Part Number: TCAN4550
Can you please help me check if there are any drivers for the Android platform? Currently, there are significant differences in the code and I am very anxious to obtain drivers for the Android platform
Tony,
The C drivers are available in the product folder on TI.com, as well as a software guide that will enable the user to understand the registers required for normal operation. The datasheet has the complete description of the power on/off timing.
The Linux drivers are community-managed, and can be found utilized through that Linux CAN community.
Eric Hackett
安卓的驱动能不能参考其他家的IC代码修改一下,只改寄存器相关的内容?我这边自己写太耗时间了,因为对IC的寄存器配置部分也不太熟悉。需要原厂处理IC的部分,我这边只处理平台部分.下面发的驱动也是安卓自带别家的IC的驱动,也是SPI的.
/* CAN bus driver for Holt HI3110 CAN Controller with SPI Interface
* Copyright(C) Timesys Corporation 2016
* Based on Microchip 251x CAN Controller (mcp251x) Linux kernel driver
* Copyright 2009 Christian Pellegrin EVOL S.r.l.
* Copyright 2007 Raymarine UK, Ltd. All Rights Reserved.
* Copyright 2006 Arcom Control Systems Ltd.
* Based on CAN bus driver for the CCAN controller written by
* - Sascha Hauer, Marc Kleine-Budde, Pengutronix
* - Simon Kallweit, intefo AG
* Copyright 2007
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include <linux/can/core.h>
#include <linux/can/dev.h>
#include <linux/can/led.h>
#include <linux/clk.h>
#include <linux/completion.h>
#include <linux/delay.h>
#include <linux/device.h>
#include <linux/dma-mapping.h>
#include <linux/freezer.h>
#include <linux/interrupt.h>
#include <linux/io.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/netdevice.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/platform_device.h>
#include <linux/regulator/consumer.h>
#include <linux/slab.h>
#include <linux/spi/spi.h>
#include <linux/uaccess.h>
#define HI3110_MASTER_RESET 0x56
#define HI3110_READ_CTRL0 0xD2
#define HI3110_READ_CTRL1 0xD4
#define HI3110_READ_STATF 0xE2
#define HI3110_WRITE_CTRL0 0x14
#define HI3110_WRITE_CTRL1 0x16
#define HI3110_WRITE_INTE 0x1C
#define HI3110_WRITE_BTR0 0x18
#define HI3110_WRITE_BTR1 0x1A
#define HI3110_READ_BTR0 0xD6
#define HI3110_READ_BTR1 0xD8
#define HI3110_READ_INTF 0xDE
#define HI3110_READ_ERR 0xDC
#define HI3110_READ_FIFO_WOTIME 0x48
#define HI3110_WRITE_FIFO 0x12
#define HI3110_READ_MESSTAT 0xDA
#define HI3110_READ_REC 0xEA
#define HI3110_READ_TEC 0xEC
#define HI3110_CTRL0_MODE_MASK (7 << 5)
#define HI3110_CTRL0_NORMAL_MODE (0 << 5)
#define HI3110_CTRL0_LOOPBACK_MODE (1 << 5)
#define HI3110_CTRL0_MONITOR_MODE (2 << 5)
#define HI3110_CTRL0_SLEEP_MODE (3 << 5)
#define HI3110_CTRL0_INIT_MODE (4 << 5)
#define HI3110_CTRL1_TXEN BIT(7)
#define HI3110_INT_RXTMP BIT(7)
#define HI3110_INT_RXFIFO BIT(6)
#define HI3110_INT_TXCPLT BIT(5)
#define HI3110_INT_BUSERR BIT(4)
#define HI3110_INT_MCHG BIT(3)
#define HI3110_INT_WAKEUP BIT(2)
#define HI3110_INT_F1MESS BIT(1)
#define HI3110_INT_F0MESS BIT(0)
#define HI3110_ERR_BUSOFF BIT(7)
#define HI3110_ERR_TXERRP BIT(6)
#define HI3110_ERR_RXERRP BIT(5)
#define HI3110_ERR_BITERR BIT(4)
#define HI3110_ERR_FRMERR BIT(3)
#define HI3110_ERR_CRCERR BIT(2)
#define HI3110_ERR_ACKERR BIT(1)
#define HI3110_ERR_STUFERR BIT(0)
#define HI3110_ERR_PROTOCOL_MASK (0x1F)
#define HI3110_ERR_PASSIVE_MASK (0x60)
#define HI3110_STAT_RXFMTY BIT(1)
#define HI3110_STAT_BUSOFF BIT(2)
#define HI3110_STAT_ERRP BIT(3)
#define HI3110_STAT_ERRW BIT(4)
#define HI3110_STAT_TXMTY BIT(7)
#define HI3110_BTR0_SJW_SHIFT 6
#define HI3110_BTR0_BRP_SHIFT 0
#define HI3110_BTR1_SAMP_3PERBIT (1 << 7)
#define HI3110_BTR1_SAMP_1PERBIT (0 << 7)
#define HI3110_BTR1_TSEG2_SHIFT 4
#define HI3110_BTR1_TSEG1_SHIFT 0
#define HI3110_FIFO_WOTIME_TAG_OFF 0
#define HI3110_FIFO_WOTIME_ID_OFF 1
#define HI3110_FIFO_WOTIME_DLC_OFF 5
#define HI3110_FIFO_WOTIME_DAT_OFF 6
#define HI3110_FIFO_WOTIME_TAG_IDE BIT(7)
#define HI3110_FIFO_WOTIME_ID_RTR BIT(0)
#define HI3110_FIFO_TAG_OFF 0
#define HI3110_FIFO_ID_OFF 1
#define HI3110_FIFO_STD_DLC_OFF 3
#define HI3110_FIFO_STD_DATA_OFF 4
#define HI3110_FIFO_EXT_DLC_OFF 5
#define HI3110_FIFO_EXT_DATA_OFF 6
#define HI3110_CAN_MAX_DATA_LEN 8
#define HI3110_RX_BUF_LEN 15
#define HI3110_TX_STD_BUF_LEN 12
#define HI3110_TX_EXT_BUF_LEN 14
#define HI3110_CAN_FRAME_MAX_BITS 128
#define HI3110_EFF_FLAGS 0x18 /* IDE + SRR */
#define HI3110_TX_ECHO_SKB_MAX 1
#define HI3110_OST_DELAY_MS (10)
#define DEVICE_NAME "hi3110"
static int hi3110_enable_dma = 1; /* Enable SPI DMA. Default: 1 (On) */
module_param(hi3110_enable_dma, int, 0444);
MODULE_PARM_DESC(hi3110_enable_dma, "Enable SPI DMA. Default: 1 (On)");
static const struct can_bittiming_const hi3110_bittiming_const = {
.name = DEVICE_NAME,
.tseg1_min = 2,
.tseg1_max = 16,
.tseg2_min = 2,
.tseg2_max = 8,
.sjw_max = 4,
.brp_min = 1,
.brp_max = 64,
.brp_inc = 1,
enum hi3110_model {
CAN_HI3110_HI3110 = 0x3110,
struct hi3110_priv {
struct can_priv can;
struct net_device *net;
struct spi_device *spi;
enum hi3110_model model;
struct mutex hi3110_lock; /* SPI device lock */
u8 *spi_tx_buf;
u8 *spi_rx_buf;
dma_addr_t spi_tx_dma;
dma_addr_t spi_rx_dma;
struct sk_buff *tx_skb;
int tx_len;
struct workqueue_struct *wq;
struct work_struct tx_work;
struct work_struct restart_work;
int force_quit;
int after_suspend;
#define HI3110_AFTER_SUSPEND_UP 1
#define HI3110_AFTER_SUSPEND_DOWN 2
#define HI3110_AFTER_SUSPEND_POWER 4
#define HI3110_AFTER_SUSPEND_RESTART 8
int restart_tx;
struct regulator *power;
struct regulator *transceiver;
struct clk *clk;
static void hi3110_clean(struct net_device *net)
struct hi3110_priv *priv = netdev_priv(net);
if (priv->tx_skb || priv->tx_len)
net->stats.tx_errors++;
if (priv->tx_skb)
dev_kfree_skb(priv->tx_skb);
if (priv->tx_len)
can_free_echo_skb(priv->net, 0);
priv->tx_skb = NULL;
priv->tx_len = 0;
/* Note about handling of error return of hi3110_spi_trans: accessing
* registers via SPI is not really different conceptually than using
* normal I/O assembler instructions, although it's much more
* complicated from a practical POV. So it's not advisable to always
* check the return value of this function. Imagine that every
* read{b,l}, write{b,l} and friends would be bracketed in "if ( < 0)
* error();", it would be a great mess (well there are some situation
* when exception handling C++ like could be useful after all). So we
* just check that transfers are OK at the beginning of our
* conversation with the chip and to avoid doing really nasty things
* (like injecting bogus packets in the network stack).
