1. There are 20 new LED lamps related to UCC28880 damage. Through cross-testing, it is found that the input and output voltages of the power supply under the input voltage of 90-100V are lower than those of the normal power supply. Measurement of power supply temperature Defective product temperature is higher than the normal power supply
2. After testing the voltage state of pins and cross-testing, the problem phenomena follow the chip, and submit the FA analysis
ER046-S243WT (1.0.5)-2019.03.pdf
atachment is about sch,any advise?thanks in advance
