DS110DF410: 2 Channels of error free transmission of PRBS31 at 10.5GHz but 2 channels of high BER
Part Number: DS110DF410
Hi TI,
I've been testing the DS110DF410 on my test card. This is 12 DS110DF410 transmitting 48 channels of PRBS31 data at 10.5 GHz. These channels are being output onto short tracks to an optical transciever and received by an FPGA on a destination device.
All channels on all DS110DF410 are being programmed through I2C from a MCU device and R/W registers can be read back to confirm that the values are correct. These register settings are supplied below.
Programming occurs as a register dump boradcast to all channels on the device.
I had confirmed the register settings on the DS110DF410EVM using the SigCon Architect GUI tool.
I have determined that my endpoint device is not the problem by lane swapping at the output connector that connects to the retimer I can get all lanes on the destination device to work but half of the outputs on my test card from the DS110DF410 are not (all lanes connected to TX0 and TX1 of retimer devices).
The output from two channels on each device that go to TX0 and TX1 are locking to the signal but showing a saturated BER of 1.55E-2.
The output from the two other channels lock and run error free.
This is the case for all 12 DS110DF410 devices and having reviewed the schematic and layout the P and N are correct directions and the routing method is very similar between all channels and the fact that TX2 and TX3 run perfectly and are configured in the same way makes me think there might be something going wrong when the device is programmed.
The registers that are being programmed to all devices on all channels is given below:
Ds110df410ProgramListEntry_t ds110df410ProgramTable[] = {
   {0x00, 0x00, 0xFF},
   {0x01, 0x00, 0xFF},
   {0x02, 0xD8, 0xFF}, // from DC
   {0x03, 0xA5, 0xFF},
   {0x04, 0x00, 0xFF},
   {0x05, 0x00, 0xFF},
   {0x06, 0x00, 0xFF},
   {0x07, 0x00, 0xFF},
   {0x08, 0x00, 0xFF},
   {0x09, 0x20, 0xFF},
   {0x0A, 0x10, 0xFF},
   {0x0B, 0x0F, 0xFF},
   {0x0C, 0x00, 0xFF}, // from 0x08
   {0x0D, 0x20, 0xFF},
   {0x0E, 0x93, 0xFF},
   {0x0F, 0x69, 0xFF},
   {0x10, 0x3A, 0xFF},
   {0x11, 0x20, 0xFF},
   {0x12, 0xA0, 0xFF},
   {0x13, 0x30, 0xFF},
   {0x14, 0x00, 0xFF},
   {0x15, 0x10, 0xFF}, // was 0x10, then 0x53,
   {0x16, 0x7A, 0xFF},
   {0x17, 0x36, 0xFF},
   {0x18, 0x40, 0xFF},
   {0x19, 0x23, 0xFF},
   {0x1A, 0x00, 0xFF},
   {0x1B, 0x03, 0xFF},
   {0x1C, 0x24, 0xFF},
   {0x1D, 0x00, 0xFF},
   {0x1E, 0x99, 0xFF},
   {0x1F, 0x55, 0xFF},
   {0x20, 0x00, 0xFF},
   {0x21, 0x00, 0xFF},
   {0x22, 0x00, 0xFF},
   {0x23, 0x40, 0xFF},
   {0x24, 0x00, 0xFF},
   {0x25, 0x00, 0xFF},
   {0x26, 0x00, 0xFF},
   {0x27, 0x3C, 0xFF}, // was 0x3E
   {0x28, 0x93, 0xFF}, // was 0x9C
   {0x29, 0x40, 0xFF},
   {0x2A, 0x30, 0xFF},
   {0x2B, 0x00, 0xFF},
   {0x2C, 0x72, 0xFF},
   {0x2D, 0x80, 0xFF},
   {0x2E, 0x00, 0xFF},
   {0x2F, 0x06, 0xFF},
   {0x30, 0x0A, 0xFF},
   {0x31, 0x20, 0xFF},
   {0x32, 0x11, 0xFF},
   {0x33, 0x88, 0xFF},
   {0x34, 0xBF, 0xFF},
   {0x35, 0x1F, 0xFF},
   {0x36, 0x31, 0xFF},
   {0x37, 0x1f, 0xFF}, // was 0x00
   {0x38, 0x00, 0xFF},
   {0x39, 0x00, 0xFF},
   {0x3A, 0xA5, 0xFF},
   {0x3B, 0x00, 0xFF},
   {0x3C, 0x00, 0xFF},
   {0x3D, 0x00, 0xFF},
   {0x3E, 0x80, 0xFF},
   {0x3F, 0x00, 0xFF},
   {0x40, 0x00, 0xFF},
   {0x41, 0x01, 0xFF},
   {0x42, 0x04, 0xFF},
   {0x43, 0x10, 0xFF},
   {0x44, 0x40, 0xFF},
   {0x45, 0x08, 0xFF},
   {0x46, 0x02, 0xFF},
   {0x47, 0x80, 0xFF},
   {0x48, 0x03, 0xFF},
   {0x49, 0x0C, 0xFF},
