TUSB4020BI: Schematic review
Part Number: TUSB4020BI
Other Parts Discussed in Thread: TPS2561
Hi Brian,
Thank you very much for reviewing my schematic, I have few more relating questions:
1. If I will not use SMBUS and I2C mode can I leave the TUSB4020B pin22 unconnected?
2. (See attached TUSB4020B pin21 question.pdfschematic please) - Why is the TUSB4020B pin21 pulled up (means active Low for power switching) when TPS2561 used in this Evaluation Module User Guide schematic is High enable?
3. Can I use the TUSB4020B part without additional SMBUS or I2C register settings?
Please let me know, thank you.
Pavel Skoda
  • HI Pavel:
    yes, SMBUSz can be floating if not use SMBUS and I2C mode.
       You need to set PWRCTL_POL pin based on power switch Enable pin. , PWRCTL_POL should be high if power switch  is low enable. PWRCTL_POL should be low if power switch  is high enable.
       PWRCTL_POL has internal PD, on EVM when switch is on, PWRCTL_POL will be high with external Pullup. when switch is off. PWRCTL_POL will be low with internal pulldown.
    So EVM will have both PU and PD option.
    Yes, TUSB4020B can work in default  register setting without any changes.
    Best
    Brian
  • Hi Brian,
    Great, thank you so much for all your answers!
    I appreciate it a lot.
    Pavel
