TCAN4550EVM: CANBUS transmit data is unstable
Part Number: TCAN4550EVM
Other Parts Discussed in Thread: TCAN4550
Hi Team,
I encountered an issue with my CAN transmit.
The transmission is very unstable and the recipient does not always receive the data.
However, when I extend the time between WriteTXBuffer and TransmitBufferContents to more than one second, the data transmission becomes more stable.
What could be causing this issue?
I have tested my receiving device and there is no problem with it.
// Write to the TX buffer
TCAN4x5x_MCAN_WriteTXBuffer(0, header, TxData);
// Send the message
TCAN4x5x_MCAN_TransmitBufferContents(0);
  • Hi Hsinyu,
    I'm not sure exactly what you mean by "the transmission is very unstable and the recipient does not always receive the data."  I don't know if this means the device is not responding to the transmission request and is not transmitting the message on the CAN bus for some reason which could indicate a clock related issue.  Or if this means that there are errors generated on the transmitted messages preventing a successful transmission to the receiving device.
    Can you monitor the CAN bus during your test with a scope to see if there are any issues with the CAN waveforms during your test?  Are there any differences in the waveforms when you add an extra delay between the WriteTXBuffer and Transmit BufferContents functions?  Do you see any Error frames getting thrown on the CAN bus when you try to transmit?
    Can you also monitor the various Status, Interrupt, Error Counter and TX Buffer registers to see if there are errors or problems getting flagged by the device?
    0x0820 - Device Interrupts
    0x0824 or 0x1050 - MCAN Interrupts
    0x1018 - Control Register (monitor INIT bit)
    0x1040 - Error Counter Register (CAN transmit and receive error counters)
    0x1044 - Protocol Status Register (CAN specific status information including Error Codes)
    0x10C4 - TX FIFO/Queue Status register
    0x10CC - TX Buffer Request Pending (to see if messages are pending transmission)
    0x10D8 - TX Buffer Add Request Transmission Occurred (to see if messages were successfully transmitted)
    Jonathan
  • Hi Jonathan,
    Sorry for the late reply.
    I'm connecting through stm32wb5 to tcan4550evm.
    The program execution is shown below.
    But there must be a 0.3-second interval for two CAN transmissions to be received by the device.
    If less than 0.3 seconds, it's easy to encounter a situation where the second data cannot be candumped.
    Is this delay time reasonable?
    In theory, how long should the interval between two CAN transmissions be for tcan4550?
    Init_CAN(); // Run the main MCAN configuration sequence. The bulk of the configuration is in this!
    uint8_t data[4] = {0x55, 0x66, 0x77, 0x88}; // Define the data payload
    Sieg_tcan_Tx(data, MCAN_DLC_4B);
    HAL_Delay(300); // Delay for 300 milliseconds (0.3 second)
    data[0] = 0x11;
    data[1] = 0x22;
    data[2] = 0x33;
    data[3] = 0x44;
    int Sieg_tcan_Tx( uint8_t *TxData, uint32_t len)
    /* Prepare Tx message Header */
    TCAN4x5x_MCAN_TX_Header header = {0}; // init CAN header
    header.DLC = len; // Data length is 8 bytes
    header.ID = 0x100; // Set the CAN ID
    header.FDF = 1; // CAN FD frame enabled
    header.BRS = 1; // Bit rate switch enabled
    header.EFC = 0;
    header.MM = 0;
    header.RTR = 0;
    header.XTD = 0; // Using standard ID
    header.ESI = 0; // Error state indicator
    if(*TxData == 1)
    else
    header.ID = 0x111; // Set the CAN ID
    TCAN4x5x_MCAN_WriteTXBuffer(0, &header, TxData);
    // Send the message
    return 0;
  • Hi Hsinyu,
    The timing is based on a combination of the SPI and CAN bit rates, as well as the idle time between CAN and SPI messages.  You will need calculate the time your system needs to transfer the message contents into a TX Buffer element and transmit the message.  You could also simply measure this with a scope or logic analyzer to determine the time from start of the SPI to the CAN message transmission.
    Because you are only using a single TX Buffer for both messages, you should also verify the first message has successfully transmitted before trying to load in the second message.  If you don't, and the TX message is still pending transmission, you could overwrite the TX buffer contents with the new message, or corrupt it with a partial overwrite as it is trying to transmit.
    You may want to add a read to the TX Buffer Transmission Occurred (0x10D8) or the TX Buffer Request Pending (0x10CC) registers prior to your second message to verify the the status of the first message and whether it is safe to reuse the buffer for a new message.
    You could also try to use multiple Dedicated TX Buffers, or a TX FIFO or Queue with more than one TX Buffer to avoid this potential issue.
    Once the TX Buffer's bit has been set in the TX Buffer Add Request (0x10D0) register, the device will try to transmit as soon as possible based on the CAN bus activity and the protocol's rules of arbitration.  If there is other activity on the CAN bus, it may not be known exactly how long it will take for the message to be successfully transmitted, so verifying the TX Buffer is available is always good practice.
    I would suggest you also review the MCAN User's Manual (Link) published by Bosch for more information on the CAN FD Controller IP used in the TCAN4550.
    Jonathan
  • Hi Jonathan,
    To meet the product requirements, I turned off CAN FD.
    When I turned off CAN FD, I no longer encountered the same issue.
    Nothing else was modified. The relevant information is as follows.
    Hsinyu
