_RC_OK;
return MEPA_RC_OK;
static mepa_rc indy_if_set(mepa_device_t *dev,
if (mac_if != MESA_PORT_INTERFACE_QSGMII) {
return MEPA_RC_OK;
static mepa_rc indy_if_get(mepa_device_t *dev, mepa_port_speed_t speed,
MEPA_ENTER(dev);
*mac_if = MESA_PORT_INTERFACE_QSGMII;
MEPA_EXIT(dev);
return MEPA_RC_OK;
uint8_t cnt = 0;
uint16_t value;
MEPA_MSLEEP(10);
cnt++;
} else {
ret = TRUE;
break;
return ret;
MEPA_MSLEEP(1);
WR(dev, INDY_BASIC_CONTROL, 0x140);
MEPA_MSLEEP(50);
return MEPA_RC_OK;
return MEPA_RC_OK;
MEPA_ENTER(dev);
res->link = FALSE;
MEPA_EXIT(dev);
res->link = TRUE;
res->link = FALSE;
res->link = TRUE;
MEPA_EXIT(dev);
return MEPA_RC_OK;
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_rc indy_aneg_status_get(mepa_device_t *dev, mepa_aneg_status_t *status)
uint16_t val;
MEPA_ENTER(dev);
RD(dev, INDY_ANEG_MSTR_SLV_STATUS, &val);
status->master_cfg_fault = (val & INDY_F_ANEG_MSTR_SLV_STATUS_CFG_FAULT) ? TRUE : FALSE;
status->master = val & INDY_F_ANEG_MSTR_SLV_STATUS_CFG_RES ? TRUE : FALSE;
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_rc indy_direct_reg_read(mepa_device_t *dev, uint32_t address, uint16_t *const value)
mepa_rc rc;
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return rc;
static mepa_rc indy_direct_reg_write(mepa_device_t *dev, uint32_t address, uint16_t value)
mepa_rc rc;
MEPA_ENTER(dev);
rc = indy_direct_reg_wr(dev, addr, value, 0xFFFF);
MEPA_EXIT(dev);
return rc;
static mepa_rc indy_ext_mmd_reg_read(mepa_device_t *dev, uint32_t address, uint16_t *const value)
mepa_rc rc;
MEPA_ENTER(dev);
if (mmd) {
} else {
MEPA_EXIT(dev);
return rc;
static mepa_rc indy_ext_mmd_reg_write(mepa_device_t *dev, uint32_t address, uint16_t value)
mepa_rc rc;
MEPA_ENTER(dev);
if (mmd) {
rc = indy_mmd_reg_wr(dev, mmd, addr, value, 0xFFFF);
} else {
MEPA_EXIT(dev);
return rc;
// Enable events
MEPA_ENTER(dev);
case MEPA_LINK_LOS:
ev_mask = ev_mask | INDY_F_GPHY_INTR_ENA_LINK_DOWN;
break;
break;
default:
break;
WRM(dev, INDY_GPHY_INTR_ENA, enable ? ev_mask : 0, ev_mask);
MEPA_EXIT(dev);
return rc;
static mepa_rc indy_event_enable_get(mepa_device_t *dev, mepa_event_t *const event)
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return rc;
static mepa_rc indy_event_status_poll(mepa_device_t *dev, mepa_event_t *const status)
uint16_t val;
*status = 0;
MEPA_ENTER(dev);
rc = RD(dev, INDY_GPHY_INTR_STATUS, &val);
if (val & INDY_F_GPHY_INTR_ENA_LINK_DOWN) {
MEPA_EXIT(dev);
return rc;
static mepa_rc indy_loopback_set(mepa_device_t *dev, const mepa_loopback_t *loopback)
