Part Number: TPS65982
Dear TI Sir :
We also have a standard typec-C PD power supply (100W) and a 24V power supply (96W), but the 24V will exceed the IC's maximum voltage rating.
Can we connect a diodes on VBUS ,and floating the SENSEP(B10) and SENSEN(A10) pin,make the 24V power pass directly through the PP_EXT path as follows?
at the same time, comply with the PD protocol.
Or do you have any other suggestions?
