Part Number: TUSB8041
I am trying to build a controllable USB HUB using two TUSB8041 ic's.
It is possible to control individually each downstream ports using TUSB8041? If yes, how can i do it? If not, should I use a switch and a microcontroller and switch on/off each port manually using the microcontroller?
