TPS65320-Q1 and TPS65320-Q1 Rev. B
Let me known the difference between TPS65320QPWPRQ1 and TPS65320BQPWPRQ1.
I can’t find the difference in the datasheet.
Best Regards.
  • Ushikubo-san,
    The appropriate applications engineer has been notified of your inquiry and will respond accordingly.
    Eric
  • Ushikubo-san,
    The "B" revisions addresses a few issues of the original version:
    Addressed BUCK output overshoot issue: TPS65320-BUCK output has an overshoot at disabling, in case LDO is already disabled
    Addressed long term fuse re-growth potential in TPS65320 and altering device analog parameter trim values
    Addressed power dissipation issuein TPS65320 when VIN > 20V and LDO is supplied by VIN and LDO output is shorted to ground
    Addressed LDO and BUCK output droop issue (around 5% with TPS65320) when VIN < 8V at cold temperature (-40C)
    For new designs, we recommend to use the "B" revision.
    Frank
