Other Parts Discussed in Thread: SN75451B, ULN2003V12
Hello
I would like to use SN75451B for High current driver but could not use it due to operating Temp is low.
Would you recommend me High Current Driver except millitary version?
THanks
Hello
THanks
Hello Ron
The SN75451B for Target application is not related to Timing Issue but Operating temp Issue.
This device is using for driving Optical Module Driver which manufactured by AVGO>
In terms of performance, This device is quite well for Application (High Current Driver) except operating Temp. Therefore, I am finding a new solution like a SN75451B.
Hello Ron
Thank you for answer.
Unfortunately the recommended device ULN2003 has low posssibility for applying Optical driver.
This is becuase, Function and Specification of ULN2003 are far from SN75451B' them.
Jin,
AND vs. NOT does need to invert input signal.
Both are open collector, but VOL on ULN2003 is higher. ULN2003V12 has low VOL (for it's current range)
How big is the opportunity?
If big enough, I will request a temperature extension.
