Rs422 Differential driver maximum differential output
Other Parts Discussed in Thread: AM26C31
Hi ,
I would like to know the maximum differential O/P voltage swing of  Rs422 Drivers,I had referred datasheets of TI's Differential drivers and found only the minimum and typical values mentioned, I would be glad,if their is any reason behind their absence.
Can I use the supply voltage to IC as maximum differential O/P voltage swing,I have attached snapshots of datasheets of parts I have referred.
Harish.S
