Hi Experts,
My customer would like to use TRS3223-Q1 into a automotive system, but they need to take account for the risk of signals shorting to vehicle PbA battery.
Can you please teach us if there is any circuit to protect DOUT and RIN pins shorting to the battery? The maximum battery voltage can go upto 18v, the RIN should be fine but the DOUT can only handle up to 13.2V and might have the risk to cause damage on TRS3223-Q1.
We tried to add schottky diode in series with DOUT pin to block the reserve battery voltage if the terminal connector is shorted to battery, but this will affect the communication under normal condition.
We need a solution to protect TRS3223-Q1 from failure under the short condition, while not affecting the communication under normal working condition.
Any suggestion would be greatly appreciated.
Thank you.
Wei-Hao
