DS90UB954-Q1: DS90UB954-Q1 Randomly count error
Part Number: DS90UB954-Q1
Other Parts Discussed in Thread: ALP
Hi Sir,
We find that 954 errors are randomly counted.
When errors are counted, CSI output will stop at that moment. Our system will shut down.
We print 954 registers: 0X35=1, 0X37=3, 0x4D=53, 0X4E=24.
Is there any reason for the error count, or is there any way to set 954 to reduce errors?
We used ALP to check cable quality, and it looks good.
  • Hello Song_po,
    What Serializer is being used on the system? Do you have ability to turn on the Patgen on the Ser? Want to see if you still have errors when using patgen from the ser.
    Can you provide the following:
    1. How many units are experiencing this issue?
    2. Simple block diagram of the system. Include FPD rate, resolution, data type, and CSI rate?
    3. Register dumps of a passing and failing run?
    Thank you,
    Glenn
  • Hi sir,
    Sorry for late
    Serializer is DS90UB953.
    1.We have 6 units. Each unit can try this issue. We have attempted to reboot 954 300 times, with approximately 40 times.
    2.
    * FPD rate : 1.83G
    * Resolution : 2592 * 732
    * data type : MIPI
    * CSI rate : 460.8/Lane
    3.Referring to the text, we dump 3 times 954 CIS error register to ref.
    Apr  1 00:00:29 Check954: DESERIALIZER_ICG 0x35= 1
    Apr  1 00:00:29 Check954: DESERIALIZER_ICG 0x37= 3
    Apr  1 00:00:29 Check954: DESERIALIZER_ICG 0x4D= 115
    Apr  1 00:00:29 Check954: DESERIALIZER_ICG 0x4E= 229
    Apr  1 00:00:29 Check954: read_ICG_RXPARERRLO_value= 0
    Apr  1 00:00:29 Check954: read_ICG_RXPARERRHI_value= 0
    Apr  1 00:00:29 kernel: [   33.043023] 954 debug 0 : read = 60
    Apr  1 00:00:29 kernel: [   33.047655] 954 debug 1 : read = 0
    Apr  1 00:00:29 kernel: [   33.052199] 954 debug 2 : read = 1E
    Apr  1 00:00:29 kernel: [   33.056650] 954 debug 3 : read = 20
    Apr  1 00:00:29 kernel: [   33.061064] 954 debug 4 : read = DF
    Apr  1 00:00:29 kernel: [   33.065475] 954 debug 5 : read = 1
    Apr  1 00:00:29 kernel: [   33.069900] 954 debug 6 : read = 0
    Apr  1 00:00:29 kernel: [   33.074228] 954 debug 7 : read = FE
    Apr  1 00:00:29 kernel: [   33.078656] 954 debug 8 : read = 1C
    Apr  1 00:00:29 kernel: [   33.083069] 954 debug 9 : read = 10
    Apr  1 00:00:29 kernel: [   33.087533] 954 debug A : read = 7A
    Apr  1 00:00:29 kernel: [   33.091950] 954 debug B : read = 7A
    Apr  1 00:00:29 kernel: [   33.097226] 954 debug C : read = AB
    Apr  1 00:00:29 kernel: [   33.101658] 954 debug D : read = 9
    Apr  1 00:00:29 kernel: [   33.106030] 954 debug E : read = 8
    Apr  1 00:00:29 kernel: [   33.110363] 954 debug F : read = 7F
    Apr  1 00:00:29 kernel: [   33.114789] 954 debug 10 : read = 0
    Apr  1 00:00:29 kernel: [   33.119200] 954 debug 11 : read = 0
    Apr  1 00:00:29 kernel: [   33.123619] 954 debug 12 : read = 0
    Apr  1 00:00:29 kernel: [   33.128035] 954 debug 13 : read = 0
    Apr  1 00:00:29 kernel: [   33.132442] 954 debug 14 : read = 0
    Apr  1 00:00:29 kernel: [   33.136860] 954 debug 15 : read = 0
    Apr  1 00:00:29 kernel: [   33.141267] 954 debug 16 : read = 0
    Apr  1 00:00:29 kernel: [   33.145683] 954 debug 17 : read = 0
    Apr  1 00:00:29 kernel: [   33.150092] 954 debug 18 : read = 10
    Apr  1 00:00:29 kernel: [   33.154588] 954 debug 19 : read = 0
    Apr  1 00:00:29 kernel: [   33.159004] 954 debug 1A : read = 0
    Apr  1 00:00:29 kernel: [   33.163433] 954 debug 1B : read = 0
    Apr  1 00:00:29 kernel: [   33.167850] 954 debug 1C : read = 0
    Apr  1 00:00:29 kernel: [   33.172260] 954 debug 1D : read = 0
    Apr  1 00:00:29 kernel: [   33.176678] 954 debug 1E : read = 4
    Apr  1 00:00:29 kernel: [   33.181087] 954 debug 1F : read = 2
    Apr  1 00:00:29 kernel: [   33.185498] 954 debug 20 : read = 10
    Apr  1 00:00:29 kernel: [   33.189996] 954 debug 21 : read = 1
    Apr  1 00:00:29 kernel: [   33.194404] 954 debug 22 : read = 0
    Apr  1 00:00:29 kernel: [   33.200160] 954 debug 23 : read = 0
    Apr  1 00:00:29 kernel: [   33.204573] 954 debug 24 : read = 0
    Apr  1 00:00:29 kernel: [   33.208990] 954 debug 25 : read = 0
    Apr  1 00:00:29 kernel: [   33.213399] 954 debug 26 : read = 0
    Apr  1 00:00:29 kernel: [   33.217814] 954 debug 27 : read = 0
    Apr  1 00:00:29 kernel: [   33.222222] 954 debug 28 : read = 0
    Apr  1 00:00:29 kernel: [   33.226639] 954 debug 29 : read = 0
    Apr  1 00:00:29 kernel: [   33.231050] 954 debug 2A : read = 0
    Apr  1 00:00:29 kernel: [   33.235456] 954 debug 2B : read = 0
    Apr  1 00:00:29 kernel: [   33.239914] 954 debug 2C : read = 0
    Apr  1 00:00:29 kernel: [   33.244361] 954 debug 2D : read = 0
    Apr  1 00:00:29 kernel: [   33.248796] 954 debug 2E : read = 0
    Apr  1 00:00:29 kernel: [   33.253257] 954 debug 2F : read = 0
    Apr  1 00:00:29 kernel: [   33.257705] 954 debug 30 : read = 0
    Apr  1 00:00:29 kernel: [   33.262130] 954 debug 31 : read = 0
    Apr  1 00:00:29 kernel: [   33.266584] 954 debug 32 : read = 0
    Apr  1 00:00:29 kernel: [   33.271039] 954 debug 33 : read = 3
    Apr  1 00:00:29 kernel: [   33.275476] 954 debug 34 : read = 40
    Apr  1 00:00:29 kernel: [   33.280140] 954 debug 35 : read = 1
    Apr  1 00:00:29 kernel: [   33.284661] 954 debug 36 : read = 0
    Apr  1 00:00:29 kernel: [   33.289145] 954 debug 37 : read = 0
    Apr  1 00:00:29 kernel: [   33.293693] 954 debug 38 : read = 0
    Apr  1 00:00:29 kernel: [   33.298118] 954 debug 39 : read = 0
    Apr  1 00:00:29 kernel: [   33.303425] 954 debug 3A : read = 0
    Apr  1 00:00:29 kernel: [   33.307875] 954 debug 3B : read = 1
    Apr  1 00:00:29 kernel: [   33.312307] 954 debug 3C : read = 14
    Apr  1 00:00:29 kernel: [   33.316939] 954 debug 3D : read = 6F
    Apr  1 00:00:29 kernel: [   33.321459] 954 debug 3E : read = 0
    Apr  1 00:00:29 kernel: [   33.326043] 954 debug 3F : read = 40
    Apr  1 00:00:29 kernel: [   33.330581] 954 debug 40 : read = 0
    Apr  1 00:00:29 kernel: [   33.335212] 954 debug 41 : read = E0
    Apr  1 00:00:29 kernel: [   33.339853] 954 debug 42 : read = 71
    Apr  1 00:00:29 kernel: [   33.344371] 954 debug 43 : read = 1
    Apr  1 00:00:29 kernel: [   33.348932] 954 debug 44 : read = 0
    Apr  1 00:00:29 kernel: [   33.353360] 954 debug 45 : read = 0
    Apr  1 00:00:29 kernel: [   33.358242] 954 debug 46 : read = 0