static int hi3110_spi_trans(struct spi_device *spi, int len)
struct hi3110_priv *priv = spi_get_drvdata(spi);
struct spi_transfer t = {
.tx_buf = priv->spi_tx_buf,
.rx_buf = priv->spi_rx_buf,
.len = len,
.cs_change = 0,
struct spi_message m;
int ret;
spi_message_init(&m);
if (hi3110_enable_dma) {
t.tx_dma = priv->spi_tx_dma;
t.rx_dma = priv->spi_rx_dma;
m.is_dma_mapped = 1;
spi_message_add_tail(&t, &m);
ret = spi_sync(spi, &m);
if (ret)
dev_err(&spi->dev, "spi transfer failed: ret = %d\n", ret);
return ret;
static u8 hi3110_cmd(struct spi_device *spi, u8 command)
priv->spi_tx_buf[0] = command;
dev_dbg(&spi->dev, "hi3110_cmd: %02X\n", command);
return hi3110_spi_trans(spi, 1);
static u8 hi3110_read(struct spi_device *spi, u8 command)
u8 val = 0;
hi3110_spi_trans(spi, 2);
val = priv->spi_rx_buf[1];
return val;
static void hi3110_write(struct spi_device *spi, u8 reg, u8 val)
priv->spi_tx_buf[0] = reg;
priv->spi_tx_buf[1] = val;
static void hi3110_hw_tx_frame(struct spi_device *spi, u8 *buf, int len)
priv->spi_tx_buf[0] = HI3110_WRITE_FIFO;
memcpy(priv->spi_tx_buf + 1, buf, len);
hi3110_spi_trans(spi, len + 1);
static void hi3110_hw_tx(struct spi_device *spi, struct can_frame *frame)
u8 buf[HI3110_TX_EXT_BUF_LEN];
buf[HI3110_FIFO_TAG_OFF] = 0;
if (frame->can_id & CAN_EFF_FLAG) {
/* Extended frame */
buf[HI3110_FIFO_ID_OFF] = (frame->can_id & CAN_EFF_MASK) >> 21;
buf[HI3110_FIFO_ID_OFF + 1] =
(((frame->can_id & CAN_EFF_MASK) >> 13) & 0xe0) |
HI3110_EFF_FLAGS |
(((frame->can_id & CAN_EFF_MASK) >> 15) & 0x07);
buf[HI3110_FIFO_ID_OFF + 2] =
(frame->can_id & CAN_EFF_MASK) >> 7;
buf[HI3110_FIFO_ID_OFF + 3] =
((frame->can_id & CAN_EFF_MASK) << 1) |
((frame->can_id & CAN_RTR_FLAG) ? 1 : 0);
buf[HI3110_FIFO_EXT_DLC_OFF] = frame->can_dlc;
memcpy(buf + HI3110_FIFO_EXT_DATA_OFF,
frame->data, frame->can_dlc);
hi3110_hw_tx_frame(spi, buf, HI3110_TX_EXT_BUF_LEN -
(HI3110_CAN_MAX_DATA_LEN - frame->can_dlc));
} else {
/* Standard frame */
buf[HI3110_FIFO_ID_OFF] = (frame->can_id & CAN_SFF_MASK) >> 3;
((frame->can_id & CAN_SFF_MASK) << 5) |
((frame->can_id & CAN_RTR_FLAG) ? (1 << 4) : 0);
buf[HI3110_FIFO_STD_DLC_OFF] = frame->can_dlc;
memcpy(buf + HI3110_FIFO_STD_DATA_OFF,
hi3110_hw_tx_frame(spi, buf, HI3110_TX_STD_BUF_LEN -
static void hi3110_hw_rx_frame(struct spi_device *spi, u8 *buf)
priv->spi_tx_buf[0] = HI3110_READ_FIFO_WOTIME;
hi3110_spi_trans(spi, HI3110_RX_BUF_LEN);
memcpy(buf, priv->spi_rx_buf + 1, HI3110_RX_BUF_LEN - 1);
static void hi3110_hw_rx(struct spi_device *spi)
struct sk_buff *skb;
struct can_frame *frame;
u8 buf[HI3110_RX_BUF_LEN - 1];
skb = alloc_can_skb(priv->net, &frame);
if (!skb) {
priv->net->stats.rx_dropped++;
return;
hi3110_hw_rx_frame(spi, buf);
if (buf[HI3110_FIFO_WOTIME_TAG_OFF] & HI3110_FIFO_WOTIME_TAG_IDE) {
/* IDE is recessive (1), indicating extended 29-bit frame */
frame->can_id = CAN_EFF_FLAG;
frame->can_id |=
(buf[HI3110_FIFO_WOTIME_ID_OFF] << 21) |
(((buf[HI3110_FIFO_WOTIME_ID_OFF + 1] & 0xE0) >> 5) << 18) |
((buf[HI3110_FIFO_WOTIME_ID_OFF + 1] & 0x07) << 15) |
(buf[HI3110_FIFO_WOTIME_ID_OFF + 2] << 7) |
(buf[HI3110_FIFO_WOTIME_ID_OFF + 3] >> 1);
} else {
/* IDE is dominant (0), frame indicating standard 11-bit */
frame->can_id =
(buf[HI3110_FIFO_WOTIME_ID_OFF] << 3) |
((buf[HI3110_FIFO_WOTIME_ID_OFF + 1] & 0xE0) >> 5);
/* Data length */
frame->can_dlc = get_can_dlc(buf[HI3110_FIFO_WOTIME_DLC_OFF] & 0x0F);
if (buf[HI3110_FIFO_WOTIME_ID_OFF + 3] & HI3110_FIFO_WOTIME_ID_RTR)
frame->can_id |= CAN_RTR_FLAG;
else
memcpy(frame->data, buf + HI3110_FIFO_WOTIME_DAT_OFF,
frame->can_dlc);
priv->net->stats.rx_packets++;
priv->net->stats.rx_bytes += frame->can_dlc;
can_led_event(priv->net, CAN_LED_EVENT_RX);
netif_rx_ni(skb);
static void hi3110_hw_sleep(struct spi_device *spi)
hi3110_write(spi, HI3110_WRITE_CTRL0, HI3110_CTRL0_SLEEP_MODE);
static netdev_tx_t hi3110_hard_start_xmit(struct sk_buff *skb,
struct spi_device *spi = priv->spi;
if (priv->tx_skb || priv->tx_len) {
dev_err(&spi->dev, "hard_xmit called while tx busy\n");
return NETDEV_TX_BUSY;
if (can_dropped_invalid_skb(net, skb))
return NETDEV_TX_OK;
netif_stop_queue(net);
priv->tx_skb = skb;
queue_work(priv->wq, &priv->tx_work);
static int hi3110_do_set_mode(struct net_device *net, enum can_mode mode)
switch (mode) {
case CAN_MODE_START:
hi3110_clean(net);
/* We have to delay work since SPI I/O may sleep */
priv->can.state = CAN_STATE_ERROR_ACTIVE;
priv->restart_tx = 1;
if (priv->can.restart_ms == 0)
priv->after_suspend = HI3110_AFTER_SUSPEND_RESTART;
queue_work(priv->wq, &priv->restart_work);
break;
default:
return -EOPNOTSUPP;
return 0;
static int hi3110_get_berr_counter(const struct net_device *net,
struct can_berr_counter *bec)
mutex_lock(&priv->hi3110_lock);
bec->txerr = hi3110_read(spi, HI3110_READ_TEC);
bec->rxerr = hi3110_read(spi, HI3110_READ_REC);
mutex_unlock(&priv->hi3110_lock);
return 0;
static int hi3110_set_normal_mode(struct spi_device *spi)
u8 reg = 0;
hi3110_write(spi, HI3110_WRITE_INTE, HI3110_INT_BUSERR |
HI3110_INT_RXFIFO | HI3110_INT_TXCPLT);
/* Enable TX */
hi3110_write(spi, HI3110_WRITE_CTRL1, HI3110_CTRL1_TXEN);
if (priv->can.ctrlmode & CAN_CTRLMODE_LOOPBACK)
reg = HI3110_CTRL0_LOOPBACK_MODE;
else if (priv->can.ctrlmode & CAN_CTRLMODE_LISTENONLY)
reg = HI3110_CTRL0_MONITOR_MODE;
else
reg = HI3110_CTRL0_NORMAL_MODE;
hi3110_write(spi, HI3110_WRITE_CTRL0, reg);
/* Wait for the device to enter the mode */
mdelay(HI3110_OST_DELAY_MS);
reg = hi3110_read(spi, HI3110_READ_CTRL0);
if ((reg & HI3110_CTRL0_MODE_MASK) != reg)
return -EBUSY;
return 0;
static int hi3110_do_set_bittiming(struct net_device *net)
struct can_bittiming *bt = &priv->can.bittiming;
hi3110_write(spi, HI3110_WRITE_BTR0,
((bt->sjw - 1) << HI3110_BTR0_SJW_SHIFT) |
((bt->brp - 1) << HI3110_BTR0_BRP_SHIFT));
hi3110_write(spi, HI3110_WRITE_BTR1,
CAN_CTRLMODE_3_SAMPLES ?
