Other Parts Discussed in Thread: TPL7407LA
Hi team,
Could you tell me how much the maximum output current is per channel?
Are the datasheet values per channel?
Sincerely.
Kengo.
Hi team,
Sincerely.
Kengo.
Hi Kengo,
Going off Clemens' answer a little bit:
IOH and IOL will be per channel. However, the recommended operating conditions do not mean that the device will always output 24 mA. These are values that have been tested internally. For example, when the device was tested a load was applied that drew exactly 24 mA.
If you can give some more information on why you need these specs, we can try and help you through your problem.