    Apr  1 00:00:29 kernel: [   33.362775] 954 debug 47 : read = 0
    Apr  1 00:00:29 kernel: [   33.367203] 954 debug 48 : read = 0
    Apr  1 00:00:29 kernel: [   33.371758] 954 debug 49 : read = 0
    Apr  1 00:00:29 kernel: [   33.376191] 954 debug 4A : read = 0
    Apr  1 00:00:29 kernel: [   33.380761] 954 debug 4B : read = 12
    Apr  1 00:00:29 kernel: [   33.385295] 954 debug 4C : read = 12
    Apr  1 00:00:29 kernel: [   33.389826] 954 debug 4D : read = 43
    Apr  1 00:00:29 kernel: [   33.394335] 954 debug 4E : read = CD
    Apr  1 00:00:29 kernel: [   33.398847] 954 debug 4F : read = 64
    Apr  1 00:00:29 kernel: [   33.403348] 954 debug 50 : read = 0
    Apr  1 00:00:29 kernel: [   33.407767] 954 debug 51 : read = 0
    Apr  1 00:00:29 kernel: [   33.412177] 954 debug 52 : read = 0
    Apr  1 00:00:29 kernel: [   33.416593] 954 debug 53 : read = 4
    Apr  1 00:00:29 kernel: [   33.421004] 954 debug 54 : read = 0
    Apr  1 00:00:29 kernel: [   33.425411] 954 debug 55 : read = 0
    Apr  1 00:00:29 kernel: [   33.429865] 954 debug 56 : read = 3
    Apr  1 00:00:29 kernel: [   33.434274] 954 debug 57 : read = 0
    Apr  1 00:00:29 kernel: [   33.438693] 954 debug 58 : read = 5E
    Apr  1 00:00:29 kernel: [   33.443190] 954 debug 59 : read = 0
    Apr  1 00:00:29 kernel: [   33.447605] 954 debug 5A : read = 0
    Apr  1 00:00:29 kernel: [   33.452016] 954 debug 5B : read = 32
    Apr  1 00:00:29 kernel: [   33.456512] 954 debug 5C : read = 32
    Apr  1 00:00:29 kernel: [   33.461015] 954 debug 5D : read = 1C
    Apr  1 00:00:29 kernel: [   33.465510] 954 debug 5E : read = 6C
    Apr  1 00:00:29 kernel: [   33.471369] 954 debug 5F : read = 6E
    Apr  1 00:00:29 kernel: [   33.475867] 954 debug 60 : read = 52
    Apr  1 00:00:29 kernel: [   33.480361] 954 debug 61 : read = D0
    Apr  1 00:00:29 kernel: [   33.484864] 954 debug 62 : read = 6A
    Apr  1 00:00:29 kernel: [   33.489363] 954 debug 63 : read = 0
    Apr  1 00:00:29 kernel: [   33.493780] 954 debug 64 : read = 0
    Apr  1 00:00:29 kernel: [   33.498190] 954 debug 65 : read = 1C
    Apr  1 00:00:29 kernel: [   33.502694] 954 debug 66 : read = 6C
    Apr  1 00:00:29 kernel: [   33.509570] 954 debug 67 : read = 6E
    Apr  1 00:00:29 kernel: [   33.514068] 954 debug 68 : read = 52
    Apr  1 00:00:29 kernel: [   33.518562] 954 debug 69 : read = D0
    Apr  1 00:00:29 kernel: [   33.523060] 954 debug 6A : read = 6A
    Apr  1 00:00:29 kernel: [   33.527555] 954 debug 6B : read = 0
    Apr  1 00:00:29 kernel: [   33.531971] 954 debug 6C : read = 0
    Apr  1 00:00:29 kernel: [   33.536380] 954 debug 6D : read = 7C
    Apr  1 00:00:29 kernel: [   33.540881] 954 debug 6E : read = 88
    Apr  1 00:00:29 kernel: [   33.545378] 954 debug 6F : read = 88
    Apr  1 00:00:29 kernel: [   33.549882] 954 debug 70 : read = 6B
    Apr  1 00:00:29 kernel: [   33.554379] 954 debug 71 : read = 6C
    Apr  1 00:00:30 kernel: [   33.558882] 954 debug 72 : read = E4
    Apr  1 00:00:30 kernel: [   33.563378] 954 debug 73 : read = 2
    Apr  1 00:00:30 kernel: [   33.567792] 954 debug 74 : read = DC
    Apr  1 00:00:30 kernel: [   33.572289] 954 debug 75 : read = F
    Apr  1 00:00:30 kernel: [   33.576703] 954 debug 76 : read = 30
    Apr  1 00:00:30 kernel: [   33.581198] 954 debug 77 : read = C5
    Apr  1 00:00:30 kernel: [   33.585701] 954 debug 78 : read = 0
    Apr  1 00:00:30 kernel: [   33.590111] 954 debug 79 : read = 1
    Apr  1 00:00:30 kernel: [   33.594527] 954 debug 7A : read = E
    Apr  1 00:00:30 kernel: [   33.598969] 954 debug 7B : read = 2F
    Apr  1 00:00:30 kernel: [   33.603543] 954 debug 7C : read = 20
    Apr  1 00:00:30 kernel: [   33.608074] 954 debug 7D : read = 0
    Apr  1 00:00:30 kernel: [   33.612525] 954 debug 7E : read = 0
    Apr  1 00:00:30 kernel: [   33.616963] 954 debug 7F : read = 0
    Apr  1 00:00:30 kernel: [   33.621387] 954 debug 80 : read = 0
    Apr  1 00:00:30 kernel: [   33.625846] 954 debug 81 : read = 0
    Apr  1 00:00:30 kernel: [   33.630285] 954 debug 82 : read = 0
    Apr  1 00:00:30 kernel: [   33.634740] 954 debug 83 : read = 0
    Apr  1 00:00:30 kernel: [   33.639194] 954 debug 84 : read = 0
    Apr  1 00:00:30 kernel: [   33.643641] 954 debug 85 : read = 0
    Apr  1 00:00:30 kernel: [   33.648077] 954 debug 86 : read = 0
    Apr  1 00:00:30 kernel: [   33.652515] 954 debug 87 : read = 0
    Apr  1 00:00:30 kernel: [   33.656955] 954 debug 88 : read = 0
    Apr  1 00:00:30 kernel: [   33.661401] 954 debug 89 : read = 0
    Apr  1 00:00:30 kernel: [   33.665858] 954 debug 8A : read = 0
    Apr  1 00:00:30 kernel: [   33.670287] 954 debug 8B : read = 0
    Apr  1 00:00:30 kernel: [   33.674740] 954 debug 8C : read = 0
    Apr  1 00:00:30 kernel: [   33.679180] 954 debug 8D : read = 0
    Apr  1 00:00:30 kernel: [   33.683642] 954 debug 8E : read = 0
    Apr  1 00:00:30 kernel: [   33.688101] 954 debug 8F : read = 0
    Apr  1 00:00:30 kernel: [   33.692559] 954 debug 90 : read = 0
    Apr  1 00:00:30 kernel: [   33.697009] 954 debug 91 : read = 0
    Apr  1 00:00:30 kernel: [   33.701439] 954 debug 92 : read = 0
    Apr  1 00:00:30 kernel: [   33.705909] 954 debug 93 : read = 0
    Apr  1 00:00:30 kernel: [   33.710353] 954 debug 94 : read = 0
    Apr  1 00:00:30 kernel: [   33.715523] 954 debug 95 : read = 0
    Apr  1 00:00:30 kernel: [   33.719970] 954 debug 96 : read = 0
    Apr  1 00:00:30 kernel: [   33.724422] 954 debug 97 : read = 0
    Apr  1 00:00:30 kernel: [   33.728872] 954 debug 98 : read = 0
    Apr  1 00:00:30 kernel: [   33.733322] 954 debug 99 : read = 0
    Apr  1 00:00:30 kernel: [   33.737766] 954 debug 9A : read = 0
    Apr  1 00:00:30 kernel: [   33.742224] 954 debug 9B : read = 0
    Apr  1 00:00:30 kernel: [   33.746673] 954 debug 9C : read = 0
    Apr  1 00:00:30 kernel: [   33.751095] 954 debug 9D : read = 0
    Apr  1 00:00:30 kernel: [   33.755529] 954 debug 9E : read = 0
    Apr  1 00:00:30 kernel: [   33.759946] 954 debug 9F : read = 0
    Apr  1 00:00:30 kernel: [   33.764355] 954 debug A0 : read = 2
    Apr  1 00:00:30 kernel: [   33.768777] 954 debug A1 : read = F
    Apr  1 00:00:30 kernel: [   33.773185] 954 debug A2 : read = 0
    Apr  1 00:00:30 kernel: [   33.777602] 954 debug A3 : read = 0
    Apr  1 00:00:30 kernel: [   33.782016] 954 debug A4 : read = 8
