Hi;
I need a reference design layout for LMH0341 .Could you supply it please ?
Hi;
Greetings,
Please attached note pcb layout for the LMH0341 EZ Link board.
Regards,, Nasserdeserializer Rev C (12-20-2007 8-26-53 PM).zip
Hi Nasser;
Thank you very much.
I checked the design files.I suppose that 100 ohm traces are referenced to Layer 2 and 75 ohm traces are referenced to Layer 3.But I see a copper island just below 75 ohm trace on Layer 2- no cut out.this island exist in gerbers also:
Could you check it if this is the correct version?
Greetings,
Layer 2 is normally used for 100-ohm reference and layer 3 for 75-ohm reference. There sDeserializer ALP daughtercard Rev D Board Layout.pdfhould be cut out under 75-ohm trace on layer 2. Please attached note a pdf of the layout where the black area shows the cut out under 75-ohm trace on layer 2.
Regards,, Nasser
