Hi Sirs,
Sorry to bother you.
Our USB function block as below. (Use mux control, one path connect to UFP mode, another path connect to HUB)
Could you help review our schematic?
Any suggestion are welcome. Thanks!!
you seems have two muxes on same USB3 path, it may failed USB3 compliance test, suggest to use USB redriver at SUC-C connector
Hi Brian,
Understood, we will discussed internal to check will add U3 re-driver or not.
So how about schematic? have any risk?
Thanks!!
I didn't see issue for TUSB322I/HD3SS3212/HD3SS6126, how do you control TUSB322 signals? I can find in your schematic.
Hi Sirs,
Thanks for your reply.
TUSB322I's I2C & INT is connected to the CPU (arm based)
Controlled by the CPU
Does this need a driver?