    Apr  1 00:00:30 kernel: [   33.786424] 954 debug A5 : read = 19
    Apr  1 00:00:30 kernel: [   33.790926] 954 debug A6 : read = 0
    Apr  1 00:00:30 kernel: [   33.795335] 954 debug A7 : read = 0
    Apr  1 00:00:30 kernel: [   33.799750] 954 debug A8 : read = 0
    Apr  1 00:00:30 kernel: [   33.804161] 954 debug A9 : read = 0
    Apr  1 00:00:30 kernel: [   33.808576] 954 debug AA : read = 0
    Apr  1 00:00:30 kernel: [   33.812988] 954 debug AB : read = 0
    Apr  1 00:00:30 kernel: [   33.818451] 954 debug AC : read = 0
    Apr  1 00:00:30 kernel: [   33.822864] 954 debug AD : read = 0
    Apr  1 00:00:30 kernel: [   33.827272] 954 debug AE : read = 0
    Apr  1 00:00:30 kernel: [   33.831686] 954 debug AF : read = 0
    Apr  1 00:00:30 kernel: [   33.836096] 954 debug B0 : read = 8
    Apr  1 00:00:30 kernel: [   33.840513] 954 debug B1 : read = E
    Apr  1 00:00:30 kernel: [   33.844926] 954 debug B2 : read = 0
    Apr  1 00:00:30 kernel: [   33.849336] 954 debug B3 : read = 8
    Apr  1 00:00:30 kernel: [   33.853748] 954 debug B4 : read = 25
    Apr  1 00:00:30 kernel: [   33.858242] 954 debug B5 : read = 0
    Apr  1 00:00:30 kernel: [   33.862658] 954 debug B6 : read = 18
    Apr  1 00:00:30 kernel: [   33.867161] 954 debug B7 : read = 0
    Apr  1 00:00:30 kernel: [   33.871580] 954 debug B8 : read = 8C
    Apr  1 00:00:30 kernel: [   33.876079] 954 debug B9 : read = 33
    Apr  1 00:00:30 kernel: [   33.880580] 954 debug BA : read = 83
    Apr  1 00:00:30 kernel: [   33.885084] 954 debug BB : read = 74
    Apr  1 00:00:30 kernel: [   33.889586] 954 debug BC : read = 80
    Apr  1 00:00:30 kernel: [   33.894084] 954 debug BD : read = 0
    Apr  1 00:00:30 kernel: [   33.898500] 954 debug BE : read = 0
    Apr  1 00:00:30 kernel: [   33.902913] 954 debug BF : read = 0
    Apr  1 00:00:30 kernel: [   33.907320] 954 debug C0 : read = 0
    Apr  1 00:00:30 kernel: [   33.911736] 954 debug C1 : read = 0
    Apr  1 00:00:30 kernel: [   33.916145] 954 debug C2 : read = 0
    Apr  1 00:00:30 kernel: [   33.921383] 954 debug C3 : read = 0
    Apr  1 00:00:30 kernel: [   33.925794] 954 debug C4 : read = 0
    Apr  1 00:00:30 kernel: [   33.930202] 954 debug C5 : read = 0
    Apr  1 00:00:30 kernel: [   33.934621] 954 debug C6 : read = 0
    Apr  1 00:00:30 kernel: [   33.939031] 954 debug C7 : read = 0
    Apr  1 00:00:30 kernel: [   33.943438] 954 debug C8 : read = 0
    Apr  1 00:00:30 kernel: [   33.947854] 954 debug C9 : read = 0
    Apr  1 00:00:30 kernel: [   33.952263] 954 debug CA : read = 0
    Apr  1 00:00:30 kernel: [   33.956701] 954 debug CB : read = 0
    Apr  1 00:00:30 kernel: [   33.961142] 954 debug CC : read = 0
    Apr  1 00:00:30 kernel: [   33.965603] 954 debug CD : read = 0
    Apr  1 00:00:30 kernel: [   33.970077] 954 debug CE : read = 0
    Apr  1 00:00:30 kernel: [   33.974528] 954 debug CF : read = 0
    Apr  1 00:00:30 kernel: [   33.978970] 954 debug D0 : read = 0
    Apr  1 00:00:30 kernel: [   33.983423] 954 debug D1 : read = 43
    Apr  1 00:00:30 kernel: [   33.987957] 954 debug D2 : read = 94
    Apr  1 00:00:30 kernel: [   33.992878] 954 debug D3 : read = 7
    Apr  1 00:00:30 kernel: [   33.997323] 954 debug D4 : read = 60
    Apr  1 00:00:30 kernel: [   34.001870] 954 debug D5 : read = F2
    Apr  1 00:00:30 kernel: [   34.006388] 954 debug D6 : read = 0
    Apr  1 00:00:30 kernel: [   34.010835] 954 debug D7 : read = 1
    Apr  1 00:00:30 kernel: [   34.015271] 954 debug D8 : read = 0
    Apr  1 00:00:30 kernel: [   34.019716] 954 debug D9 : read = 0
    Apr  1 00:00:30 kernel: [   34.024355] 954 debug DA : read = 0
    Apr  1 00:00:30 kernel: [   34.028788] 954 debug DB : read = 8
    Apr  1 00:00:30 kernel: [   34.033211] 954 debug DC : read = 0
    Apr  1 00:00:30 kernel: [   34.037643] 954 debug DD : read = 0
    Apr  1 00:00:30 kernel: [   34.042128] 954 debug DE : read = 0
    Apr  1 00:00:30 kernel: [   34.046579] 954 debug DF : read = 0
    Apr  1 00:00:30 kernel: [   34.051011] 954 debug E0 : read = 0
    Apr  1 00:00:30 kernel: [   34.055448] 954 debug E1 : read = 0
    Apr  1 00:00:30 kernel: [   34.059909] 954 debug E2 : read = 0
    Apr  1 00:00:30 kernel: [   34.064331] 954 debug E3 : read = 0
    Apr  1 00:00:30 kernel: [   34.068803] 954 debug E4 : read = 0
    Apr  1 00:00:30 kernel: [   34.073261] 954 debug E5 : read = 0
    Apr  1 00:00:30 kernel: [   34.077703] 954 debug E6 : read = 0
    Apr  1 00:00:30 kernel: [   34.082170] 954 debug E7 : read = 0
    Apr  1 00:00:30 kernel: [   34.086676] 954 debug E8 : read = 0
    Apr  1 00:00:30 kernel: [   34.091104] 954 debug E9 : read = 0
    Apr  1 00:00:30 kernel: [   34.095553] 954 debug EA : read = 0
    Apr  1 00:00:30 kernel: [   34.099993] 954 debug EB : read = 0
    Apr  1 00:00:30 kernel: [   34.104496] 954 debug EC : read = 0
    Apr  1 00:00:30 kernel: [   34.108953] 954 debug ED : read = 0
    Apr  1 00:00:30 kernel: [   34.113389] 954 debug EE : read = 0
    Apr  1 00:00:30 kernel: [   34.117826] 954 debug EF : read = 0
    Apr  1 00:00:30 kernel: [   34.122267] 954 debug F0 : read = 5F
    Apr  1 00:00:30 kernel: [   34.127294] 954 debug F1 : read = 55
    Apr  1 00:00:30 kernel: [   34.131833] 954 debug F2 : read = 42
    Apr  1 00:00:30 kernel: [   34.136329] 954 debug F3 : read = 39
    Apr  1 00:00:30 kernel: [   34.140829] 954 debug F4 : read = 35
    Apr  1 00:00:30 kernel: [   34.145334] 954 debug F5 : read = 34
    Apr  1 00:00:30 kernel: [   34.149839] 954 debug F6 : read = 0
    Apr  1 00:00:30 kernel: [   34.154268] 954 debug F7 : read = 0
    Apr  1 00:00:30 kernel: [   34.158686] 954 debug F8 : read = 0
    Apr  1 00:00:30 kernel: [   34.163107] 954 debug F9 : read = 0
    Apr  1 00:00:30 kernel: [   34.167522] 954 debug FA : read = 0
    Apr  1 00:00:30 kernel: [   34.171952] 954 debug FB : read = 0
    Apr  1 00:00:30 kernel: [   34.176429] 954 debug FC : read = 0
    Apr  1 00:00:30 kernel: [   34.180864] 954 debug FD : read = 0
    Apr  1 00:00:30 kernel: [   34.185286] 954 debug FE : read = 0
    Apr  1 00:00:30 kernel: [   34.189765] 954 debug FF : read = 0
    Mar 15 15:35:15 Check954: DESERIALIZER_ICG 0x35= 1
    Mar 15 15:35:15 Check954: DESERIALIZER_ICG 0x37= 3
    Mar 15 15:35:15 Check954: DESERIALIZER_ICG 0x4D= 83
    Mar 15 15:35:15 Check954: DESERIALIZER_ICG 0x4E= 229
    Mar 15 15:35:15 Check954: read_ICG_RXPARERRLO_value= 1
