Part Number: TCAN4551-Q1
Other Parts Discussed in Thread: TCAN4550
Hi,everyone,
Rencently when we recently used the chip TCAN4551, we found that the waveform would shake after adding the common mode inductor AMCW4532B-2-220T, and the waveform would be normal after shorting the common mode inductor with 0 ohm resistance. But this common mode inductor used in the TCAN1044 chip waveform is normal. So is it the configuration of the chip that causes the output current capacity of the chip to weaken, which leads to the oscillation of the waveform?
