Part Number: TPS65987D
Other Parts Discussed in Thread: TPS65987,
Dear TI support team,
I have 3 questions regarding to control this device by HOST CPU without using external SPI Flash memory;
1.
We have been recognized that individual register settings via I2C are sufficient for controlling TPS65987. (A)
However, your comment (replied via TI-Japan member) seems we have to change our control sequence to update entire configuration at first by installing patch(PTC), then individually set register via I2C.(B)
I’m wondering the difference among two methods above (A) and (B). Is the PTC setting mandatory or just highly recommended for avoiding the lack of necessary setting?
2.
We are now setting BOOT Mode as “Safe configuration” for disabling Port initially in accordance with ADCIN1 setting.
I’m now doubting that we didn’t set any port enable operation correctly. The operations from host currently is just setting several registers 0x27, 0x28 and 0x29. Is it enough for enabling port? If not, please let me know how to operates to switch port from disable to enable.
3.
If you have any sample code for HOST CPU, please provide us.
It would be the easiest way to understand how to control TPS65987 from CPU side via I2C correctly.