   {0x4A, 0x30, 0xFF},
   {0x4B, 0x41, 0xFF},
   {0x4C, 0x50, 0xFF},
   {0x4D, 0xC0, 0xFF},
   {0x4E, 0x60, 0xFF},
   {0x4F, 0x90, 0xFF},
   {0x50, 0x88, 0xFF},
   {0x51, 0x82, 0xFF},
   {0x52, 0xA0, 0xFF},
   {0x53, 0x46, 0xFF},
   {0x54, 0x52, 0xFF},
   {0x55, 0x8C, 0xFF},
   {0x56, 0xB0, 0xFF},
   {0x57, 0xC8, 0xFF},
   {0x58, 0x57, 0xFF},
   {0x59, 0x5D, 0xFF},
   {0x5A, 0x69, 0xFF},
   {0x5B, 0x75, 0xFF},
   {0x5C, 0xD5, 0xFF},
   {0x5D, 0x99, 0xFF},
   {0x5E, 0x96, 0xFF},
   {0x5F, 0xA5, 0xFF},
   {0x60, 0x80, 0xFF},
   {0x61, 0xB4, 0xFF},
   {0x62, 0x80, 0xFF},
   {0x63, 0xB4, 0xFF},
   {0x64, 0xFF, 0xFF},
   {0x65, 0x00, 0xFF},
   {0x66, 0x00, 0xFF},
   {0x67, 0x20, 0xFF},
   {0x68, 0x00, 0xFF},
   {0x69, 0x0A, 0xFF},
   {0x6A, 0x44, 0xFF},
   {0x6B, 0x00, 0xFF},
   {0x6C, 0x00, 0xFF},
   {0x6D, 0x00, 0xFF},
   {0x6E, 0x00, 0xFF},
   {0x6F, 0x00, 0xFF},
   {0x70, 0x03, 0xFF},
   {0x71, 0x20, 0xFF},
   {0x72, 0x00, 0xFF},
   {0x73, 0x00, 0xFF},
   {0x74, 0x00, 0xFF},
   {0x18, 0x00, 0xFF},
   {0x09, 0x24, 0xFF},
   {0x1E, 0x10, 0x10}, /* Set Bit 4 */
   {0x30, 0x00, 0x08}, /* Clear bit 3*/
   {0x30, 0x08, 0x08}, /* Set bit 3*/
   {0x0D, 0x20, 0x20}, /* Set bit 5 */
   {0x09, 0x20, 0x20}, /* Set bit 5 */
   {0x1E, 0x80, 0xE0}, /* Write 0x04 to bits 7:5 */
   {0xFF, 0xFF, 0xFF},
We have confirmed that all values that can be written have taken and can be read back. Is there anyway that programming 4 channels in this way could result in 2 channels working and 2 channels not working?
Sean Suttie.
    Can you capture the retimer full channel register values for both a "bad" channel when issue is observed and also "Good" channel, to allow me to compare the retimer status values?
    Rodrigo Natal
    HSSC Applications Engineer
  • A full register dump is given below.
    This is all retimer and channel registers dumped.
    Selected Retimer: 0
    CH = 0xD1 AD=0x30
    Shared registers:
       SMBUS_ADDRESS_VALUE = 0x00
       VERSION_VALUE       = 0xf0 (expect 0xf0)
    Channel 0 registers:
       RESET_VALUE (0) = 0x00:
          Core State Machine: Normal Operation
          Channel registers: Normal Operation
          Reference clock domain: Normal Operation
          VCO DIV clock domain: Normal Operation
       LOCK_LOSS_VALUE (1) = 0x00:
       CDR_STATUS (2) = 0xd8:
          PPM Count met = 1
          CTLE Auto Adapt Complete = 1
          Fail Lock Check = 0 (signal quality and amplitude level not sufficient for CDR lock)
          Lock = 1
          CDR Lock = 1
          Single Bit Limit Reached = 0
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x35
       REGISTER 0x28: 0x6f
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Channel 1 registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x30
       REGISTER 0x28: 0x6f
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Channel 2 registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x38
       REGISTER 0x28: 0x6c
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Channel 3 registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x03
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x6c
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 1
    CH = 0xD1 AD=0x32
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xc0
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x33
       REGISTER 0x28: 0x8d
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x0d
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
       LOCK_LOSS_VALUE (1) = 0x01:
          Loss of signal after hanving acquired it.
