Other Parts Discussed in Thread: TXS0108E
Hi Expert,
Customer met some questions on TXS0108E-Q1 in their project. You can find the schematic as below.
In customer system, there have one case that PERIPH_1V8_SW(VCCA of TXS0108) power on later than cluSOC_VRTC_1V8 and cluSOC_VDD_1V8. Their expectation is all the Ax and Bx are under Hi-Z state before VCCA and VCCB completely power up. From the description in datasheet, we should pull down the OE pin.
Customer modify the OE pin to GND, but found A1 pin is 0.4V before VCCA power up, it is not Hi-Z state. There have cluSOC_VRTC_1V8 pull up on A1, it should be 1.8V at Hi-Z state. You can find the waveform as below. CH3 is A1 pin, CH2 is VCCA.
Can you help check?
Thanks!
Ethan Wen