HI3110_BTR1_SAMP_3PERBIT : HI3110_BTR1_SAMP_1PERBIT) |
((bt->phase_seg1 + bt->prop_seg - 1)
<< HI3110_BTR1_TSEG1_SHIFT) |
((bt->phase_seg2 - 1) << HI3110_BTR1_TSEG2_SHIFT));
dev_dbg(&spi->dev, "BT: 0x%02x 0x%02x\n",
hi3110_read(spi, HI3110_READ_BTR0),
hi3110_read(spi, HI3110_READ_BTR1));
return 0;
static int hi3110_setup(struct net_device *net)
hi3110_do_set_bittiming(net);
return 0;
static int hi3110_hw_reset(struct spi_device *spi)
u8 reg;
int ret;
/* Wait for oscillator startup timer after power up */
ret = hi3110_cmd(spi, HI3110_MASTER_RESET);
if (ret)
return ret;
/* Wait for oscillator startup timer after reset */
if ((reg & HI3110_CTRL0_MODE_MASK) != HI3110_CTRL0_INIT_MODE)
return -ENODEV;
/* As per the datasheet it appears the error flags are
* not cleared on reset. Explicitly clear them by performing a read
hi3110_read(spi, HI3110_READ_ERR);
return 0;
static int hi3110_hw_probe(struct spi_device *spi)
u8 statf;
hi3110_hw_reset(spi);
/* Confirm correct operation by checking against reset values
* in datasheet
statf = hi3110_read(spi, HI3110_READ_STATF);
dev_dbg(&spi->dev, "statf: %02X\n", statf);
if (statf != 0x82)
return -ENODEV;
return 0;
static int hi3110_power_enable(struct regulator *reg, int enable)
if (IS_ERR_OR_NULL(reg))
return 0;
if (enable)
return regulator_enable(reg);
else
return regulator_disable(reg);
static int hi3110_stop(struct net_device *net)
close_candev(net);
priv->force_quit = 1;
free_irq(spi->irq, priv);
destroy_workqueue(priv->wq);
priv->wq = NULL;
/* Disable transmit, interrupts and clear flags */
hi3110_write(spi, HI3110_WRITE_CTRL1, 0x0);
hi3110_write(spi, HI3110_WRITE_INTE, 0x0);
hi3110_read(spi, HI3110_READ_INTF);
hi3110_clean(net);
hi3110_hw_sleep(spi);
hi3110_power_enable(priv->transceiver, 0);
priv->can.state = CAN_STATE_STOPPED;
can_led_event(net, CAN_LED_EVENT_STOP);
return 0;
static void hi3110_tx_work_handler(struct work_struct *ws)
struct hi3110_priv *priv = container_of(ws, struct hi3110_priv,
tx_work);
struct net_device *net = priv->net;
if (priv->tx_skb) {
if (priv->can.state == CAN_STATE_BUS_OFF) {
hi3110_clean(net);
} else {
frame = (struct can_frame *)priv->tx_skb->data;
hi3110_hw_tx(spi, frame);
priv->tx_len = 1 + frame->can_dlc;
can_put_echo_skb(priv->tx_skb, net, 0);
static void hi3110_restart_work_handler(struct work_struct *ws)
restart_work);
if (priv->after_suspend) {
hi3110_setup(net);
if (priv->after_suspend & HI3110_AFTER_SUSPEND_RESTART) {
hi3110_set_normal_mode(spi);
} else if (priv->after_suspend & HI3110_AFTER_SUSPEND_UP) {
netif_device_attach(net);
hi3110_clean(net);
netif_wake_queue(net);
} else {
priv->after_suspend = 0;
priv->force_quit = 0;
if (priv->restart_tx) {
priv->restart_tx = 0;
hi3110_setup(net);
hi3110_clean(net);
static irqreturn_t hi3110_can_ist(int irq, void *dev_id)
struct hi3110_priv *priv = dev_id;
while (!priv->force_quit) {
enum can_state new_state;
u8 intf, eflag, statf;
while (!(HI3110_STAT_RXFMTY &
(statf = hi3110_read(spi, HI3110_READ_STATF)))) {
hi3110_hw_rx(spi);
intf = hi3110_read(spi, HI3110_READ_INTF);
eflag = hi3110_read(spi, HI3110_READ_ERR);
/* Update can state */
if (eflag & HI3110_ERR_BUSOFF)
new_state = CAN_STATE_BUS_OFF;
else if (eflag & HI3110_ERR_PASSIVE_MASK)
new_state = CAN_STATE_ERROR_PASSIVE;
else if (statf & HI3110_STAT_ERRW)
new_state = CAN_STATE_ERROR_WARNING;
else
new_state = CAN_STATE_ERROR_ACTIVE;
if (new_state != priv->can.state) {
struct can_frame *cf;
enum can_state rx_state, tx_state;
u8 rxerr, txerr;
skb = alloc_can_err_skb(net, &cf);
if (!skb)
break;
cf->data[6] = txerr;
cf->data[7] = rxerr;
tx_state = txerr >= rxerr ? new_state : 0;
rx_state = txerr <= rxerr ? new_state : 0;
can_change_state(net, cf, tx_state, rx_state);
netif_rx_ni(skb);
if (new_state == CAN_STATE_BUS_OFF) {
can_bus_off(net);
if (priv->can.restart_ms == 0) {
break;
/* Update bus errors */
if ((intf & HI3110_INT_BUSERR) &&
(priv->can.ctrlmode & CAN_CTRLMODE_BERR_REPORTING)) {
/* Check for protocol errors */
if (eflag & HI3110_ERR_PROTOCOL_MASK) {
if (!skb)
break;
cf->can_id |= CAN_ERR_PROT | CAN_ERR_BUSERROR;
priv->can.can_stats.bus_error++;
priv->net->stats.rx_errors++;
if (eflag & HI3110_ERR_BITERR)
cf->data[2] |= CAN_ERR_PROT_BIT;
else if (eflag & HI3110_ERR_FRMERR)
cf->data[2] |= CAN_ERR_PROT_FORM;
else if (eflag & HI3110_ERR_STUFERR)
cf->data[2] |= CAN_ERR_PROT_STUFF;
else if (eflag & HI3110_ERR_CRCERR)
cf->data[3] |= CAN_ERR_PROT_LOC_CRC_SEQ;
else if (eflag & HI3110_ERR_ACKERR)
cf->data[3] |= CAN_ERR_PROT_LOC_ACK;
cf->data[6] = hi3110_read(spi, HI3110_READ_TEC);
cf->data[7] = hi3110_read(spi, HI3110_READ_REC);
netdev_dbg(priv->net, "Bus Error\n");
netif_rx_ni(skb);
if (priv->tx_len && statf & HI3110_STAT_TXMTY) {
net->stats.tx_packets++;
net->stats.tx_bytes += priv->tx_len - 1;
can_led_event(net, CAN_LED_EVENT_TX);
if (priv->tx_len) {
can_get_echo_skb(net, 0);
priv->tx_len = 0;
if (intf == 0)
break;
return IRQ_HANDLED;
static int hi3110_open(struct net_device *net)
unsigned long flags = IRQF_ONESHOT | IRQF_TRIGGER_HIGH;
int ret;
ret = open_candev(net);
if (ret)
return ret;
hi3110_power_enable(priv->transceiver, 1);
priv->tx_len = 0;
ret = request_threaded_irq(spi->irq, NULL, hi3110_can_ist,
flags, DEVICE_NAME, priv);
if (ret) {
dev_err(&spi->dev, "failed to acquire irq %d\n", spi->irq);
goto out_close;
priv->wq = alloc_workqueue("hi3110_wq", WQ_FREEZABLE | WQ_MEM_RECLAIM,
0);
if (!priv->wq) {
ret = -ENOMEM;
goto out_free_irq;
INIT_WORK(&priv->tx_work, hi3110_tx_work_handler);
INIT_WORK(&priv->restart_work, hi3110_restart_work_handler);
ret = hi3110_hw_reset(spi);
if (ret)
goto out_free_wq;
ret = hi3110_setup(net);
if (ret)
goto out_free_wq;
ret = hi3110_set_normal_mode(spi);
if (ret)
goto out_free_wq;
can_led_event(net, CAN_LED_EVENT_OPEN);
return 0;
out_free_wq:
out_free_irq:
out_close:
close_candev(net);
return ret;
static const struct net_device_ops hi3110_netdev_ops = {
.ndo_open = hi3110_open,
.ndo_stop = hi3110_stop,
.ndo_start_xmit = hi3110_hard_start_xmit,
static const struct of_device_id hi3110_of_match[] = {
.compatible = "holt,hi3110",
.data = (void *)CAN_HI3110_HI3110,
MODULE_DEVICE_TABLE(of, hi3110_of_match);
static const struct spi_device_id hi3110_id_table[] = {
.name = "hi3110",
.driver_data = (kernel_ulong_t)CAN_HI3110_HI3110,
MODULE_DEVICE_TABLE(spi, hi3110_id_table);
static int hi3110_can_probe(struct spi_device *spi)
const struct of_device_id *of_id = of_match_device(hi3110_of_match,
&spi->dev);
struct hi3110_priv *priv;
struct clk *clk;
int freq, ret;
clk = devm_clk_get(&spi->dev, NULL);
if (IS_ERR(clk)) {
dev_err(&spi->dev, "no CAN clock source defined\n");
return PTR_ERR(clk);
freq = clk_get_rate(clk);
/* Sanity check */
if (freq > 40000000)
return -ERANGE;
/* Allocate can/net device */
net = alloc_candev(sizeof(struct hi3110_priv), HI3110_TX_ECHO_SKB_MAX);
if (!net)
return -ENOMEM;
if (!IS_ERR(clk)) {
ret = clk_prepare_enable(clk);
if (ret)
goto out_free;
net->netdev_ops = &hi3110_netdev_ops;
net->flags |= IFF_ECHO;
priv->can.bittiming_const = &hi3110_bittiming_const;
priv->can.do_set_mode = hi3110_do_set_mode;
priv->can.do_get_berr_counter = hi3110_get_berr_counter;
priv->can.clock.freq = freq / 2;
priv->can.ctrlmode_supported = CAN_CTRLMODE_3_SAMPLES |
CAN_CTRLMODE_LOOPBACK |
CAN_CTRLMODE_LISTENONLY |
CAN_CTRLMODE_BERR_REPORTING;
if (of_id)
priv->model = (enum hi3110_model)of_id->data;
else
priv->model = spi_get_device_id(spi)->driver_data;
priv->net = net;
priv->clk = clk;
spi_set_drvdata(spi, priv);
/* Configure the SPI bus */
spi->bits_per_word = 8;
ret = spi_setup(spi);
if (ret)
goto out_clk;
priv->power = devm_regulator_get_optional(&spi->dev, "vdd");
priv->transceiver = devm_regulator_get_optional(&spi->dev, "xceiver");
if ((PTR_ERR(priv->power) == -EPROBE_DEFER) ||
(PTR_ERR(priv->transceiver) == -EPROBE_DEFER)) {
ret = -EPROBE_DEFER;
goto out_clk;
ret = hi3110_power_enable(priv->power, 1);
if (ret)
goto out_clk;
priv->spi = spi;
mutex_init(&priv->hi3110_lock);
/* If requested, allocate DMA buffers */
spi->dev.coherent_dma_mask = ~0;
/* Minimum coherent DMA allocation is PAGE_SIZE, so allocate
* that much and share it between Tx and Rx DMA buffers.
