Part Number: DS100BR111
Other Parts Discussed in Thread: DS100BR210
Our intent is to use the device in the SMBus Master Mode (ENSMB = Float) to read in device setup values from an external EEPROM at power-up. However, section 8.3 SMBus Master Mode in the datasheet states that access to the SMBus lines is not possible if the EPPROM fails to load settings (e.g. blank EEPROM). If this is the case, how do you perform initial programming of a blank EEPROM on a brand new board assembly?
