Other Parts Discussed in Thread: TEST2, SN65DSI86
I designed a DSI to DP board using SN65DSI86-Q1 to output FHD camera images to DP monitor.
However, the DSI output is confirmed on the soc, but only a black screen is displayed on the DP monitor.
I output a color bar from SN65DSI86-Q1 and confirmed it on the DP monitor.
1. Circuit diagram
DSItoDP_Rev0.1_20240726.pdf
2. init data
// ======Soft reset ======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x09, 0x01, 1, 1);
ERR_CHECK_RET(ret,-1);
// ======REFCLK 27MHz ======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x0A, 0x04, 1, 1); // 26
//======ASSR RW control ======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0xFF, 0x07, 1, 1);
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x16, 0x01, 1, 1);
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0xFF, 0x00, 1, 1);
//======Single 4 DSI lanes======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x10, 0x26, 1, 1); // channel A,B 4lane set
//======DSIA CLK FREQ 445MHz======
// Set automatically after EN setting
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x12, 0x56, 1, 1);
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x12, 0x59, 1, 1); // 445Mhz
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x12, 0x60, 1, 1);// 480Mhz
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x12, 0x65, 1, 1);// 480Mhz
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x12, 0xC0, 1, 1);// 750Mhz ( MAX 0x96 , 750Mhz)
// ret = i2c_read_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x12, &read_data, 1,1); // r: 0x84
// printf("DSI65DSI86Q1_ADDR 0x12 = 0x%x\n", read_data);
//======DSIB CLK FREQ 445MHz======
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x13, 0x59, 1, 1);
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x13, 0x60, 1, 1);// 480Mhz ( MAX 0x96 , 750Mhz)
//======enhanced framing and ASSR======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x5A, 0x04, 1, 1);
//======2 DP lanes no SSC======
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x93, 0x20, 1, 1);
//======1 DP lanes no SSC======
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x93, 0x10, 1, 1);
//======4 DP lanes no SSC======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x93, 0x30, 1, 1); // default
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x93, 0x70, 1, 1); // PRE 1
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x93, 0xB0, 1, 1);// PRE 2
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x93, 0xF0, 1, 1);// PRE 3
//======HBR (2.7Gbps)======
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x94, 0xE0, 1, 1); // 5.4
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x94, 0x80, 1, 1); // 2.7
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x94, 0x20, 1, 1); // 1.62Gbps
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x94, 0x21, 1, 1); // SW 1
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x94, 0x22, 1, 1); // SW2
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x94, 0x23, 1, 1); // SW3
//======PLL ENABLE======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x0D, 0x01, 1, 1);
//======Verify PLL is locked======
// ret |= tixx_write_Only_reg(0x0A);
ret = i2c_read_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x0A, &read_data, 1,1); // r: 0x84
printf("DSI65DSI86Q1_ADDR 0x0A = 0x%x\n", read_data);
//======POST-Cursor2 0dB ======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x95, 0x00, 1, 1);
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x95, 0x40, 1, 1); // POST-Cursor2
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x95, 0x80, 1, 1);
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x95, 0xC0, 1, 1);
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0xF8, 0xFF, 1, 1);
//======Semi-Auto TRAIN ======
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x01, 1, 1); //Normal mode (Idle pattern or active video)
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x02, 1, 1); // TPS1
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x03, 1, 1); // TPS2
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x04, 1, 1); // TPS3
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x05, 1, 1); // PRBS7
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x06, 1, 1); // HBR2
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x07, 1, 1); // 80-bit Custom Pattern
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x08, 1, 1); // Symbol Error Rate Measurement Pattern
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x09, 1, 1); // Fast Link Training
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x0A, 1, 1); // Semi-Auto Link Training.
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, 0x0B, 1, 1); // Redriver Semi-Auto Link Training
sleep(0.02);
//Copyright © 2014–2015, Texas Instruments Incorporated Submit Documentation Feedback 69
//Product Folder Links: SN65DSI86-Q1
//SN65DSI86-Q1
//SLLSEJ5A –JULY 2014–REVISED DECEMBER 2015 www.ti.com
//======Verify Training was successful======
// ret |= tixx_write_Only_reg(0x96);
ret = i2c_read_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x96, &read_data, 1,1);
printf("DSI65DSI86Q1_ADDR 0x96 = 0x%x\n", read_data);
ret = i2c_read_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x00, &read_data, 1,1);
//=====CHA_ACTIVE_LINE_LENGTH is 1920 =======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x20, 0x80, 1, 1);
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x21, 0x07, 1, 1);
//=====CHA_VERTICAL_DISPLAY_SIZE is 1080 =======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x24, 0x38, 1, 1);
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x25, 0x04, 1, 1);
//=====CHA_HSYNC_PULSE_WIDTH is 44 positive =======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x2C, 0x2C, 1, 1);
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x2D, 0x00, 1, 1);
//=====CHA_VSYNC_PULSE_WIDTH is 5 positive=======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x30, 0x05, 1, 1);
// ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x31, 0x80, 1, 1); // default
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x31, 0x00, 1, 1);
//=====CHA_HORIZONTAL_BACK_PORCH is 148=======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x34, 0x94, 1, 1);
//=====CHA_VERTICAL_BACK_PORCH is 36=======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x36, 0x24, 1, 1);
//=====CHA_HORIZONTAL_FRONT_PORCH is 88=======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x38, 0x58, 1, 1);
//=====CHA_VERTICAL_FRONT_PORCH is 4=======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x3A, 0x04, 1, 1);
//======DP- 24bpp======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x5B, 0x00, 1, 1);
//=====COLOR BAR disabled=======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x3C, 0x00, 1, 1);
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x3C, 0x10, 1, 1); // enable
//ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x3C, 0x12, 1, 1); // enable
//======enhanced framing, ASSR, and Vstream enable======
ret = i2c_write_data_type(i2c_num, DSI65DSI86Q1_ADDR, 0x5A, 0x0C, 1, 1);
3. Register status