    Mar 15 15:35:15 Check954: read_ICG_RXPARERRHI_value= 0
    Mar 15 15:35:15 kernel: [  166.811000] 954 debug 0 : read = 60
    Mar 15 15:35:15 kernel: [  166.815489] 954 debug 1 : read = 0
    Mar 15 15:35:16 kernel: [  166.820319] 954 debug 2 : read = 1E
    Mar 15 15:35:16 kernel: [  166.824733] 954 debug 3 : read = 20
    Mar 15 15:35:16 kernel: [  166.829205] 954 debug 4 : read = DF
    Mar 15 15:35:16 kernel: [  166.833668] 954 debug 5 : read = 1
    Mar 15 15:35:16 kernel: [  166.838654] 954 debug 6 : read = 0
    Mar 15 15:35:16 kernel: [  166.843102] 954 debug 7 : read = FE
    Mar 15 15:35:16 kernel: [  166.847649] 954 debug 8 : read = 1C
    Mar 15 15:35:16 kernel: [  166.853705] 954 debug 9 : read = 10
    Mar 15 15:35:16 kernel: [  166.858590] 954 debug A : read = 7A
    Mar 15 15:35:16 kernel: [  166.863031] 954 debug B : read = 7A
    Mar 15 15:35:16 kernel: [  166.870636] 954 debug C : read = AB
    Mar 15 15:35:16 kernel: [  166.875554] 954 debug D : read = 9
    Mar 15 15:35:16 kernel: [  166.879933] 954 debug E : read = 8
    Mar 15 15:35:16 kernel: [  166.887578] 954 debug F : read = 7F
    Mar 15 15:35:16 kernel: [  166.892168] 954 debug 10 : read = 0
    Mar 15 15:35:16 kernel: [  166.896699] 954 debug 11 : read = 0
    Mar 15 15:35:16 kernel: [  166.903771] 954 debug 12 : read = 0
    Mar 15 15:35:16 kernel: [  166.908534] 954 debug 13 : read = 0
    Mar 15 15:35:16 kernel: [  166.913042] 954 debug 14 : read = 0
    Mar 15 15:35:16 kernel: [  166.920407] 954 debug 15 : read = 0
    Mar 15 15:35:16 kernel: [  166.924915] 954 debug 16 : read = 0
    Mar 15 15:35:16 kernel: [  166.929457] 954 debug 17 : read = 0
    Mar 15 15:35:16 kernel: [  166.937614] 954 debug 18 : read = 10
    Mar 15 15:35:16 kernel: [  166.942200] 954 debug 19 : read = 0
    Mar 15 15:35:16 kernel: [  166.946689] 954 debug 1A : read = 0
    Mar 15 15:35:16 kernel: [  166.954389] 954 debug 1B : read = 0
    Mar 15 15:35:16 kernel: [  166.960743] 954 debug 1C : read = 0
    Mar 15 15:35:16 kernel: [  166.965212] 954 debug 1D : read = 0
    Mar 15 15:35:16 kernel: [  166.972943] 954 debug 1E : read = 4
    Mar 15 15:35:16 kernel: [  166.977665] 954 debug 1F : read = 2
    Mar 15 15:35:16 kernel: [  166.982240] 954 debug 20 : read = 10
    Mar 15 15:35:16 kernel: [  166.987086] 954 debug 21 : read = 1
    Mar 15 15:35:16 kernel: [  166.991585] 954 debug 22 : read = 0
    Mar 15 15:35:16 kernel: [  166.996211] 954 debug 23 : read = 0
    Mar 15 15:35:16 kernel: [  167.003745] 954 debug 24 : read = 0
    Mar 15 15:35:16 kernel: [  167.008319] 954 debug 25 : read = 0
    Mar 15 15:35:16 kernel: [  167.013016] 954 debug 26 : read = 0
    Mar 15 15:35:16 kernel: [  167.017511] 954 debug 27 : read = 0
    Mar 15 15:35:16 kernel: [  167.022447] 954 debug 28 : read = 0
    Mar 15 15:35:16 kernel: [  167.026872] 954 debug 29 : read = 0
    Mar 15 15:35:16 kernel: [  167.031388] 954 debug 2A : read = 0
    Mar 15 15:35:16 kernel: [  167.037034] 954 debug 2B : read = 0
    Mar 15 15:35:16 kernel: [  167.041468] 954 debug 2C : read = 0
    Mar 15 15:35:16 kernel: [  167.046108] 954 debug 2D : read = 0
    Mar 15 15:35:16 kernel: [  167.050674] 954 debug 2E : read = 0
    Mar 15 15:35:16 kernel: [  167.055128] 954 debug 2F : read = 0
    Mar 15 15:35:16 kernel: [  167.059539] 954 debug 30 : read = 0
    Mar 15 15:35:16 kernel: [  167.063953] 954 debug 31 : read = 0
    Mar 15 15:35:16 kernel: [  167.071555] 954 debug 32 : read = 0
    Mar 15 15:35:16 kernel: [  167.075964] 954 debug 33 : read = 3
    Mar 15 15:35:16 kernel: [  167.080393] 954 debug 34 : read = 40
    Mar 15 15:35:16 kernel: [  167.084902] 954 debug 35 : read = 1
    Mar 15 15:35:16 kernel: [  167.089318] 954 debug 36 : read = 0
    Mar 15 15:35:16 kernel: [  167.093742] 954 debug 37 : read = 0
    Mar 15 15:35:16 kernel: [  167.098156] 954 debug 38 : read = 0
    Mar 15 15:35:16 kernel: [  167.102579] 954 debug 39 : read = 0
    Mar 15 15:35:16 kernel: [  167.107008] 954 debug 3A : read = 0
    Mar 15 15:35:16 kernel: [  167.111419] 954 debug 3B : read = 1
    Mar 15 15:35:16 kernel: [  167.115826] 954 debug 3C : read = 14
    Mar 15 15:35:16 kernel: [  167.120344] 954 debug 3D : read = 6F
    Mar 15 15:35:16 kernel: [  167.124859] 954 debug 3E : read = 0
    Mar 15 15:35:16 kernel: [  167.129276] 954 debug 3F : read = 40
    Mar 15 15:35:16 kernel: [  167.133789] 954 debug 40 : read = 0
    Mar 15 15:35:16 kernel: [  167.138208] 954 debug 41 : read = E0
    Mar 15 15:35:16 kernel: [  167.142708] 954 debug 42 : read = 71
    Mar 15 15:35:16 kernel: [  167.147220] 954 debug 43 : read = 1
    Mar 15 15:35:16 kernel: [  167.151644] 954 debug 44 : read = 0
    Mar 15 15:35:16 kernel: [  167.156078] 954 debug 45 : read = 0
    Mar 15 15:35:16 kernel: [  167.160502] 954 debug 46 : read = 0
    Mar 15 15:35:16 kernel: [  167.166589] 954 debug 47 : read = 0
    Mar 15 15:35:16 kernel: [  167.171020] 954 debug 48 : read = 0
    Mar 15 15:35:16 kernel: [  167.175436] 954 debug 49 : read = 0
    Mar 15 15:35:16 kernel: [  167.179843] 954 debug 4A : read = 0
    Mar 15 15:35:16 kernel: [  167.184268] 954 debug 4B : read = 12
    Mar 15 15:35:16 kernel: [  167.188765] 954 debug 4C : read = 12
    Mar 15 15:35:16 kernel: [  167.193265] 954 debug 4D : read = 43
    Mar 15 15:35:16 kernel: [  167.197762] 954 debug 4E : read = C
    Mar 15 15:35:16 kernel: [  167.202188] 954 debug 4F : read = 64
    Mar 15 15:35:16 kernel: [  167.206684] 954 debug 50 : read = 0
    Mar 15 15:35:16 kernel: [  167.211098] 954 debug 51 : read = 0
    Mar 15 15:35:16 kernel: [  167.215506] 954 debug 52 : read = 0
    Mar 15 15:35:16 kernel: [  167.219935] 954 debug 53 : read = 4
    Mar 15 15:35:16 kernel: [  167.224347] 954 debug 54 : read = 0
    Mar 15 15:35:16 kernel: [  167.228754] 954 debug 55 : read = 0
    Mar 15 15:35:16 kernel: [  167.233169] 954 debug 56 : read = 1
    Mar 15 15:35:16 kernel: [  167.237592] 954 debug 57 : read = 0
    Mar 15 15:35:16 kernel: [  167.242007] 954 debug 58 : read = 5E
    Mar 15 15:35:16 kernel: [  167.247225] 954 debug 59 : read = 0
    Mar 15 15:35:16 kernel: [  167.251902] 954 debug 5A : read = 0
    Mar 15 15:35:16 kernel: [  167.256808] 954 debug 5B : read = 32
    Mar 15 15:35:16 kernel: [  167.261481] 954 debug 5C : read = 32
    Mar 15 15:35:16 kernel: [  167.266085] 954 debug 5D : read = 1C