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xd5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x31
       REGISTER 0x28: 0x99
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1c
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x99
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x99
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 2
    CH = 0xD1 AD=0x34
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x03
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x36
       REGISTER 0x28: 0x9f
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x35
       REGISTER 0x28: 0x99
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xb0
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3a
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x16
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
       CDR_STATUS (2) = 0x98:
          PPM Count met = 1
          CTLE Auto Adept Complete = 0 (in progress)
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xb0
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x16
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 3
    CH = 0xD1 AD=0x36
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xc8
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x9c
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x17
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x99
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xc0
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3a
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x0d
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xc0
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x39
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x0d
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 4
    CH = 0xD1 AD=0x38
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x33
       REGISTER 0x28: 0x72
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x88
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x03
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x39
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x10
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x88
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3a
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x10
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x88
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x10
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 5
    CH = 0xD1 AD=0x3A
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3a
       REGISTER 0x28: 0x93
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x03
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x39
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3a
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3a
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 6
    CH = 0xD7 AD=0x3C
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x88
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x36
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x10
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x41
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x0b
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x41
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x0b
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 7
    CH = 0xD7 AD=0x3E
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xc8
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x38
       REGISTER 0x28: 0x8d
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x17
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x82
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x8d
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x11
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3a
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 8
    CH = 0xD7 AD=0x40
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x82
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x93
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x11
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x5d
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x93
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x19
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x99
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x39
       REGISTER 0x28: 0x99
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1d
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x99
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x39
       REGISTER 0x28: 0x99
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1d
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 9
    CH = 0xD7 AD=0x42
    Shared registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x37
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x93
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xa5
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x3b
       REGISTER 0x28: 0x93
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x1f
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 10
    CH = 0xD7 AD=0x44
    Shared registers:
       SMBUS_ADDRESS_VALUE = 0x00
       VERSION_VALUE       = 0xf0 (expect 0xf0)
    Channel 0 registers:
       RESET_VALUE (0) = 0x00:
          Core State Machine: Normal Operation
          Channel registers: Normal Operation
          Reference clock domain: Normal Operation
          VCO DIV clock domain: Normal Operation
       LOCK_LOSS_VALUE (1) = 0x00:
       CDR_STATUS (2) = 0xd8:
          PPM Count met = 1
          CTLE Auto Adapt Complete = 1
          Fail Lock Check = 0 (signal quality and amplitude level not sufficient for CDR lock)
          Lock = 1
          CDR Lock = 1
          Single Bit Limit Reached = 0
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x0c
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x38
       REGISTER 0x28: 0x90
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x09
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Channel 1 registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x5d
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x38
       REGISTER 0x28: 0x96
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x19
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Channel 2 registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xb0
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x38
       REGISTER 0x28: 0x93
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x16
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Channel 3 registers:
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0xb0
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x38
       REGISTER 0x28: 0x93
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x16
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
    Selected Retimer: 11
    CH = 0xD7 AD=0x46
    Shared registers:
       LOCK_LOSS_VALUE (1) = 0x10:
          Loss of CDR lock after having acquired it.
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x34
       REGISTER 0x28: 0x6c
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
       LOCK_LOSS_VALUE (1) = 0x11:
          Loss of signal after hanving acquired it.
