Other Parts Discussed in Thread: TCA9535
HI
In order to hardware reset the PCA9535 registers to default state we are looking to cycle its VCC supply voltage pin resulting in a POR.
Given that all I/O pins will default to high impedance "inputs" is it OK that some of these inputs may be driven by VCC levels whilst the the supply voltage pin is
being cycled from VCC to GND to VCC.
Similarly the I2C interface signals, the address pins and the INT# output pins will/may be pulled to VCC via resistors whilst the supply pin cycling is occurring.
Can you see any issue with doing this?
Finbarr