priv->spi_tx_buf = dmam_alloc_coherent(&spi->dev,
PAGE_SIZE,
&priv->spi_tx_dma,
GFP_DMA);
if (priv->spi_tx_buf) {
priv->spi_rx_buf = (priv->spi_tx_buf + (PAGE_SIZE / 2));
priv->spi_rx_dma = (dma_addr_t)(priv->spi_tx_dma +
(PAGE_SIZE / 2));
} else {
/* Fall back to non-DMA */
hi3110_enable_dma = 0;
/* Allocate non-DMA buffers */
if (!hi3110_enable_dma) {
priv->spi_tx_buf = devm_kzalloc(&spi->dev, HI3110_RX_BUF_LEN,
GFP_KERNEL);
if (!priv->spi_tx_buf) {
ret = -ENOMEM;
goto error_probe;
priv->spi_rx_buf = devm_kzalloc(&spi->dev, HI3110_RX_BUF_LEN,
GFP_KERNEL);
if (!priv->spi_rx_buf) {
ret = -ENOMEM;
goto error_probe;
SET_NETDEV_DEV(net, &spi->dev);
ret = hi3110_hw_probe(spi);
if (ret) {
if (ret == -ENODEV)
dev_err(&spi->dev, "Cannot initialize %x. Wrong wiring?\n",
priv->model);
goto error_probe;
ret = register_candev(net);
if (ret)
goto error_probe;
devm_can_led_init(net);
netdev_info(net, "%x successfully initialized.\n", priv->model);
return 0;
error_probe:
hi3110_power_enable(priv->power, 0);
out_clk:
if (!IS_ERR(clk))
clk_disable_unprepare(clk);
out_free:
free_candev(net);
dev_err(&spi->dev, "Probe failed, err=%d\n", -ret);
return ret;
static int hi3110_can_remove(struct spi_device *spi)
unregister_candev(net);
if (!IS_ERR(priv->clk))
clk_disable_unprepare(priv->clk);
free_candev(net);
return 0;
static int __maybe_unused hi3110_can_suspend(struct device *dev)
struct spi_device *spi = to_spi_device(dev);
disable_irq(spi->irq);
/* Note: at this point neither IST nor workqueues are running.
* open/stop cannot be called anyway so locking is not needed
if (netif_running(net)) {
netif_device_detach(net);
priv->after_suspend = HI3110_AFTER_SUSPEND_UP;
} else {
priv->after_suspend = HI3110_AFTER_SUSPEND_DOWN;
if (!IS_ERR_OR_NULL(priv->power)) {
regulator_disable(priv->power);
priv->after_suspend |= HI3110_AFTER_SUSPEND_POWER;
return 0;
static int __maybe_unused hi3110_can_resume(struct device *dev)
if (priv->after_suspend & HI3110_AFTER_SUSPEND_POWER)
} else {
enable_irq(spi->irq);
return 0;
static SIMPLE_DEV_PM_OPS(hi3110_can_pm_ops, hi3110_can_suspend, hi3110_can_resume);
static struct spi_driver hi3110_can_driver = {
.driver = {
.of_match_table = hi3110_of_match,
.pm = &hi3110_can_pm_ops,
.id_table = hi3110_id_table,
.probe = hi3110_can_probe,
.remove = hi3110_can_remove,
module_spi_driver(hi3110_can_driver);
MODULE_AUTHOR("Akshay Bhat <akshay.bhat@timesys.com>");
MODULE_AUTHOR("Casey Fitzpatrick <casey.fitzpatrick@timesys.com>");
MODULE_DESCRIPTION("Holt HI-3110 CAN driver");
MODULE_LICENSE("GPL v2");
* CAN bus driver for Microchip 251x/25625 CAN Controller with SPI Interface
* MCP2510 support and bug fixes by Christian Pellegrin
* <chripell@evolware.org>
* Written under contract by:
* Chris Elston, Katalix Systems, Ltd.
* Based on Microchip MCP251x CAN controller driver written by
* David Vrabel, Copyright 2006 Arcom Control Systems Ltd.
* Copyright 2007
* it under the terms of the version 2 of the GNU General Public License
* as published by the Free Software Foundation
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, see <http://www.gnu.org/licenses/>.
* Your platform definition file should specify something like:
* static struct mcp251x_platform_data mcp251x_info = {
* .oscillator_frequency = 8000000,
* static struct spi_board_info spi_board_info[] = {
* .modalias = "mcp2510",
* // "mcp2515" or "mcp25625" depending on your controller
* .platform_data = &mcp251x_info,
* .irq = IRQ_EINT13,
* .max_speed_hz = 2*1000*1000,
* .chip_select = 2,
* Please see mcp251x.h for a description of the fields in
* struct mcp251x_platform_data.