MEPA_ENTER(dev);
// Far end loopback
if (loopback->far_end_ena == TRUE) {
WRM(dev, INDY_PCS_LOOP_POLARITY_CTRL, INDY_F_PCS_LOOP_CTRL_PORT_LOOP,
INDY_F_PCS_LOOP_CTRL_PORT_LOOP);
} else if (data->loopback.far_end_ena == TRUE) {
WRM(dev, INDY_PCS_LOOP_POLARITY_CTRL, 0, INDY_F_PCS_LOOP_CTRL_PORT_LOOP);
WRM(dev, INDY_BASIC_CONTROL, INDY_F_BASIC_CTRL_LOOPBACK, INDY_F_BASIC_CTRL_LOOPBACK);
WRM(dev, INDY_BASIC_CONTROL, 0, INDY_F_BASIC_CTRL_ANEG_ENA);
WRM(dev, INDY_BASIC_CONTROL, INDY_F_BASIC_CTRL_SPEED_SEL_BIT_1, INDY_F_BASIC_CTRL_SPEED_SEL_BIT_1 | INDY_F_BASIC_CTRL_SPEED_SEL_BIT_0);
WRM(dev, INDY_BASIC_CONTROL, 0, INDY_F_BASIC_CTRL_LOOPBACK);
WRM(dev, INDY_ANEG_MSTR_SLV_CTRL, 0, INDY_F_ANEG_MSTR_SLV_CTRL_CFG_ENA |
INDY_F_ANEG_MSTR_SLV_CTRL_CFG_VAL);
// Enable aneg
WRM(dev, INDY_BASIC_CONTROL, INDY_F_BASIC_CTRL_ANEG_ENA | INDY_F_BASIC_CTRL_RESTART_ANEG,
INDY_F_BASIC_CTRL_ANEG_ENA | INDY_F_BASIC_CTRL_RESTART_ANEG);
if (data->dev.rev <= 1) {
EP_WR(dev, INDY_POWER_MGMT_MODE_11, 0x4377);
if (loopback->connector_ena == TRUE) {
WR(dev, INDY_RESV_CON_LOOP, 0xfc08);
} else if (data->loopback.connector_ena == TRUE) {
WR(dev, INDY_RESV_CON_LOOP, 0xfc00);
if (loopback->qsgmii_pcs_tbi_ena == TRUE) { // Enable tbi loopback
EP_WRM(dev, INDY_QSGMII_PCS1G_DEBUG, INDY_F_QSGMII_PCS1G_DBG_TBI_HOST_LOOPBACK,
INDY_F_QSGMII_PCS1G_DBG_TBI_HOST_LOOPBACK);
} else if (data->loopback.qsgmii_pcs_tbi_ena == TRUE) { // Disable tbi loopback
EP_WRM(dev, INDY_QSGMII_PCS1G_DEBUG, 0, INDY_F_QSGMII_PCS1G_DBG_TBI_HOST_LOOPBACK);
if (loopback->qsgmii_pcs_gmii_ena == TRUE) { // Enable gmii loopback
EP_WRM(dev, INDY_QSGMII_PCS1G_DEBUG, INDY_F_QSGMII_PCS1G_DBG_GMII_LOOPBACK,
INDY_F_QSGMII_PCS1G_DBG_GMII_LOOPBACK);
} else if (data->loopback.qsgmii_pcs_gmii_ena == TRUE) { // Disable gmii loopback
EP_WRM(dev, INDY_QSGMII_PCS1G_DEBUG, 0, INDY_F_QSGMII_PCS1G_DBG_GMII_LOOPBACK);
if (loopback->qsgmii_serdes_ena == TRUE) { // Enable qsgmii serdes loopback.
// Serdes configuration would affect all the 4 ports.
EP_WRM(dev, INDY_QSGMII_SERDES_MISC_CTRL, INDY_F_QSGMII_SERDES_MISC_CTRL_LB_MODE,
INDY_F_QSGMII_SERDES_MISC_CTRL_LB_MODE);
} else if (data->loopback.qsgmii_serdes_ena == TRUE) {
EP_WRM(dev, INDY_QSGMII_SERDES_MISC_CTRL, 0, INDY_F_QSGMII_SERDES_MISC_CTRL_LB_MODE);
MEPA_EXIT(dev);
return MEPA_RC_OK;
mepa_rc indy_loopback_get(struct mepa_device *dev, mepa_loopback_t *const loopback)
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return MEPA_RC_OK;
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
// invalid.
