Hi Team,
I knew that when using inductance in POC is very suitable because the DCR is smallest.
However, because of the area, customer need to use Ferrite bead+ Inductance.
May I ask the following questions?
- Q1: Can customer only use several Ferrite bead in series instead of using inductance? When using ferrite bead to replace inductance, what is the disadvantage? DCR become bigger?
- Q2: As for resistor, is it use for impedance matching?
- Any other deeper learning material about POC design (except SNLA272)?
Thanks!