    Mar 15 15:35:16 kernel: [  167.273770] 954 debug 5E : read = 6C
    Mar 15 15:35:16 kernel: [  167.278381] 954 debug 5F : read = 6E
    Mar 15 15:35:16 kernel: [  167.283192] 954 debug 60 : read = 52
    Mar 15 15:35:16 kernel: [  167.288002] 954 debug 61 : read = D0
    Mar 15 15:35:16 kernel: [  167.292670] 954 debug 62 : read = 6A
    Mar 15 15:35:16 kernel: [  167.297225] 954 debug 63 : read = 0
    Mar 15 15:35:16 kernel: [  167.302636] 954 debug 64 : read = 0
    Mar 15 15:35:16 kernel: [  167.307759] 954 debug 65 : read = 1C
    Mar 15 15:35:16 kernel: [  167.312949] 954 debug 66 : read = 6C
    Mar 15 15:35:16 kernel: [  167.317594] 954 debug 67 : read = 6E
    Mar 15 15:35:16 kernel: [  167.322141] 954 debug 68 : read = 52
    Mar 15 15:35:16 kernel: [  167.326968] 954 debug 69 : read = D0
    Mar 15 15:35:16 kernel: [  167.331508] 954 debug 6A : read = 6A
    Mar 15 15:35:16 kernel: [  167.336561] 954 debug 6B : read = 0
    Mar 15 15:35:16 kernel: [  167.341027] 954 debug 6C : read = 0
    Mar 15 15:35:16 kernel: [  167.345465] 954 debug 6D : read = 7C
    Mar 15 15:35:16 kernel: [  167.350332] 954 debug 6E : read = 88
    Mar 15 15:35:16 kernel: [  167.354856] 954 debug 6F : read = 88
    Mar 15 15:35:16 kernel: [  167.359379] 954 debug 70 : read = 6B
    Mar 15 15:35:16 kernel: [  167.364223] 954 debug 71 : read = 6C
    Mar 15 15:35:16 kernel: [  167.368788] 954 debug 72 : read = E4
    Mar 15 15:35:16 kernel: [  167.373330] 954 debug 73 : read = 2
    Mar 15 15:35:16 kernel: [  167.378097] 954 debug 74 : read = DC
    Mar 15 15:35:16 kernel: [  167.382637] 954 debug 75 : read = F
    Mar 15 15:35:16 kernel: [  167.388101] 954 debug 76 : read = 30
    Mar 15 15:35:16 kernel: [  167.393463] 954 debug 77 : read = C5
    Mar 15 15:35:16 kernel: [  167.398678] 954 debug 78 : read = 0
    Mar 15 15:35:16 kernel: [  167.403604] 954 debug 79 : read = 1
    Mar 15 15:35:16 kernel: [  167.408452] 954 debug 7A : read = 4
    Mar 15 15:35:16 kernel: [  167.413190] 954 debug 7B : read = 90
    Mar 15 15:35:16 kernel: [  167.417833] 954 debug 7C : read = 20
    Mar 15 15:35:16 kernel: [  167.422519] 954 debug 7D : read = 0
    Mar 15 15:35:16 kernel: [  167.426988] 954 debug 7E : read = 0
    Mar 15 15:35:16 kernel: [  167.431676] 954 debug 7F : read = 0
    Mar 15 15:35:16 kernel: [  167.436138] 954 debug 80 : read = 0
    Mar 15 15:35:16 kernel: [  167.440568] 954 debug 81 : read = 0
    Mar 15 15:35:16 kernel: [  167.445012] 954 debug 82 : read = 0
    Mar 15 15:35:16 kernel: [  167.449552] 954 debug 83 : read = 0
    Mar 15 15:35:16 kernel: [  167.454074] 954 debug 84 : read = 0
    Mar 15 15:35:16 kernel: [  167.458500] 954 debug 85 : read = 0
    Mar 15 15:35:16 kernel: [  167.462930] 954 debug 86 : read = 0
    Mar 15 15:35:16 kernel: [  167.467401] 954 debug 87 : read = 0
    Mar 15 15:35:16 kernel: [  167.471848] 954 debug 88 : read = 0
    Mar 15 15:35:16 kernel: [  167.476870] 954 debug 89 : read = 0
    Mar 15 15:35:16 kernel: [  167.483942] 954 debug 8A : read = 0
    Mar 15 15:35:16 kernel: [  167.488403] 954 debug 8B : read = 0
    Mar 15 15:35:16 kernel: [  167.493546] 954 debug 8C : read = 0
    Mar 15 15:35:16 kernel: [  167.499132] 954 debug 8D : read = 0
    Mar 15 15:35:16 kernel: [  167.504134] 954 debug 8E : read = 0
    Mar 15 15:35:16 kernel: [  167.509714] 954 debug 8F : read = 0
    Mar 15 15:35:16 kernel: [  167.514141] 954 debug 90 : read = 0
    Mar 15 15:35:16 kernel: [  167.518607] 954 debug 91 : read = 0
    Mar 15 15:35:16 kernel: [  167.523084] 954 debug 92 : read = 0
    Mar 15 15:35:16 kernel: [  167.527507] 954 debug 93 : read = 0
    Mar 15 15:35:16 kernel: [  167.531936] 954 debug 94 : read = 0
    Mar 15 15:35:16 kernel: [  167.536417] 954 debug 95 : read = 0
    Mar 15 15:35:16 kernel: [  167.540851] 954 debug 96 : read = 0
    Mar 15 15:35:16 kernel: [  167.545298] 954 debug 97 : read = 0
    Mar 15 15:35:16 kernel: [  167.549772] 954 debug 98 : read = 0
    Mar 15 15:35:16 kernel: [  167.554271] 954 debug 99 : read = 0
    Mar 15 15:35:16 kernel: [  167.558693] 954 debug 9A : read = 0
    Mar 15 15:35:16 kernel: [  167.563142] 954 debug 9B : read = 0
    Mar 15 15:35:16 kernel: [  167.567592] 954 debug 9C : read = 0
    Mar 15 15:35:16 kernel: [  167.572053] 954 debug 9D : read = 0
    Mar 15 15:35:16 kernel: [  167.576491] 954 debug 9E : read = 0
    Mar 15 15:35:16 kernel: [  167.580935] 954 debug 9F : read = 0
    Mar 15 15:35:16 kernel: [  167.588263] 954 debug A0 : read = 2
    Mar 15 15:35:16 kernel: [  167.592682] 954 debug A1 : read = F
    Mar 15 15:35:16 kernel: [  167.597108] 954 debug A2 : read = 0
    Mar 15 15:35:16 kernel: [  167.601576] 954 debug A3 : read = 0
    Mar 15 15:35:16 kernel: [  167.606050] 954 debug A4 : read = 8
    Mar 15 15:35:16 kernel: [  167.610480] 954 debug A5 : read = 19
    Mar 15 15:35:16 kernel: [  167.615018] 954 debug A6 : read = 0
    Mar 15 15:35:16 kernel: [  167.619525] 954 debug A7 : read = 0
    Mar 15 15:35:16 kernel: [  167.623991] 954 debug A8 : read = 0
    Mar 15 15:35:16 kernel: [  167.628534] 954 debug A9 : read = 0
    Mar 15 15:35:16 kernel: [  167.633034] 954 debug AA : read = 0
    Mar 15 15:35:16 kernel: [  167.638116] 954 debug AB : read = 0
    Mar 15 15:35:16 kernel: [  167.642596] 954 debug AC : read = 0
    Mar 15 15:35:16 kernel: [  167.647089] 954 debug AD : read = 0
    Mar 15 15:35:16 kernel: [  167.651721] 954 debug AE : read = 0
    Mar 15 15:35:16 kernel: [  167.656614] 954 debug AF : read = 0
    Mar 15 15:35:16 kernel: [  167.661106] 954 debug B0 : read = 8
    Mar 15 15:35:16 kernel: [  167.665596] 954 debug B1 : read = E
    Mar 15 15:35:16 kernel: [  167.670565] 954 debug B2 : read = 0
    Mar 15 15:35:16 kernel: [  167.676549] 954 debug B3 : read = 8
    Mar 15 15:35:16 kernel: [  167.681086] 954 debug B4 : read = 25
    Mar 15 15:35:16 kernel: [  167.685797] 954 debug B5 : read = 0
    Mar 15 15:35:16 kernel: [  167.692899] 954 debug B6 : read = 18
    Mar 15 15:35:16 kernel: [  167.697473] 954 debug B7 : read = 0
    Mar 15 15:35:16 kernel: [  167.702028] 954 debug B8 : read = 8C
    Mar 15 15:35:16 kernel: [  167.707172] 954 debug B9 : read = 33
    Mar 15 15:35:16 kernel: [  167.711737] 954 debug BA : read = 83
    Mar 15 15:35:16 kernel: [  167.716555] 954 debug BB : read = 74
