Part Number: SM470R1B1M-HT
Chip lot: 3BAC 1812A
Debug log is as follows:
Fri Oct 22, 2021 08:10:03: IAR Embedded Workbench 8.32.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\bin\armproc.dll)
Fri Oct 22, 2021 08:10:03: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashSM470R1B1M.mac
Fri Oct 22, 2021 08:10:03: JLINK command: ProjectFile = D:\Workspace\IAR_ARM\SM470_OS_10-02_10-53\Project\settings\SM470_Debug.jlink, return = 0
Fri Oct 22, 2021 08:10:03: Device "SM470R1B1M" selected.
Fri Oct 22, 2021 08:10:03: DLL version: V6.14a, compiled Feb 27 2017 18:41:26
Fri Oct 22, 2021 08:10:03: Firmware: J-Link V9 compiled Dec 13 2019 11:14:50
Fri Oct 22, 2021 08:10:03: JTAG speed is initially set to: 1000 kHz
Fri Oct 22, 2021 08:10:03: TotalIRLen = 4, IRPrint = 0x01
Fri Oct 22, 2021 08:10:03: Hardware reset with strategy 0 was performed
Fri Oct 22, 2021 08:10:03: Initial reset was performed
Fri Oct 22, 2021 08:10:03: Found 1 JTAG device, Total IRLen = 4:
Fri Oct 22, 2021 08:10:03: #0 Id: 0x3100E02F, IRLen: 4, IRPrint: 0x1 ARM7TDMI Core
Fri Oct 22, 2021 08:10:03: J-Link found 1 JTAG device(s). ARM core Id: 3100E02F ARM7
Fri Oct 22, 2021 08:10:03: execUserFlashInit
Fri Oct 22, 2021 08:10:03: Executing memory setup macro dddd B1M Flash
Fri Oct 22, 2021 08:10:03: Adaptive clocking not supported for selected CPU core. Only supported for -S cores.
Fri Oct 22, 2021 08:10:03: Auto JTAG speed: 8000 kHz
Fri Oct 22, 2021 08:10:03: 3456 bytes downloaded and verified (35.90 Kbytes/sec)
Fri Oct 22, 2021 08:10:03: Warning:
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400080, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400081, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400082, target byte: 0xDB, byte in file: 0x0C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400083, target byte: 0xFF, byte in file: 0xDD
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400084, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400085, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400086, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400087, target byte: 0xFF, byte in file: 0x04
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400088, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400089, target byte: 0xDD, byte in file: 0x40
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008A, target byte: 0xDB, byte in file: 0xFD
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008B, target byte: 0xFF, byte in file: 0x7C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008C, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008D, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008E, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040008F, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400090, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400091, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400092, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400093, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400094, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400095, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400096, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400097, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400098, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400099, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009A, target byte: 0xDB, byte in file: 0x30
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009B, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009C, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009D, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009E, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040009F, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A0, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A1, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A2, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A3, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A4, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A5, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A6, target byte: 0xDB, byte in file: 0x31
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A7, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A8, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000A9, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AA, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AB, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AC, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AD, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AE, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000AF, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B0, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B1, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B2, target byte: 0xDB, byte in file: 0x32
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B3, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B4, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B5, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B6, target byte: 0xDB, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B7, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B8, target byte: 0xCF, byte in file: 0x61
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000B9, target byte: 0xDD, byte in file: 0x73
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BA, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BB, target byte: 0xFF, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BC, target byte: 0xCF, byte in file: 0x65
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BD, target byte: 0xDD, byte in file: 0x79
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BE, target byte: 0xDB, byte in file: 0x33
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000BF, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C0, target byte: 0xCF, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C1, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C2, target byte: 0xDB, byte in file: 0x63
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C3, target byte: 0xFF, byte in file: 0x6C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C4, target byte: 0xCF, byte in file: 0x6F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C5, target byte: 0xDD, byte in file: 0x63
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C6, target byte: 0xDB, byte in file: 0x6B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C7, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C8, target byte: 0xCF, byte in file: 0xB5
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000C9, target byte: 0xDD, byte in file: 0xF1
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CA, target byte: 0xDB, byte in file: 0x9F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CB, target byte: 0xFF, byte in file: 0x06
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CC, target byte: 0xCF, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CD, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CE, target byte: 0xDB, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000CF, target byte: 0xFF, byte in file: 0x16
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D0, target byte: 0xCF, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D1, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D2, target byte: 0xDB, byte in file: 0x2F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D3, target byte: 0xFF, byte in file: 0x01
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D4, target byte: 0xCF, byte in file: 0xDB
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D5, target byte: 0xDD, byte in file: 0x1B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D6, target byte: 0xDB, byte in file: 0x9D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D7, target byte: 0xFF, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D8, target byte: 0xCF, byte in file: 0x1C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000D9, target byte: 0xDD, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DA, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DB, target byte: 0xFF, byte in file: 0x29
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DC, target byte: 0xCF, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DD, target byte: 0xDD, byte in file: 0x7F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DE, target byte: 0xDB, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000DF, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E0, target byte: 0xCF, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E1, target byte: 0xDD, byte in file: 0x1D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E2, target byte: 0xDB, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E3, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E4, target byte: 0xCF, byte in file: 0xD1
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E5, target byte: 0xDD, byte in file: 0x0F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E6, target byte: 0xDB, byte in file: 0x42
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E7, target byte: 0xFF, byte in file: 0xBE
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E8, target byte: 0xCF, byte in file: 0xDA
