I have used TI part-CD4504B as per below schematic; but its getting heated up & also damaged.
Connection details -
while testing, only 15V connected. No inputs given & 3.3V also not present.
Is the IC getting failed because of only supply ? Please clarify.
Thanks for your reply.
But normally all the inputs will not be used; out of 6 channel, I need only 2 channel.
So, in that case what shall I do ? Shall I connect pull down resistors to unused channel ?
Tusarkanta Das
Thanks for your suggestion.
Please clarify last point.
- What about 2 used channels; shall I put pull down/pull-up resistors for those ? because that is not continuous signal which is connected to 2 channel.
Tusarkanta Das