    Mar 15 15:35:16 kernel: [  167.722024] 954 debug BC : read = 80
    Mar 15 15:35:16 kernel: [  167.726670] 954 debug BD : read = 0
    Mar 15 15:35:16 kernel: [  167.731269] 954 debug BE : read = 0
    Mar 15 15:35:16 kernel: [  167.735784] 954 debug BF : read = 0
    Mar 15 15:35:16 kernel: [  167.740961] 954 debug C0 : read = 0
    Mar 15 15:35:16 kernel: [  167.745566] 954 debug C1 : read = 0
    Mar 15 15:35:16 kernel: [  167.750205] 954 debug C2 : read = 0
    Mar 15 15:35:16 kernel: [  167.755248] 954 debug C3 : read = 0
    Mar 15 15:35:16 kernel: [  167.759727] 954 debug C4 : read = 0
    Mar 15 15:35:16 kernel: [  167.764204] 954 debug C5 : read = 0
    Mar 15 15:35:16 kernel: [  167.768730] 954 debug C6 : read = 0
    Mar 15 15:35:16 kernel: [  167.773607] 954 debug C7 : read = 0
    Mar 15 15:35:16 kernel: [  167.778096] 954 debug C8 : read = 0
    Mar 15 15:35:16 kernel: [  167.782562] 954 debug C9 : read = 0
    Mar 15 15:35:16 kernel: [  167.787494] 954 debug CA : read = 0
    Mar 15 15:35:16 kernel: [  167.791924] 954 debug CB : read = 0
    Mar 15 15:35:16 kernel: [  167.798994] 954 debug CC : read = 0
    Mar 15 15:35:16 kernel: [  167.803508] 954 debug CD : read = 0
    Mar 15 15:35:16 kernel: [  167.807936] 954 debug CE : read = 0
    Mar 15 15:35:16 kernel: [  167.812365] 954 debug CF : read = 0
    Mar 15 15:35:16 kernel: [  167.816813] 954 debug D0 : read = 0
    Mar 15 15:35:17 kernel: [  167.821278] 954 debug D1 : read = 43
    Mar 15 15:35:17 kernel: [  167.825799] 954 debug D2 : read = 94
    Mar 15 15:35:17 kernel: [  167.830315] 954 debug D3 : read = 5
    Mar 15 15:35:17 kernel: [  167.834782] 954 debug D4 : read = 60
    Mar 15 15:35:17 kernel: [  167.839332] 954 debug D5 : read = F2
    Mar 15 15:35:17 kernel: [  167.843848] 954 debug D6 : read = 0
    Mar 15 15:35:17 kernel: [  167.848287] 954 debug D7 : read = 1
    Mar 15 15:35:17 kernel: [  167.852798] 954 debug D8 : read = 0
    Mar 15 15:35:17 kernel: [  167.857269] 954 debug D9 : read = 0
    Mar 15 15:35:17 kernel: [  167.861696] 954 debug DA : read = 0
    Mar 15 15:35:17 kernel: [  167.866135] 954 debug DB : read = 0
    Mar 15 15:35:17 kernel: [  167.870636] 954 debug DC : read = 0
    Mar 15 15:35:17 kernel: [  167.875073] 954 debug DD : read = 0
    Mar 15 15:35:17 kernel: [  167.880068] 954 debug DE : read = 0
    Mar 15 15:35:17 kernel: [  167.884520] 954 debug DF : read = 0
    Mar 15 15:35:17 kernel: [  167.889002] 954 debug E0 : read = 0
    Mar 15 15:35:17 kernel: [  167.893436] 954 debug E1 : read = 0
    Mar 15 15:35:17 kernel: [  167.897859] 954 debug E2 : read = 0
    Mar 15 15:35:17 kernel: [  167.904932] 954 debug E3 : read = 0
    Mar 15 15:35:17 kernel: [  167.909361] 954 debug E4 : read = 0
    Mar 15 15:35:17 kernel: [  167.913786] 954 debug E5 : read = 0
    Mar 15 15:35:17 kernel: [  167.918219] 954 debug E6 : read = 0
    Mar 15 15:35:17 kernel: [  167.922685] 954 debug E7 : read = 0
    Mar 15 15:35:17 kernel: [  167.927117] 954 debug E8 : read = 0
    Mar 15 15:35:17 kernel: [  167.931540] 954 debug E9 : read = 0
    Mar 15 15:35:17 kernel: [  167.935959] 954 debug EA : read = 0
    Mar 15 15:35:17 kernel: [  167.940382] 954 debug EB : read = 0
    Mar 15 15:35:17 kernel: [  167.944816] 954 debug EC : read = 0
    Mar 15 15:35:17 kernel: [  167.949237] 954 debug ED : read = 0
    Mar 15 15:35:17 kernel: [  167.953689] 954 debug EE : read = 0
    Mar 15 15:35:17 kernel: [  167.958126] 954 debug EF : read = 0
    Mar 15 15:35:17 kernel: [  167.962567] 954 debug F0 : read = 5F
    Mar 15 15:35:17 kernel: [  167.967091] 954 debug F1 : read = 55
    Mar 15 15:35:17 kernel: [  167.971616] 954 debug F2 : read = 42
    Mar 15 15:35:17 kernel: [  167.976136] 954 debug F3 : read = 39
    Mar 15 15:35:17 kernel: [  167.980666] 954 debug F4 : read = 35
    Mar 15 15:35:17 kernel: [  167.985423] 954 debug F5 : read = 34
    Mar 15 15:35:17 kernel: [  167.990141] 954 debug F6 : read = 0
    Mar 15 15:35:17 kernel: [  167.994597] 954 debug F7 : read = 0
    Mar 15 15:35:17 kernel: [  167.999157] 954 debug F8 : read = 0
    Mar 15 15:35:17 kernel: [  168.003728] 954 debug F9 : read = 0
    Mar 15 15:35:17 kernel: [  168.010864] 954 debug FA : read = 0
    Mar 15 15:35:17 kernel: [  168.015369] 954 debug FB : read = 0
    Mar 15 15:35:17 kernel: [  168.020009] 954 debug FC : read = 0
    Mar 15 15:35:17 kernel: [  168.024553] 954 debug FD : read = 0
    Mar 15 15:35:17 kernel: [  168.029028] 954 debug FE : read = 0
    Mar 15 15:35:17 kernel: [  168.033593] 954 debug FF : read = 0
    Mar 15 15:35:17 Check954: DESERIALIZER_ICG 0x35= 1
    Mar 15 15:35:17 Check954: DESERIALIZER_ICG 0x37= 3
    Mar 15 15:35:17 Check954: DESERIALIZER_ICG 0x4D= 83
    Mar 15 15:35:17 Check954: DESERIALIZER_ICG 0x4E= 101
    Mar 15 15:35:17 Check954: read_ICG_RXPARERRLO_value= 0
    Mar 15 15:35:17 Check954: read_ICG_RXPARERRHI_value= 0
    Mar 15 15:35:17 kernel: [  168.522429] 954 debug 0 : read = 60
    Mar 15 15:35:17 kernel: [  168.527025] 954 debug 1 : read = 0
    Mar 15 15:35:17 kernel: [  168.531528] 954 debug 2 : read = 1E
    Mar 15 15:35:17 kernel: [  168.536025] 954 debug 3 : read = 20
    Mar 15 15:35:17 kernel: [  168.540526] 954 debug 4 : read = DF
    Mar 15 15:35:17 kernel: [  168.544978] 954 debug 5 : read = 1
    Mar 15 15:35:17 kernel: [  168.549357] 954 debug 6 : read = 0
    Mar 15 15:35:17 kernel: [  168.553842] 954 debug 7 : read = FE
    Mar 15 15:35:17 kernel: [  168.558339] 954 debug 8 : read = 1C
    Mar 15 15:35:17 kernel: [  168.562877] 954 debug 9 : read = 10
    Mar 15 15:35:17 kernel: [  168.567401] 954 debug A : read = 7A
    Mar 15 15:35:17 kernel: [  168.574499] 954 debug B : read = 7A
    Mar 15 15:35:17 kernel: [  168.578986] 954 debug C : read = AB
    Mar 15 15:35:17 kernel: [  168.583463] 954 debug D : read = 9
    Mar 15 15:35:17 kernel: [  168.587912] 954 debug E : read = 8
    Mar 15 15:35:17 kernel: [  168.592286] 954 debug F : read = 7F
    Mar 15 15:35:17 kernel: [  168.596823] 954 debug 10 : read = 0
    Mar 15 15:35:17 kernel: [  168.601362] 954 debug 11 : read = 0
    Mar 15 15:35:17 kernel: [  168.606672] 954 debug 12 : read = 0
    Mar 15 15:35:17 kernel: [  168.611112] 954 debug 13 : read = 0
    Mar 15 15:35:17 kernel: [  168.615561] 954 debug 14 : read = 0
    Mar 15 15:35:17 kernel: [  168.620066] 954 debug 15 : read = 0