#include <linux/can/platform/mcp251x.h>
/* SPI interface instruction set */
#define INSTRUCTION_WRITE 0x02
#define INSTRUCTION_READ 0x03
#define INSTRUCTION_BIT_MODIFY 0x05
#define INSTRUCTION_LOAD_TXB(n) (0x40 + 2 * (n))
#define INSTRUCTION_READ_RXB(n) (((n) == 0) ? 0x90 : 0x94)
#define INSTRUCTION_RESET 0xC0
#define RTS_TXB0 0x01
#define RTS_TXB1 0x02
#define RTS_TXB2 0x04
#define INSTRUCTION_RTS(n) (0x80 | ((n) & 0x07))
/* MPC251x registers */
#define CANSTAT 0x0e
#define CANCTRL 0x0f
# define CANCTRL_REQOP_MASK 0xe0
# define CANCTRL_REQOP_CONF 0x80
# define CANCTRL_REQOP_LISTEN_ONLY 0x60
# define CANCTRL_REQOP_LOOPBACK 0x40
# define CANCTRL_REQOP_SLEEP 0x20
# define CANCTRL_REQOP_NORMAL 0x00
# define CANCTRL_OSM 0x08
# define CANCTRL_ABAT 0x10
#define TEC 0x1c
#define REC 0x1d
#define CNF1 0x2a
# define CNF1_SJW_SHIFT 6
#define CNF2 0x29
# define CNF2_BTLMODE 0x80
# define CNF2_SAM 0x40
# define CNF2_PS1_SHIFT 3
#define CNF3 0x28
# define CNF3_SOF 0x08
# define CNF3_WAKFIL 0x04
# define CNF3_PHSEG2_MASK 0x07
#define CANINTE 0x2b
# define CANINTE_MERRE 0x80
# define CANINTE_WAKIE 0x40
# define CANINTE_ERRIE 0x20
# define CANINTE_TX2IE 0x10
# define CANINTE_TX1IE 0x08
# define CANINTE_TX0IE 0x04
# define CANINTE_RX1IE 0x02
# define CANINTE_RX0IE 0x01
#define CANINTF 0x2c
# define CANINTF_MERRF 0x80
# define CANINTF_WAKIF 0x40
# define CANINTF_ERRIF 0x20
# define CANINTF_TX2IF 0x10
# define CANINTF_TX1IF 0x08
# define CANINTF_TX0IF 0x04
# define CANINTF_RX1IF 0x02
# define CANINTF_RX0IF 0x01
# define CANINTF_RX (CANINTF_RX0IF | CANINTF_RX1IF)
# define CANINTF_TX (CANINTF_TX2IF | CANINTF_TX1IF | CANINTF_TX0IF)
# define CANINTF_ERR (CANINTF_ERRIF)
#define EFLG 0x2d
# define EFLG_EWARN 0x01
# define EFLG_RXWAR 0x02
# define EFLG_TXWAR 0x04
# define EFLG_RXEP 0x08
# define EFLG_TXEP 0x10
# define EFLG_TXBO 0x20
# define EFLG_RX0OVR 0x40
# define EFLG_RX1OVR 0x80
#define TXBCTRL(n) (((n) * 0x10) + 0x30 + TXBCTRL_OFF)
# define TXBCTRL_ABTF 0x40
# define TXBCTRL_MLOA 0x20
# define TXBCTRL_TXERR 0x10
# define TXBCTRL_TXREQ 0x08
#define TXBSIDH(n) (((n) * 0x10) + 0x30 + TXBSIDH_OFF)
# define SIDH_SHIFT 3
#define TXBSIDL(n) (((n) * 0x10) + 0x30 + TXBSIDL_OFF)
# define SIDL_SID_MASK 7
# define SIDL_SID_SHIFT 5
# define SIDL_EXIDE_SHIFT 3
# define SIDL_EID_SHIFT 16
# define SIDL_EID_MASK 3
#define TXBEID8(n) (((n) * 0x10) + 0x30 + TXBEID8_OFF)
#define TXBEID0(n) (((n) * 0x10) + 0x30 + TXBEID0_OFF)
#define TXBDLC(n) (((n) * 0x10) + 0x30 + TXBDLC_OFF)
# define DLC_RTR_SHIFT 6
#define TXBCTRL_OFF 0
#define TXBSIDH_OFF 1
#define TXBSIDL_OFF 2
#define TXBEID8_OFF 3
#define TXBEID0_OFF 4
#define TXBDLC_OFF 5
#define TXBDAT_OFF 6
#define RXBCTRL(n) (((n) * 0x10) + 0x60 + RXBCTRL_OFF)
# define RXBCTRL_BUKT 0x04
# define RXBCTRL_RXM0 0x20
# define RXBCTRL_RXM1 0x40
#define RXBSIDH(n) (((n) * 0x10) + 0x60 + RXBSIDH_OFF)
# define RXBSIDH_SHIFT 3
#define RXBSIDL(n) (((n) * 0x10) + 0x60 + RXBSIDL_OFF)
# define RXBSIDL_IDE 0x08
# define RXBSIDL_SRR 0x10
# define RXBSIDL_EID 3
# define RXBSIDL_SHIFT 5
#define RXBEID8(n) (((n) * 0x10) + 0x60 + RXBEID8_OFF)
#define RXBEID0(n) (((n) * 0x10) + 0x60 + RXBEID0_OFF)
#define RXBDLC(n) (((n) * 0x10) + 0x60 + RXBDLC_OFF)
# define RXBDLC_LEN_MASK 0x0f
# define RXBDLC_RTR 0x40
#define RXBCTRL_OFF 0
#define RXBSIDH_OFF 1
#define RXBSIDL_OFF 2
#define RXBEID8_OFF 3
#define RXBEID0_OFF 4
#define RXBDLC_OFF 5
#define RXBDAT_OFF 6
#define RXFSID(n) ((n < 3) ? 0 : 4)
#define RXFSIDH(n) ((n) * 4 + RXFSID(n))
#define RXFSIDL(n) ((n) * 4 + 1 + RXFSID(n))
#define RXFEID8(n) ((n) * 4 + 2 + RXFSID(n))
#define RXFEID0(n) ((n) * 4 + 3 + RXFSID(n))
#define RXMSIDH(n) ((n) * 4 + 0x20)
#define RXMSIDL(n) ((n) * 4 + 0x21)
#define RXMEID8(n) ((n) * 4 + 0x22)
#define RXMEID0(n) ((n) * 4 + 0x23)
#define GET_BYTE(val, byte) \
(((val) >> ((byte) * 8)) & 0xff)
#define SET_BYTE(val, byte) \
(((val) & 0xff) << ((byte) * 8))
* Buffer size required for the largest SPI transfer (i.e., reading a
* frame)
#define CAN_FRAME_MAX_DATA_LEN 8
#define SPI_TRANSFER_BUF_LEN (6 + CAN_FRAME_MAX_DATA_LEN)
#define CAN_FRAME_MAX_BITS 128
#define TX_ECHO_SKB_MAX 1
#define MCP251X_OST_DELAY_MS (5)
#define DEVICE_NAME "mcp251x"
static int mcp251x_enable_dma; /* Enable SPI DMA. Default: 0 (Off) */
module_param(mcp251x_enable_dma, int, 0444);
MODULE_PARM_DESC(mcp251x_enable_dma, "Enable SPI DMA. Default: 0 (Off)");
static const struct can_bittiming_const mcp251x_bittiming_const = {
.tseg1_min = 3,
.tseg1_max = 16,
.tseg2_min = 2,
.tseg2_max = 8,
.sjw_max = 4,
.brp_min = 1,
.brp_max = 64,
.brp_inc = 1,
enum mcp251x_model {
CAN_MCP251X_MCP2510 = 0x2510,
CAN_MCP251X_MCP2515 = 0x2515,
CAN_MCP251X_MCP25625 = 0x25625,
struct mcp251x_priv {
enum mcp251x_model model;
struct mutex mcp_lock; /* SPI device lock */
u8 *spi_tx_buf;
u8 *spi_rx_buf;
int tx_len;
int force_quit;
int after_suspend;
#define AFTER_SUSPEND_UP 1
#define AFTER_SUSPEND_DOWN 2
#define AFTER_SUSPEND_POWER 4
#define AFTER_SUSPEND_RESTART 8
int restart_tx;
struct clk *clk;
#define MCP251X_IS(_model) \
static inline int mcp251x_is_##_model(struct spi_device *spi) \
struct mcp251x_priv *priv = spi_get_drvdata(spi); \
return priv->model == CAN_MCP251X_MCP##_model; \
MCP251X_IS(2510);
static void mcp251x_clean(struct net_device *net)
struct mcp251x_priv *priv = netdev_priv(net);
if (priv->tx_skb)
if (priv->tx_len)
priv->tx_len = 0;
* Note about handling of error return of mcp251x_spi_trans: accessing
static int mcp251x_spi_trans(struct spi_device *spi, int len)
.len = len,
.cs_change = 0,
int ret;
if (mcp251x_enable_dma) {
if (ret)
return ret;
static u8 mcp251x_read_reg(struct spi_device *spi, uint8_t reg)
u8 val = 0;
priv->spi_tx_buf[0] = INSTRUCTION_READ;
priv->spi_tx_buf[1] = reg;
mcp251x_spi_trans(spi, 3);
val = priv->spi_rx_buf[2];
return val;
static void mcp251x_read_2regs(struct spi_device *spi, uint8_t reg,
uint8_t *v1, uint8_t *v2)
mcp251x_spi_trans(spi, 4);
*v1 = priv->spi_rx_buf[2];
*v2 = priv->spi_rx_buf[3];
static void mcp251x_write_reg(struct spi_device *spi, u8 reg, uint8_t val)
priv->spi_tx_buf[0] = INSTRUCTION_WRITE;
priv->spi_tx_buf[2] = val;
static void mcp251x_write_bits(struct spi_device *spi, u8 reg,
u8 mask, uint8_t val)
priv->spi_tx_buf[0] = INSTRUCTION_BIT_MODIFY;
priv->spi_tx_buf[2] = mask;
priv->spi_tx_buf[3] = val;
static void mcp251x_hw_tx_frame(struct spi_device *spi, u8 *buf,
int len, int tx_buf_idx)
if (mcp251x_is_2510(spi)) {
int i;
for (i = 1; i < TXBDAT_OFF + len; i++)
mcp251x_write_reg(spi, TXBCTRL(tx_buf_idx) + i,
buf[i]);
} else {
memcpy(priv->spi_tx_buf, buf, TXBDAT_OFF + len);
mcp251x_spi_trans(spi, TXBDAT_OFF + len);
static void mcp251x_hw_tx(struct spi_device *spi, struct can_frame *frame,
int tx_buf_idx)
u32 sid, eid, exide, rtr;
u8 buf[SPI_TRANSFER_BUF_LEN];
exide = (frame->can_id & CAN_EFF_FLAG) ? 1 : 0; /* Extended ID Enable */
if (exide)
