Hello team,
From the datasheet I see the max trace length from device to eDP receptacle, if there any information about the max cable length requirement from eDP receptacle? Thanks a lot.
Hello team,
The DSI86 implements both SWING and Pre-emphasis level to compensate for the loss of source trace, the eDP cable, the connector, and the sink trace. The max pre-emphasis that can be supported by DSI86 is 7.2dB, you can use this to estimate the eDP cable length requirement.
David