    Mar 15 15:35:17 kernel: [  168.624500] 954 debug 16 : read = 0
    Mar 15 15:35:17 kernel: [  168.629726] 954 debug 17 : read = 0
    Mar 15 15:35:17 kernel: [  168.634922] 954 debug 18 : read = 10
    Mar 15 15:35:17 kernel: [  168.640775] 954 debug 19 : read = 0
    Mar 15 15:35:17 kernel: [  168.646536] 954 debug 1A : read = 0
    Mar 15 15:35:17 kernel: [  168.652298] 954 debug 1B : read = 0
    Mar 15 15:35:17 kernel: [  168.658065] 954 debug 1C : read = 0
    Mar 15 15:35:17 kernel: [  168.663830] 954 debug 1D : read = 0
    Mar 15 15:35:17 kernel: [  168.668337] 954 debug 1E : read = 4
    Mar 15 15:35:17 kernel: [  168.673116] 954 debug 1F : read = 2
    Mar 15 15:35:17 kernel: [  168.681018] 954 debug 20 : read = 10
    Mar 15 15:35:17 kernel: [  168.686552] 954 debug 21 : read = 1
    Mar 15 15:35:17 kernel: [  168.691134] 954 debug 22 : read = 0
    Mar 15 15:35:17 kernel: [  168.696100] 954 debug 23 : read = 0
    Mar 15 15:35:17 kernel: [  168.701528] 954 debug 24 : read = 0
    Mar 15 15:35:17 kernel: [  168.706829] 954 debug 25 : read = 0
    Mar 15 15:35:17 kernel: [  168.712735] 954 debug 26 : read = 0
    Mar 15 15:35:17 kernel: [  168.717201] 954 debug 27 : read = 0
    Mar 15 15:35:17 kernel: [  168.721751] 954 debug 28 : read = 0
    Mar 15 15:35:17 kernel: [  168.726253] 954 debug 29 : read = 0
    Mar 15 15:35:17 kernel: [  168.730701] 954 debug 2A : read = 0
    Mar 15 15:35:17 kernel: [  168.735359] 954 debug 2B : read = 0
    Mar 15 15:35:17 kernel: [  168.739863] 954 debug 2C : read = 0
    Mar 15 15:35:17 kernel: [  168.744314] 954 debug 2D : read = 0
    Mar 15 15:35:17 kernel: [  168.748814] 954 debug 2E : read = 0
    Mar 15 15:35:17 kernel: [  168.753306] 954 debug 2F : read = 0
    Mar 15 15:35:17 kernel: [  168.757761] 954 debug 30 : read = 0
    Mar 15 15:35:17 kernel: [  168.762251] 954 debug 31 : read = 0
    Mar 15 15:35:17 kernel: [  168.766688] 954 debug 32 : read = 0
    Mar 15 15:35:17 kernel: [  168.771176] 954 debug 33 : read = 3
    Mar 15 15:35:17 kernel: [  168.775662] 954 debug 34 : read = 40
    Mar 15 15:35:17 kernel: [  168.780230] 954 debug 35 : read = 1
    Mar 15 15:35:17 kernel: [  168.784664] 954 debug 36 : read = 0
    Mar 15 15:35:17 kernel: [  168.789275] 954 debug 37 : read = 0
    Mar 15 15:35:17 kernel: [  168.793713] 954 debug 38 : read = 0
    Mar 15 15:35:17 kernel: [  168.798155] 954 debug 39 : read = 0
    Mar 15 15:35:17 kernel: [  168.802642] 954 debug 3A : read = 0
    Mar 15 15:35:17 kernel: [  168.807143] 954 debug 3B : read = 1
    Mar 15 15:35:17 kernel: [  168.811584] 954 debug 3C : read = 14
    Mar 15 15:35:17 kernel: [  168.816230] 954 debug 3D : read = 6F
    Mar 15 15:35:17 kernel: [  168.820842] 954 debug 3E : read = 0
    Mar 15 15:35:18 kernel: [  168.825327] 954 debug 3F : read = 40
    Mar 15 15:35:18 kernel: [  168.829926] 954 debug 40 : read = 0
    Mar 15 15:35:18 kernel: [  168.834382] 954 debug 41 : read = E0
    Mar 15 15:35:18 kernel: [  168.838990] 954 debug 42 : read = 71
    Mar 15 15:35:18 kernel: [  168.843580] 954 debug 43 : read = 1
    Mar 15 15:35:18 kernel: [  168.848028] 954 debug 44 : read = 0
    Mar 15 15:35:18 kernel: [  168.852461] 954 debug 45 : read = 0
    Mar 15 15:35:18 kernel: [  168.856938] 954 debug 46 : read = 0
    Mar 15 15:35:18 kernel: [  168.861358] 954 debug 47 : read = 0
    Mar 15 15:35:18 kernel: [  168.865769] 954 debug 48 : read = 0
    Mar 15 15:35:18 kernel: [  168.870231] 954 debug 49 : read = 0
    Mar 15 15:35:18 kernel: [  168.874644] 954 debug 4A : read = 0
    Mar 15 15:35:18 kernel: [  168.879062] 954 debug 4B : read = 12
    Mar 15 15:35:18 kernel: [  168.883581] 954 debug 4C : read = 12
    Mar 15 15:35:18 kernel: [  168.888096] 954 debug 4D : read = 43
    Mar 15 15:35:18 kernel: [  168.892595] 954 debug 4E : read = 4
    Mar 15 15:35:18 kernel: [  168.897027] 954 debug 4F : read = 63
    Mar 15 15:35:18 kernel: [  168.901525] 954 debug 50 : read = 0
    Mar 15 15:35:18 kernel: [  168.905945] 954 debug 51 : read = 0
    Mar 15 15:35:18 kernel: [  168.910376] 954 debug 52 : read = 0
    Mar 15 15:35:18 kernel: [  168.914783] 954 debug 53 : read = 4
    Mar 15 15:35:18 kernel: [  168.919202] 954 debug 54 : read = 0
    Mar 15 15:35:18 kernel: [  168.923630] 954 debug 55 : read = 0
    Mar 15 15:35:18 kernel: [  168.928048] 954 debug 56 : read = 0
    Mar 15 15:35:18 kernel: [  168.932461] 954 debug 57 : read = 0
    Mar 15 15:35:18 kernel: [  168.936890] 954 debug 58 : read = 5E
    Mar 15 15:35:18 kernel: [  168.941396] 954 debug 59 : read = 0
    Mar 15 15:35:18 kernel: [  168.945806] 954 debug 5A : read = 0
    Mar 15 15:35:18 kernel: [  168.950237] 954 debug 5B : read = 32
    Mar 15 15:35:18 kernel: [  168.954737] 954 debug 5C : read = 32
    Mar 15 15:35:18 kernel: [  168.959243] 954 debug 5D : read = 1C
    Mar 15 15:35:18 kernel: [  168.963757] 954 debug 5E : read = 6C
    Mar 15 15:35:18 kernel: [  168.968264] 954 debug 5F : read = 6E
    Mar 15 15:35:18 kernel: [  168.972762] 954 debug 60 : read = 52
    Mar 15 15:35:18 kernel: [  168.977281] 954 debug 61 : read = D0
    Mar 15 15:35:18 kernel: [  168.981778] 954 debug 62 : read = 6A
    Mar 15 15:35:18 kernel: [  168.986283] 954 debug 63 : read = 0
    Mar 15 15:35:18 kernel: [  168.990709] 954 debug 64 : read = 0
    Mar 15 15:35:18 kernel: [  168.995124] 954 debug 65 : read = 1C
    Mar 15 15:35:18 kernel: [  168.999624] 954 debug 66 : read = 6C
    Mar 15 15:35:18 kernel: [  169.004147] 954 debug 67 : read = 6E
    Mar 15 15:35:18 kernel: [  169.008647] 954 debug 68 : read = 52
    Mar 15 15:35:18 kernel: [  169.013153] 954 debug 69 : read = D0
    Mar 15 15:35:18 kernel: [  169.017667] 954 debug 6A : read = 6A
    Mar 15 15:35:18 kernel: [  169.022171] 954 debug 6B : read = 0
    Mar 15 15:35:18 kernel: [  169.026582] 954 debug 6C : read = 0
    Mar 15 15:35:18 kernel: [  169.031012] 954 debug 6D : read = 7C
    Mar 15 15:35:18 kernel: [  169.035508] 954 debug 6E : read = 88
    Mar 15 15:35:18 kernel: [  169.040011] 954 debug 6F : read = 88
    Mar 15 15:35:18 kernel: [  169.044526] 954 debug 70 : read = 6B
    Mar 15 15:35:18 kernel: [  169.049031] 954 debug 71 : read = 6C
    Mar 15 15:35:18 kernel: [  169.053585] 954 debug 72 : read = E4
    Mar 15 15:35:18 kernel: [  169.058187] 954 debug 73 : read = 2
    Mar 15 15:35:18 kernel: [  169.062622] 954 debug 74 : read = DC