sid = (frame->can_id & CAN_EFF_MASK) >> 18;
else
sid = frame->can_id & CAN_SFF_MASK; /* Standard ID */
eid = frame->can_id & CAN_EFF_MASK; /* Extended ID */
rtr = (frame->can_id & CAN_RTR_FLAG) ? 1 : 0; /* Remote transmission */
buf[TXBCTRL_OFF] = INSTRUCTION_LOAD_TXB(tx_buf_idx);
buf[TXBSIDH_OFF] = sid >> SIDH_SHIFT;
buf[TXBSIDL_OFF] = ((sid & SIDL_SID_MASK) << SIDL_SID_SHIFT) |
(exide << SIDL_EXIDE_SHIFT) |
((eid >> SIDL_EID_SHIFT) & SIDL_EID_MASK);
buf[TXBEID8_OFF] = GET_BYTE(eid, 1);
buf[TXBEID0_OFF] = GET_BYTE(eid, 0);
buf[TXBDLC_OFF] = (rtr << DLC_RTR_SHIFT) | frame->can_dlc;
memcpy(buf + TXBDAT_OFF, frame->data, frame->can_dlc);
mcp251x_hw_tx_frame(spi, buf, frame->can_dlc, tx_buf_idx);
/* use INSTRUCTION_RTS, to avoid "repeated frame problem" */
priv->spi_tx_buf[0] = INSTRUCTION_RTS(1 << tx_buf_idx);
mcp251x_spi_trans(priv->spi, 1);
static void mcp251x_hw_rx_frame(struct spi_device *spi, u8 *buf,
int buf_idx)
int i, len;
for (i = 1; i < RXBDAT_OFF; i++)
buf[i] = mcp251x_read_reg(spi, RXBCTRL(buf_idx) + i);
len = get_can_dlc(buf[RXBDLC_OFF] & RXBDLC_LEN_MASK);
for (; i < (RXBDAT_OFF + len); i++)
} else {
priv->spi_tx_buf[RXBCTRL_OFF] = INSTRUCTION_READ_RXB(buf_idx);
mcp251x_spi_trans(spi, SPI_TRANSFER_BUF_LEN);
memcpy(buf, priv->spi_rx_buf, SPI_TRANSFER_BUF_LEN);
static void mcp251x_hw_rx(struct spi_device *spi, int buf_idx)
if (!skb) {
dev_err(&spi->dev, "cannot allocate RX skb\n");
return;
mcp251x_hw_rx_frame(spi, buf, buf_idx);
if (buf[RXBSIDL_OFF] & RXBSIDL_IDE) {
/* Extended ID format */
frame->can_id |=
/* Extended ID part */
SET_BYTE(buf[RXBSIDL_OFF] & RXBSIDL_EID, 2) |
SET_BYTE(buf[RXBEID8_OFF], 1) |
SET_BYTE(buf[RXBEID0_OFF], 0) |
/* Standard ID part */
(((buf[RXBSIDH_OFF] << RXBSIDH_SHIFT) |
(buf[RXBSIDL_OFF] >> RXBSIDL_SHIFT)) << 18);
/* Remote transmission request */
if (buf[RXBDLC_OFF] & RXBDLC_RTR)
} else {
/* Standard ID format */
frame->can_id =
(buf[RXBSIDL_OFF] >> RXBSIDL_SHIFT);
if (buf[RXBSIDL_OFF] & RXBSIDL_SRR)
/* Data length */
frame->can_dlc = get_can_dlc(buf[RXBDLC_OFF] & RXBDLC_LEN_MASK);
memcpy(frame->data, buf + RXBDAT_OFF, frame->can_dlc);
netif_rx_ni(skb);
static void mcp251x_hw_sleep(struct spi_device *spi)
mcp251x_write_reg(spi, CANCTRL, CANCTRL_REQOP_SLEEP);
static netdev_tx_t mcp251x_hard_start_xmit(struct sk_buff *skb,
dev_warn(&spi->dev, "hard_xmit called while tx busy\n");
priv->tx_skb = skb;
static int mcp251x_do_set_mode(struct net_device *net, enum can_mode mode)
switch (mode) {
mcp251x_clean(net);
priv->after_suspend = AFTER_SUSPEND_RESTART;
break;
default:
return -EOPNOTSUPP;
return 0;
static int mcp251x_set_normal_mode(struct spi_device *spi)
unsigned long timeout;
/* Enable interrupts */
mcp251x_write_reg(spi, CANINTE,
CANINTE_ERRIE | CANINTE_TX2IE | CANINTE_TX1IE |
CANINTE_TX0IE | CANINTE_RX1IE | CANINTE_RX0IE);
if (priv->can.ctrlmode & CAN_CTRLMODE_LOOPBACK) {
/* Put device into loopback mode */
mcp251x_write_reg(spi, CANCTRL, CANCTRL_REQOP_LOOPBACK);
} else if (priv->can.ctrlmode & CAN_CTRLMODE_LISTENONLY) {
/* Put device into listen-only mode */
mcp251x_write_reg(spi, CANCTRL, CANCTRL_REQOP_LISTEN_ONLY);
} else {
/* Put device into normal mode */
mcp251x_write_reg(spi, CANCTRL, CANCTRL_REQOP_NORMAL);
/* Wait for the device to enter normal mode */
timeout = jiffies + HZ;
while (mcp251x_read_reg(spi, CANSTAT) & CANCTRL_REQOP_MASK) {
schedule();
if (time_after(jiffies, timeout)) {
dev_err(&spi->dev, "MCP251x didn't"
" enter in normal mode\n");
return -EBUSY;
return 0;
static int mcp251x_do_set_bittiming(struct net_device *net)
mcp251x_write_reg(spi, CNF1, ((bt->sjw - 1) << CNF1_SJW_SHIFT) |
(bt->brp - 1));
mcp251x_write_reg(spi, CNF2, CNF2_BTLMODE |
(priv->can.ctrlmode & CAN_CTRLMODE_3_SAMPLES ?
CNF2_SAM : 0) |
((bt->phase_seg1 - 1) << CNF2_PS1_SHIFT) |
(bt->prop_seg - 1));
mcp251x_write_bits(spi, CNF3, CNF3_PHSEG2_MASK,
(bt->phase_seg2 - 1));
dev_dbg(&spi->dev, "CNF: 0x%02x 0x%02x 0x%02x\n",
mcp251x_read_reg(spi, CNF1),
mcp251x_read_reg(spi, CNF2),
mcp251x_read_reg(spi, CNF3));
return 0;
static int mcp251x_setup(struct net_device *net, struct spi_device *spi)
mcp251x_do_set_bittiming(net);
mcp251x_write_reg(spi, RXBCTRL(0),
RXBCTRL_BUKT | RXBCTRL_RXM0 | RXBCTRL_RXM1);
mcp251x_write_reg(spi, RXBCTRL(1),
return 0;
static int mcp251x_hw_reset(struct spi_device *spi)
int ret;
mdelay(MCP251X_OST_DELAY_MS);
priv->spi_tx_buf[0] = INSTRUCTION_RESET;
ret = mcp251x_spi_trans(spi, 1);
if (ret)
return ret;
/* Wait for reset to finish */
while ((mcp251x_read_reg(spi, CANSTAT) & CANCTRL_REQOP_MASK) !=
CANCTRL_REQOP_CONF) {
usleep_range(MCP251X_OST_DELAY_MS * 1000,
MCP251X_OST_DELAY_MS * 1000 * 2);
dev_err(&spi->dev,
"MCP251x didn't enter in conf mode after reset\n");
return -EBUSY;
return 0;
static int mcp251x_hw_probe(struct spi_device *spi)
u8 ctrl;
int ret;
ret = mcp251x_hw_reset(spi);
if (ret)
return ret;
ctrl = mcp251x_read_reg(spi, CANCTRL);
dev_dbg(&spi->dev, "CANCTRL 0x%02x\n", ctrl);
/* Check for power up default value */
if ((ctrl & 0x17) != 0x07)
return -ENODEV;
return 0;
static int mcp251x_power_enable(struct regulator *reg, int enable)
return 0;
if (enable)
else
static int mcp251x_stop(struct net_device *net)
close_candev(net);
priv->wq = NULL;
mutex_lock(&priv->mcp_lock);
/* Disable and clear pending interrupts */
mcp251x_write_reg(spi, CANINTE, 0x00);
mcp251x_write_reg(spi, CANINTF, 0x00);
mcp251x_write_reg(spi, TXBCTRL(0), 0);
mcp251x_clean(net);
mcp251x_hw_sleep(spi);
mcp251x_power_enable(priv->transceiver, 0);
mutex_unlock(&priv->mcp_lock);
return 0;
static void mcp251x_error_skb(struct net_device *net, int can_id, int data1)
skb = alloc_can_err_skb(net, &frame);
if (skb) {
frame->can_id |= can_id;
frame->data[1] = data1;
netif_rx_ni(skb);
} else {
netdev_err(net, "cannot allocate error skb\n");
static void mcp251x_tx_work_handler(struct work_struct *ws)
struct mcp251x_priv *priv = container_of(ws, struct mcp251x_priv,
tx_work);
if (priv->tx_skb) {
mcp251x_clean(net);
} else {
if (frame->can_dlc > CAN_FRAME_MAX_DATA_LEN)
frame->can_dlc = CAN_FRAME_MAX_DATA_LEN;
mcp251x_hw_tx(spi, frame, 0);
static void mcp251x_restart_work_handler(struct work_struct *ws)
restart_work);
mcp251x_setup(net, spi);
if (priv->after_suspend & AFTER_SUSPEND_RESTART) {
mcp251x_set_normal_mode(spi);
} else if (priv->after_suspend & AFTER_SUSPEND_UP) {
mcp251x_clean(net);
} else {
mcp251x_clean(net);
mcp251x_error_skb(net, CAN_ERR_RESTARTED, 0);
static irqreturn_t mcp251x_can_ist(int irq, void *dev_id)
struct mcp251x_priv *priv = dev_id;
u8 intf, eflag;
u8 clear_intf = 0;
int can_id = 0, data1 = 0;
mcp251x_read_2regs(spi, CANINTF, &intf, &eflag);
/* mask out flags we don't care about */
intf &= CANINTF_RX | CANINTF_TX | CANINTF_ERR;
/* receive buffer 0 */
if (intf & CANINTF_RX0IF) {
mcp251x_hw_rx(spi, 0);
/* Free one buffer ASAP
* (The MCP2515/25625 does this automatically.)