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000E9, target byte: 0xDD, byte in file: 0x11
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EA, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EB, target byte: 0xFF, byte in file: 0xA0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EC, target byte: 0xCF, byte in file: 0x99
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000ED, target byte: 0xDD, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EE, target byte: 0xDB, byte in file: 0x18
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000EF, target byte: 0xFF, byte in file: 0x08
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F0, target byte: 0xCF, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F1, target byte: 0xDD, byte in file: 0x40
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F2, target byte: 0xDB, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F3, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F4, target byte: 0xCF, byte in file: 0xD0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F5, target byte: 0xDD, byte in file: 0x0B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F6, target byte: 0xDB, byte in file: 0x22
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F7, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F8, target byte: 0xCF, byte in file: 0x21
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000F9, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FA, target byte: 0xDB, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FB, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FC, target byte: 0xCF, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FD, target byte: 0xDD, byte in file: 0xE3
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FE, target byte: 0xDB, byte in file: 0x49
Fri Oct 22, 2021 08:10:03: Verify error at address 0x004000FF, target byte: 0xFF, byte in file: 0x78
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400100, target byte: 0xCF, byte in file: 0x60
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400101, target byte: 0xDD, byte in file: 0x08
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400102, target byte: 0xDB, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400103, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400104, target byte: 0xCF, byte in file: 0xE0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400105, target byte: 0xDD, byte in file: 0x0A
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400106, target byte: 0xDB, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400107, target byte: 0xFF, byte in file: 0x34
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400108, target byte: 0xCF, byte in file: 0x1D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400109, target byte: 0xDD, byte in file: 0x2D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010A, target byte: 0xDB, byte in file: 0x42
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010B, target byte: 0xFF, byte in file: 0xBC
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010C, target byte: 0xCF, byte in file: 0xDB
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010D, target byte: 0xDD, byte in file: 0xE4
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010E, target byte: 0xDB, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040010F, target byte: 0xFF, byte in file: 0x74
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400110, target byte: 0xCF, byte in file: 0x21
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400111, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400112, target byte: 0xDB, byte in file: 0x43
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400113, target byte: 0xFF, byte in file: 0xC9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400114, target byte: 0xCF, byte in file: 0x60
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400115, target byte: 0xDD, byte in file: 0x01
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400116, target byte: 0xDB, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400117, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400118, target byte: 0xCF, byte in file: 0x2F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400119, target byte: 0xDD, byte in file: 0x01
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011B, target byte: 0xFF, byte in file: 0x1B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011C, target byte: 0xCF, byte in file: 0x9D
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011D, target byte: 0xDD, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011E, target byte: 0xDB, byte in file: 0x1C
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040011F, target byte: 0xFF, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400120, target byte: 0xCF, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400121, target byte: 0xDD, byte in file: 0x29
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400122, target byte: 0xDB, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400123, target byte: 0xFF, byte in file: 0x70
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400124, target byte: 0xCF, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400125, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400126, target byte: 0xDB, byte in file: 0xF8
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400127, target byte: 0xFF, byte in file: 0xFA
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400128, target byte: 0xCF, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400129, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012A, target byte: 0xDB, byte in file: 0xD1
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012B, target byte: 0xFF, byte in file: 0x0F
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012C, target byte: 0xCF, byte in file: 0x42
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012D, target byte: 0xDD, byte in file: 0xBE
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012E, target byte: 0xDB, byte in file: 0xDA
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040012F, target byte: 0xFF, byte in file: 0x11
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400130, target byte: 0xCF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400131, target byte: 0xDD, byte in file: 0xA0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400132, target byte: 0xDB, byte in file: 0x99
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400133, target byte: 0xFF, byte in file: 0x07
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400134, target byte: 0xCF, byte in file: 0x18
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400135, target byte: 0xDD, byte in file: 0x08
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400136, target byte: 0xDB, byte in file: 0x68
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400137, target byte: 0xFF, byte in file: 0x40
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400138, target byte: 0xCF, byte in file: 0x28
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400139, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013A, target byte: 0xDB, byte in file: 0xD0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013B, target byte: 0xFF, byte in file: 0x0B
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013C, target byte: 0xCF, byte in file: 0x22
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013D, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013E, target byte: 0xDB, byte in file: 0x21
Fri Oct 22, 2021 08:10:03: Verify error at address 0x0040013F, target byte: 0xFF, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400140, target byte: 0xCF, byte in file: 0xF0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400141, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400142, target byte: 0xDB, byte in file: 0xF9
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400143, target byte: 0xFF, byte in file: 0xC0
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400144, target byte: 0xCF, byte in file: 0x49
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400145, target byte: 0xDD, byte in file: 0x66
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400146, target byte: 0xDB, byte in file: 0x60
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400147, target byte: 0xFF, byte in file: 0x48
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400148, target byte: 0xCF, byte in file: 0x24
Fri Oct 22, 2021 08:10:03: Verify error at address 0x00400149, target byte: 0xDD, byte in file: 0x00
Fri Oct 22, 2021 08:10:03: Warning: Too many verify errors, only the first 200 are displayed
Fri Oct 22, 2021 08:10:05: Fatal error: There were warnings during download of FLASH loader, see Log Window Session aborted!
Fri Oct 22, 2021 08:10:05: Failed to load flash loader: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashSM470R1B1M.out
Fri Oct 22, 2021 08:10:05: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\TexasInstruments\FlashSM470R1B1M.mac
Fri Oct 22, 2021 08:10:05: IAR Embedded Workbench 8.32.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\bin\armproc.dll)
And the customer has tested, it is not related to the JTAG rate and the problem remained at 100KHz. Also tried JTAG reset, but failed either.
Could you please help to check this?
Thanks!
Cherry Zhou