    Mar 15 15:35:18 kernel: [  169.067193] 954 debug 75 : read = F
    Mar 15 15:35:18 kernel: [  169.071684] 954 debug 76 : read = 30
    Mar 15 15:35:18 kernel: [  169.076218] 954 debug 77 : read = C5
    Mar 15 15:35:18 kernel: [  169.080741] 954 debug 78 : read = 0
    Mar 15 15:35:18 kernel: [  169.085229] 954 debug 79 : read = 1
    Mar 15 15:35:18 kernel: [  169.089663] 954 debug 7A : read = 0
    Mar 15 15:35:18 kernel: [  169.094108] 954 debug 7B : read = A7
    Mar 15 15:35:18 kernel: [  169.098665] 954 debug 7C : read = 20
    Mar 15 15:35:18 kernel: [  169.103205] 954 debug 7D : read = 0
    Mar 15 15:35:18 kernel: [  169.107668] 954 debug 7E : read = 0
    Mar 15 15:35:18 kernel: [  169.112161] 954 debug 7F : read = 0
    Mar 15 15:35:18 kernel: [  169.116609] 954 debug 80 : read = 0
    Mar 15 15:35:18 kernel: [  169.121076] 954 debug 81 : read = 0
    Mar 15 15:35:18 kernel: [  169.125553] 954 debug 82 : read = 0
    Mar 15 15:35:18 kernel: [  169.130000] 954 debug 83 : read = 0
    Mar 15 15:35:18 kernel: [  169.134439] 954 debug 84 : read = 0
    Mar 15 15:35:18 kernel: [  169.138959] 954 debug 85 : read = 0
    Mar 15 15:35:18 kernel: [  169.143423] 954 debug 86 : read = 0
    Mar 15 15:35:18 kernel: [  169.147868] 954 debug 87 : read = 0
    Mar 15 15:35:18 kernel: [  169.152392] 954 debug 88 : read = 0
    Mar 15 15:35:18 kernel: [  169.156827] 954 debug 89 : read = 0
    Mar 15 15:35:18 kernel: [  169.161295] 954 debug 8A : read = 0
    Mar 15 15:35:18 kernel: [  169.165793] 954 debug 8B : read = 0
    Mar 15 15:35:18 kernel: [  169.170254] 954 debug 8C : read = 0
    Mar 15 15:35:18 kernel: [  169.174710] 954 debug 8D : read = 0
    Mar 15 15:35:18 kernel: [  169.179223] 954 debug 8E : read = 0
    Mar 15 15:35:18 kernel: [  169.183681] 954 debug 8F : read = 0
    Mar 15 15:35:18 kernel: [  169.188144] 954 debug 90 : read = 0
    Mar 15 15:35:18 kernel: [  169.192937] 954 debug 91 : read = 0
    Mar 15 15:35:18 kernel: [  169.197464] 954 debug 92 : read = 0
    Mar 15 15:35:18 kernel: [  169.201910] 954 debug 93 : read = 0
    Mar 15 15:35:18 kernel: [  169.206355] 954 debug 94 : read = 0
    Mar 15 15:35:18 kernel: [  169.210810] 954 debug 95 : read = 0
    Mar 15 15:35:18 kernel: [  169.215237] 954 debug 96 : read = 0
    Mar 15 15:35:18 kernel: [  169.219664] 954 debug 97 : read = 0
    Mar 15 15:35:18 kernel: [  169.224108] 954 debug 98 : read = 0
    Mar 15 15:35:18 kernel: [  169.228524] 954 debug 99 : read = 0
    Mar 15 15:35:18 kernel: [  169.232956] 954 debug 9A : read = 0
    Mar 15 15:35:18 kernel: [  169.237405] 954 debug 9B : read = 0
    Mar 15 15:35:18 kernel: [  169.241828] 954 debug 9C : read = 0
    Mar 15 15:35:18 kernel: [  169.246252] 954 debug 9D : read = 0
    Mar 15 15:35:18 kernel: [  169.250662] 954 debug 9E : read = 0
    Mar 15 15:35:18 kernel: [  169.255079] 954 debug 9F : read = 0
    Mar 15 15:35:18 kernel: [  169.259494] 954 debug A0 : read = 2
    Mar 15 15:35:18 kernel: [  169.263908] 954 debug A1 : read = F
    Mar 15 15:35:18 kernel: [  169.268321] 954 debug A2 : read = 0
    Mar 15 15:35:18 kernel: [  169.272752] 954 debug A3 : read = 0
    Mar 15 15:35:18 kernel: [  169.277175] 954 debug A4 : read = 8
    Mar 15 15:35:18 kernel: [  169.281592] 954 debug A5 : read = 19
    Mar 15 15:35:18 kernel: [  169.286113] 954 debug A6 : read = 0
    Mar 15 15:35:18 kernel: [  169.290533] 954 debug A7 : read = 0
    Mar 15 15:35:18 kernel: [  169.294954] 954 debug A8 : read = 0
    Mar 15 15:35:18 kernel: [  169.299384] 954 debug A9 : read = 0
    Mar 15 15:35:18 kernel: [  169.303808] 954 debug AA : read = 0
    Mar 15 15:35:18 kernel: [  169.308232] 954 debug AB : read = 0
    Mar 15 15:35:18 kernel: [  169.312674] 954 debug AC : read = 0
    Mar 15 15:35:18 kernel: [  169.317091] 954 debug AD : read = 0
    Mar 15 15:35:18 kernel: [  169.321500] 954 debug AE : read = 0
    Mar 15 15:35:18 kernel: [  169.325935] 954 debug AF : read = 0
    Mar 15 15:35:18 kernel: [  169.330359] 954 debug B0 : read = 8
    Mar 15 15:35:18 kernel: [  169.334780] 954 debug B1 : read = E
    Mar 15 15:35:18 kernel: [  169.339210] 954 debug B2 : read = 0
    Mar 15 15:35:18 kernel: [  169.343633] 954 debug B3 : read = 8
    Mar 15 15:35:18 kernel: [  169.348065] 954 debug B4 : read = 25
    Mar 15 15:35:18 kernel: [  169.352568] 954 debug B5 : read = 0
    Mar 15 15:35:18 kernel: [  169.356997] 954 debug B6 : read = 18
    Mar 15 15:35:18 kernel: [  169.361509] 954 debug B7 : read = 0
    Mar 15 15:35:18 kernel: [  169.365964] 954 debug B8 : read = 8C
    Mar 15 15:35:18 kernel: [  169.370478] 954 debug B9 : read = 33
    Mar 15 15:35:18 kernel: [  169.374976] 954 debug BA : read = 83
    Mar 15 15:35:18 kernel: [  169.379501] 954 debug BB : read = 74
    Mar 15 15:35:18 kernel: [  169.383998] 954 debug BC : read = 80
    Mar 15 15:35:18 kernel: [  169.388510] 954 debug BD : read = 0
    Mar 15 15:35:18 kernel: [  169.392936] 954 debug BE : read = 0
    Mar 15 15:35:18 kernel: [  169.397380] 954 debug BF : read = 0
    Mar 15 15:35:18 kernel: [  169.402129] 954 debug C0 : read = 0
    Mar 15 15:35:18 kernel: [  169.406552] 954 debug C1 : read = 0
    Mar 15 15:35:18 kernel: [  169.410969] 954 debug C2 : read = 0
    Mar 15 15:35:18 kernel: [  169.415422] 954 debug C3 : read = 0
    Mar 15 15:35:18 kernel: [  169.423987] 954 debug C4 : read = 0
    Mar 15 15:35:18 kernel: [  169.428457] 954 debug C5 : read = 0
    Mar 15 15:35:18 kernel: [  169.432916] 954 debug C6 : read = 0
    Mar 15 15:35:18 kernel: [  169.437400] 954 debug C7 : read = 0
    Mar 15 15:35:18 kernel: [  169.441844] 954 debug C8 : read = 0
    Mar 15 15:35:18 kernel: [  169.446275] 954 debug C9 : read = 0
    Mar 15 15:35:18 kernel: [  169.450710] 954 debug CA : read = 0
    Mar 15 15:35:18 kernel: [  169.456245] 954 debug CB : read = 0
    Mar 15 15:35:18 kernel: [  169.461751] 954 debug CC : read = 0
    Mar 15 15:35:18 kernel: [  169.466392] 954 debug CD : read = 0
  • Hi Song_po,
    Thanks for the update. In the initial MAP results, was the imager on while this data was collected? I recommend having the image powered on during this testing as link may be impacted while MAP is running.
    Additionally, is there a reason register 0x41 was changed from 0xA7 to 0xE0? We recommend setting 0x41[3:0] to 0x9 for better link margin.
    Zoe