mcp251x_write_bits(spi, CANINTF, CANINTF_RX0IF, 0x00);
/* receive buffer 1 */
if (intf & CANINTF_RX1IF) {
mcp251x_hw_rx(spi, 1);
/* The MCP2515/25625 does this automatically. */
clear_intf |= CANINTF_RX1IF;
/* any error or tx interrupt we need to clear? */
if (intf & (CANINTF_ERR | CANINTF_TX))
clear_intf |= intf & (CANINTF_ERR | CANINTF_TX);
if (clear_intf)
mcp251x_write_bits(spi, CANINTF, clear_intf, 0x00);
if (eflag & (EFLG_RX0OVR | EFLG_RX1OVR))
mcp251x_write_bits(spi, EFLG, eflag, 0x00);
if (eflag & EFLG_TXBO) {
can_id |= CAN_ERR_BUSOFF;
} else if (eflag & EFLG_TXEP) {
can_id |= CAN_ERR_CRTL;
data1 |= CAN_ERR_CRTL_TX_PASSIVE;
} else if (eflag & EFLG_RXEP) {
data1 |= CAN_ERR_CRTL_RX_PASSIVE;
} else if (eflag & EFLG_TXWAR) {
data1 |= CAN_ERR_CRTL_TX_WARNING;
} else if (eflag & EFLG_RXWAR) {
data1 |= CAN_ERR_CRTL_RX_WARNING;
} else {
/* Update can state statistics */
switch (priv->can.state) {
case CAN_STATE_ERROR_ACTIVE:
if (new_state >= CAN_STATE_ERROR_WARNING &&
new_state <= CAN_STATE_BUS_OFF)
priv->can.can_stats.error_warning++;
case CAN_STATE_ERROR_WARNING: /* fallthrough */
if (new_state >= CAN_STATE_ERROR_PASSIVE &&
priv->can.can_stats.error_passive++;
break;
default:
break;
priv->can.state = new_state;
if (intf & CANINTF_ERRIF) {
/* Handle overflow counters */
if (eflag & (EFLG_RX0OVR | EFLG_RX1OVR)) {
if (eflag & EFLG_RX0OVR) {
net->stats.rx_over_errors++;
if (eflag & EFLG_RX1OVR) {
data1 |= CAN_ERR_CRTL_RX_OVERFLOW;
mcp251x_error_skb(net, can_id, data1);
priv->can.can_stats.bus_off++;
can_bus_off(net);
break;
if (intf == 0)
break;
if (intf & CANINTF_TX) {
if (priv->tx_len) {
priv->tx_len = 0;
return IRQ_HANDLED;
static int mcp251x_open(struct net_device *net)
unsigned long flags = IRQF_ONESHOT | IRQF_TRIGGER_FALLING;
int ret;
if (ret) {
dev_err(&spi->dev, "unable to set initial baudrate!\n");
return ret;
mcp251x_power_enable(priv->transceiver, 1);
priv->tx_len = 0;
ret = request_threaded_irq(spi->irq, NULL, mcp251x_can_ist,
flags | IRQF_ONESHOT, DEVICE_NAME, priv);
if (ret) {
goto out_close;
priv->wq = alloc_workqueue("mcp251x_wq", WQ_FREEZABLE | WQ_MEM_RECLAIM,
0);
if (!priv->wq) {
ret = -ENOMEM;
goto out_clean;
INIT_WORK(&priv->tx_work, mcp251x_tx_work_handler);
INIT_WORK(&priv->restart_work, mcp251x_restart_work_handler);
if (ret)
goto out_free_wq;
ret = mcp251x_setup(net, spi);
if (ret)
goto out_free_wq;
ret = mcp251x_set_normal_mode(spi);
if (ret)
goto out_free_wq;
return 0;
out_free_wq:
out_clean:
out_close:
close_candev(net);
return ret;
static const struct net_device_ops mcp251x_netdev_ops = {
.ndo_open = mcp251x_open,
.ndo_stop = mcp251x_stop,
.ndo_start_xmit = mcp251x_hard_start_xmit,
.ndo_change_mtu = can_change_mtu,
static const struct of_device_id mcp251x_of_match[] = {
.compatible = "microchip,mcp2510",
.data = (void *)CAN_MCP251X_MCP2510,
.compatible = "microchip,mcp2515",
.data = (void *)CAN_MCP251X_MCP2515,
.compatible = "microchip,mcp25625",
.data = (void *)CAN_MCP251X_MCP25625,
MODULE_DEVICE_TABLE(of, mcp251x_of_match);
static const struct spi_device_id mcp251x_id_table[] = {
.name = "mcp2510",
.driver_data = (kernel_ulong_t)CAN_MCP251X_MCP2510,
.name = "mcp2515",
.driver_data = (kernel_ulong_t)CAN_MCP251X_MCP2515,
.name = "mcp25625",
.driver_data = (kernel_ulong_t)CAN_MCP251X_MCP25625,
MODULE_DEVICE_TABLE(spi, mcp251x_id_table);
static int mcp251x_can_probe(struct spi_device *spi)
const struct of_device_id *of_id = of_match_device(mcp251x_of_match,
&spi->dev);
struct mcp251x_platform_data *pdata = dev_get_platdata(&spi->dev);
struct mcp251x_priv *priv;
struct clk *clk;
int freq, ret;
if (IS_ERR(clk)) {
if (pdata)
freq = pdata->oscillator_frequency;
else
} else {
/* Sanity check */
if (freq < 1000000 || freq > 25000000)
return -ERANGE;
net = alloc_candev(sizeof(struct mcp251x_priv), TX_ECHO_SKB_MAX);
if (!net)
return -ENOMEM;
if (!IS_ERR(clk)) {
if (ret)
goto out_free;
net->netdev_ops = &mcp251x_netdev_ops;
priv->can.bittiming_const = &mcp251x_bittiming_const;
priv->can.do_set_mode = mcp251x_do_set_mode;
CAN_CTRLMODE_LOOPBACK | CAN_CTRLMODE_LISTENONLY;
if (of_id)
priv->model = (enum mcp251x_model)of_id->data;
else
priv->net = net;
priv->clk = clk;
spi->max_speed_hz = spi->max_speed_hz ? : 5 * 1000 * 1000;
else
spi->max_speed_hz = spi->max_speed_hz ? : 10 * 1000 * 1000;
if (ret)
goto out_clk;
goto out_clk;
ret = mcp251x_power_enable(priv->power, 1);
if (ret)
goto out_clk;
priv->spi = spi;
mutex_init(&priv->mcp_lock);
PAGE_SIZE,
&priv->spi_tx_dma,
GFP_DMA);
(PAGE_SIZE / 2));
} else {
mcp251x_enable_dma = 0;
if (!mcp251x_enable_dma) {
priv->spi_tx_buf = devm_kzalloc(&spi->dev, SPI_TRANSFER_BUF_LEN,
GFP_KERNEL);
ret = -ENOMEM;
goto error_probe;
priv->spi_rx_buf = devm_kzalloc(&spi->dev, SPI_TRANSFER_BUF_LEN,
GFP_KERNEL);
ret = -ENOMEM;
goto error_probe;
/* Here is OK to not lock the MCP, no one knows about it yet */
ret = mcp251x_hw_probe(spi);
if (ret) {
if (ret == -ENODEV)
dev_err(&spi->dev, "Cannot initialize MCP%x. Wrong wiring?\n", priv->model);
goto error_probe;
if (ret)
goto error_probe;
netdev_info(net, "MCP%x successfully initialized.\n", priv->model);
return 0;
error_probe:
mcp251x_power_enable(priv->power, 0);
out_clk:
if (!IS_ERR(clk))
out_free:
free_candev(net);
return ret;
static int mcp251x_can_remove(struct spi_device *spi)
free_candev(net);
return 0;
static int __maybe_unused mcp251x_can_suspend(struct device *dev)
priv->after_suspend = AFTER_SUSPEND_UP;
} else {
priv->after_suspend = AFTER_SUSPEND_DOWN;
priv->after_suspend |= AFTER_SUSPEND_POWER;
return 0;
static int __maybe_unused mcp251x_can_resume(struct device *dev)
if (priv->after_suspend & AFTER_SUSPEND_POWER)
} else {
return 0;
static SIMPLE_DEV_PM_OPS(mcp251x_can_pm_ops, mcp251x_can_suspend,
mcp251x_can_resume);
static struct spi_driver mcp251x_can_driver = {
.driver = {
.of_match_table = mcp251x_of_match,
.pm = &mcp251x_can_pm_ops,
.id_table = mcp251x_id_table,
.probe = mcp251x_can_probe,
.remove = mcp251x_can_remove,
module_spi_driver(mcp251x_can_driver);
MODULE_AUTHOR("Chris Elston <celston@katalix.com>, "
"Christian Pellegrin <chripell@evolware.org>");
MODULE_DESCRIPTION("Microchip 251x/25625 CAN driver");
Can Android drivers refer to other IC codes and modify only register related content? It takes too much time for me to write on my own because I am not very familiar with the register configuration part of the IC. I only handle the platform part of the IC that needs to be processed by the original factory. The driver sent below is also an Android built-in IC driver from another company, which is also SPI.