break;
return gpio;
uint8_t ret = 0;
switch (mode) {
ret = 0;
break;
ret = 1;
break;
ret = 2;
break;
ret = 3;
break;
ret = 4;
break;
ret = 5;
break;
ret = 6;
break;
ret = 8;
break;
ret = 9;
break;
ret = 10;
break;
ret = 12;
break;
ret = 14;
break;
ret = 15;
break;
ret = 0xf0;
break;
default:
break;
return ret;
uint16_t mode;
// Normal operation
return MEPA_RC_OK;
gpio_en = 1;
if (gpio_no < 16) {
val = 1 << gpio_no;
if (gpio_en) {
if (gpio_en) {
} else {
return MEPA_RC_OK;
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return rc;
// Set Isolate mode
static mepa_rc indy_isolate_mode_conf(mepa_device_t *dev, const mepa_bool_t iso_en)
MEPA_ENTER(dev);
WRM(dev, INDY_BASIC_CONTROL, INDY_F_BASIC_CTRL_ISO_MODE_EN, INDY_F_BASIC_CTRL_ISO_MODE_EN);
} else {
WRM(dev, INDY_BASIC_CONTROL, 0, INDY_F_BASIC_CTRL_ISO_MODE_EN);
MEPA_EXIT(dev);
return MEPA_RC_OK;
uint16_t val = 0;
if (gpio_no > 23) {
MEPA_ENTER(dev);
if (gpio_no < 16) {
val = 1 << gpio_no;
} else {
MEPA_EXIT(dev);
return MEPA_RC_OK;
uint16_t val = 0;
if (gpio_no > 23) {
MEPA_ENTER(dev);
if (gpio_no < 16) {
MEPA_EXIT(dev);
return MEPA_RC_OK;
MEPA_ENTER(dev);
case MEPA_FREQ_25M:
break;
break;
default:
break;
break;
break;
break;
break;
default:
break;
MEPA_EXIT(dev);
return rc;
static mepa_rc indy_link_base_port(mepa_device_t *dev, mepa_device_t *base_dev, uint8_t packet_idx)
MEPA_ENTER(dev);
MEPA_EXIT(dev);
return MEPA_RC_OK;
static mepa_rc indy_info_get(mepa_device_t *dev, mepa_phy_info_t *const phy_info)
phy_info->cap = 0;
phy_info->part_number = 8814;
phy_info->cap |= (data->dev.model == 0x26) ? MEPA_CAP_TS_MASK_GEN_3 : MEPA_CAP_TS_MASK_NONE;
return MEPA_RC_OK;
mepa_drivers_t mepa_lan8814_driver_init()
static const int nr_indy_drivers = 2;
static mepa_driver_t indy_drivers[] = {
.id = 0x221660, // LAN8814 QSGMII standalone PHY
.mask = 0xfffff0,
.mepa_driver_delete = indy_delete,
.mepa_driver_reset = indy_reset,
.mepa_driver_poll = indy_poll,
.mepa_driver_conf_set = indy_conf_set,
.mepa_driver_conf_get = indy_conf_get,
.mepa_driver_if_set = indy_if_set,
.mepa_driver_if_get = indy_if_get,
.mepa_driver_probe = indy_probe,
.mepa_driver_aneg_status_get = indy_aneg_status_get,
.mepa_driver_clause22_read = indy_direct_reg_read,
.mepa_driver_clause22_write = indy_direct_reg_write,
.mepa_driver_clause45_read = indy_ext_mmd_reg_read,
.mepa_driver_clause45_write = indy_ext_mmd_reg_write,
.mepa_driver_event_enable_set = indy_event_enable_set,
.mepa_driver_event_enable_get = indy_event_enable_get,
.mepa_driver_event_poll = indy_event_status_poll,
.mepa_driver_loopback_set = indy_loopback_set,
.mepa_driver_loopback_get = indy_loopback_get,
.mepa_driver_link_base_port = indy_link_base_port,
.mepa_driver_phy_info_get = indy_info_get,
.mepa_driver_isolate_mode_conf = indy_isolate_mode_conf,
.mepa_debug_info_dump = indy_debug_info_dump,
.id = 0x221670, // Single PHY based on LAN8814 instantiated in LAN966x
.mask = 0xfffff0,
.mepa_driver_if_set = mas_if_set,
.mepa_driver_if_get = mas_if_get,
result.phy_drv = indy_drivers;
result.count = nr_indy_drivers;
return result;