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x38
       REGISTER 0x28: 0x6f
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x36
       REGISTER 0x28: 0x6f
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
          PPM Count met = 1
          Lock = 1
          CDR Lock = 1
          Comp LPF High = 0
          Comp LPF Low = 0
       REGISTER 3: 0x00
       REGISTER 8: 0x00
       REGISTER 9: 0x24
       REGISTER 0xA: 0x10
       REGISTER 0xB: 0x0f
       REGISTER 0xC: 0x00
       REGISTER 0xD: 0x20
       REGISTER 0xE: 0x93
       REGISTER 0xF: 0x69
       REGISTER 0x10: 0x3a
       REGISTER 0x11: 0x20
       REGISTER 0x12: 0xa0
       REGISTER 0x13: 0x30
       REGISTER 0x14: 0x00
       REGISTER 0x15: 0x10
       REGISTER 0x16: 0x7a
       REGISTER 0x17: 0x36
       REGISTER 0x18: 0x00
       REGISTER 0x19: 0x23
       REGISTER 0x1A: 0x00
       REGISTER 0x1B: 0x03
       REGISTER 0x1C: 0x24
       REGISTER 0x1D: 0x00
       REGISTER 0x1E: 0x99
       REGISTER 0x1F: 0x55
       REGISTER 0x20: 0x00
       REGISTER 0x21: 0x00
       REGISTER 0x22: 0x00
       REGISTER 0x23: 0x40
       REGISTER 0x24: 0x00
       REGISTER 0x25: 0x00
       REGISTER 0x26: 0x00
       REGISTER 0x27: 0x36
       REGISTER 0x28: 0x6f
       REGISTER 0x29: 0x40
       REGISTER 0x2A: 0x30
       REGISTER 0x2B: 0x00
       REGISTER 0x2C: 0x72
       REGISTER 0x2D: 0x80
       REGISTER 0x2E: 0x00
       REGISTER 0x2F: 0x06
       REGISTER 0x30: 0x0a
       REGISTER 0x31: 0x20
       REGISTER 0x32: 0x11
       REGISTER 0x33: 0x88
       REGISTER 0x34: 0xbf
       REGISTER 0x35: 0x1f
       REGISTER 0x36: 0x31
       REGISTER 0x37: 0x00
       REGISTER 0x38: 0x00
       REGISTER 0x39: 0x00
       REGISTER 0x3A: 0xa5
       REGISTER 0x3E: 0x80
       REGISTER 0x60: 0x80
       REGISTER 0x61: 0xb4
       REGISTER 0x62: 0x80
       REGISTER 0x63: 0xb4
       REGISTER 0x64: 0xff
       REGISTER 0x67: 0x20
       REGISTER 0x69: 0x0a
       REGISTER 0x6A: 0x44
       REGISTER 0x6B: 0x00
       REGISTER 0x6C: 0x00
       REGISTER 0x6D: 0x00
       REGISTER 0x6E: 0x00
       REGISTER 0x70: 0x03
       REGISTER 0x71: 0x20
       REGISTER 0x72: 0x00
       REGISTER 0x73: 0x00
       REGISTER 0x74: 0x00
       REGISTER 0x75: 0x00
  • Hi Sean,
    Thanks the system level data. The main reason I asked for it was that I wanted to check whether there was some signature of incorrect EQ adaption on channels 0 and 1. Based on your data, I do not see it. Rather, your observed retimer eye opening values are quite good for channels 0 and 1.
    Please note that the DS110DF410 does not support PRBS checker function, only generator. Are you checking errors on your host ASIC or FPGA?
    Below is the sequence for PRBS generator. Do double check your scripts against it.
    Table 35. Register Writes to Enable PRBS Generator
    STEP
    SHARED/CHANNEL REGISTER SET
    OPERATION
    REGISTER ADDRESS [HEX]
    REGISTER VALUE [HEX]
    WRITE MASK [HEX]
    COMMENT
    1
    Channel
    Write
    09
    20
    20
    Override Output Multiplexer
    Select.
    2
    Channel
    Write
    1E
    80
    E0
    Turn on serializer (ser_en=1).
    3
    Channel
    Write
    1E
    10
    10
    Power-up PRBS Generator.
    4
    Channel
    Write
    30
    00
    08
    Reset PRBS Clock.
    5
    Channel
    Write
    30
    08
    08
    Power-up PRBS Clock.
    6
    Channel
    Write
    30
    00
    02
    03
    Select PRBS9 pattern. Select PRBS31 pattern.
    7
    Channel
    Write
    0D
    20
    20
    Enable PRBS Clock triggering on Div/Clock so that the eye diagram is viewable. Disabling results in Pattern Cycle triggering.
    Cordially,
    Rodrigo Natal
  • Hi Rodrigo,
    Thank you for your time and attention.
    I am happy to say that I've identified the problem with my system and it was not the retimer at fault. The register set I had looks to work fine.
    Sean.