* Copyright 2007
.tseg1_min = 2,
.tseg1_max = 16,
.tseg2_min = 2,
.tseg2_max = 8,
.sjw_max = 4,
.brp_min = 1,
.brp_max = 64,
.brp_inc = 1,
enum hi3110_model {
u8 *spi_tx_buf;
u8 *spi_rx_buf;
int tx_len;
int force_quit;
int after_suspend;
int restart_tx;
struct clk *clk;
if (priv->tx_skb)
if (priv->tx_len)
priv->tx_len = 0;
.len = len,
.cs_change = 0,
int ret;
if (ret)
return ret;
u8 val = 0;
return val;
HI3110_EFF_FLAGS |
} else {
if (!skb) {
return;
frame->can_id |=
} else {
frame->can_id =
/* Data length */
else
frame->can_dlc);
netif_rx_ni(skb);
priv->tx_skb = skb;
switch (mode) {
hi3110_clean(net);
break;
default:
return -EOPNOTSUPP;
return 0;
return 0;
u8 reg = 0;
/* Enable TX */
else
return -EBUSY;
return 0;
return 0;
return 0;
u8 reg;
int ret;
if (ret)
return ret;
return -ENODEV;
return 0;
u8 statf;
* in datasheet
if (statf != 0x82)
return -ENODEV;
return 0;
return 0;
if (enable)
else
close_candev(net);
priv->wq = NULL;
hi3110_clean(net);
return 0;
tx_work);
if (priv->tx_skb) {
hi3110_clean(net);
} else {
restart_work);
hi3110_setup(net);
hi3110_clean(net);
} else {
hi3110_setup(net);
hi3110_clean(net);
hi3110_hw_rx(spi);
else
u8 rxerr, txerr;
if (!skb)
break;
netif_rx_ni(skb);
can_bus_off(net);
break;
if (!skb)
break;
netif_rx_ni(skb);
if (priv->tx_len) {
priv->tx_len = 0;
if (intf == 0)
break;
return IRQ_HANDLED;
int ret;
if (ret)
return ret;
priv->tx_len = 0;
if (ret) {
goto out_close;
0);
if (!priv->wq) {
ret = -ENOMEM;
goto out_free_irq;
if (ret)
goto out_free_wq;
if (ret)
goto out_free_wq;
if (ret)
goto out_free_wq;
return 0;
out_free_wq:
out_free_irq:
out_close:
close_candev(net);
return ret;
.name = "hi3110",
&spi->dev);
struct clk *clk;
int freq, ret;
if (IS_ERR(clk)) {
/* Sanity check */
return -ERANGE;
if (!net)
return -ENOMEM;
if (!IS_ERR(clk)) {
if (ret)
goto out_free;
if (of_id)
else
priv->net = net;
priv->clk = clk;
if (ret)
goto out_clk;
goto out_clk;
if (ret)
goto out_clk;
priv->spi = spi;
PAGE_SIZE,
&priv->spi_tx_dma,
GFP_DMA);
(PAGE_SIZE / 2));
} else {
GFP_KERNEL);
ret = -ENOMEM;
goto error_probe;
GFP_KERNEL);
ret = -ENOMEM;
goto error_probe;
if (ret) {
if (ret == -ENODEV)
priv->model);
goto error_probe;
if (ret)
goto error_probe;
return 0;
error_probe:
out_clk:
if (!IS_ERR(clk))
out_free:
free_candev(net);
return ret;
free_candev(net);
return 0;
} else {
return 0;
} else {
return 0;
.driver = {
* Copyright 2007
* .chip_select = 2,
#define TEC 0x1c
#define REC 0x1d
#define CNF1 0x2a
#define CNF2 0x29
#define CNF3 0x28
#define EFLG 0x2d
* frame)
.tseg1_min = 3,
.tseg1_max = 16,
.tseg2_min = 2,
.tseg2_max = 8,
.sjw_max = 4,
.brp_min = 1,
.brp_max = 64,
.brp_inc = 1,
u8 *spi_tx_buf;
u8 *spi_rx_buf;
int tx_len;
int force_quit;
int after_suspend;
int restart_tx;
struct clk *clk;
MCP251X_IS(2510);
if (priv->tx_skb)
if (priv->tx_len)
priv->tx_len = 0;
.len = len,
.cs_change = 0,
int ret;
if (ret)
return ret;
u8 val = 0;
return val;
int i;
buf[i]);
} else {
int tx_buf_idx)
if (exide)
else
int buf_idx)
int i, len;
} else {
if (!skb) {
return;
frame->can_id |=
} else {
frame->can_id =
/* Data length */
netif_rx_ni(skb);
priv->tx_skb = skb;
switch (mode) {
mcp251x_clean(net);
break;
default:
return -EOPNOTSUPP;
return 0;
} else {
schedule();
return -EBUSY;
return 0;
(bt->brp - 1));
CNF2_SAM : 0) |
return 0;
return 0;
int ret;
if (ret)
return ret;
dev_err(&spi->dev,
return -EBUSY;
return 0;
u8 ctrl;
int ret;
if (ret)
return ret;
return -ENODEV;
return 0;
return 0;
if (enable)
else
close_candev(net);
priv->wq = NULL;
mcp251x_clean(net);
return 0;
if (skb) {
netif_rx_ni(skb);
} else {
tx_work);
if (priv->tx_skb) {
mcp251x_clean(net);
} else {
restart_work);
mcp251x_clean(net);
} else {
mcp251x_clean(net);
u8 intf, eflag;
u8 clear_intf = 0;
if (clear_intf)
} else {
break;
default:
break;
can_bus_off(net);
break;
if (intf == 0)
break;
if (priv->tx_len) {
priv->tx_len = 0;
return IRQ_HANDLED;
int ret;
if (ret) {
return ret;
priv->tx_len = 0;
if (ret) {
goto out_close;
0);
if (!priv->wq) {
ret = -ENOMEM;
goto out_clean;
if (ret)
goto out_free_wq;
if (ret)
goto out_free_wq;
if (ret)
goto out_free_wq;
return 0;
out_free_wq:
out_clean:
out_close:
close_candev(net);
return ret;
.name = "mcp2510",
.name = "mcp2515",
.name = "mcp25625",
&spi->dev);
struct clk *clk;
int freq, ret;
if (IS_ERR(clk)) {
if (pdata)
else
} else {
/* Sanity check */
return -ERANGE;
if (!net)
return -ENOMEM;
if (!IS_ERR(clk)) {
if (ret)
goto out_free;
if (of_id)
else
priv->net = net;
priv->clk = clk;
else
if (ret)
goto out_clk;
goto out_clk;
if (ret)
goto out_clk;
priv->spi = spi;
PAGE_SIZE,
&priv->spi_tx_dma,
GFP_DMA);
(PAGE_SIZE / 2));
} else {
GFP_KERNEL);
ret = -ENOMEM;
goto error_probe;
GFP_KERNEL);
ret = -ENOMEM;
goto error_probe;
if (ret) {
if (ret == -ENODEV)
goto error_probe;
if (ret)
goto error_probe;
return 0;
error_probe:
out_clk:
if (!IS_ERR(clk))
out_free:
free_candev(net);
return ret;
free_candev(net);
return 0;
} else {
return 0;
} else {
return 0;
.driver = {
Hi Tony,
The TCAN4550 is based on the M_CAN IP developed and licensed by Bosch. This IP is a common CAN FD Controller IP used in many devices and MCUs, and modification of code for any other M_CAN related device should be fairly simple. However, there are other CAN FD Controller IPs used in other devices such as the MCP251x ICs that use a completely different register stack that would be difficult to directly modify.
An overview of the basic configuration needed for the TCAN4550 can be found in the TCAN45xx Software User's Guide (Link).
A detailed description and overview of the Bosch M_CAN registers can be found in the M_CAN User's Manual (Link). These registers are used without modification in the TCAN4550 with one exception. The TCAN4550 has added an offset of 0x1000 to each register address. For example the M_CAN Control register has an address of 0x18 in the Bosch User's Manual, but the TCAN4550 uses address 0x1018 for this register. (0x1000 + 0x18 = 0x1018).
There is an example demo code in ANSI-C available for review and modification. It can be downloaded from the Software Development section of the TCAN4550-Q1's ti.com product folder (Link) or (SLLC469 - TCAN4550 Demo Software (Link).
Jonathan
