My customer has a question regarding power supply to the AM243x when only using the main domain and not the MCU domain.
Do they have to supply power to the following pins?
If there are any other pins they don't need to supply power to, please let me know.
Also, the AM243x datasheet (Section 7.4 Recommended Operating Conditions) gives nominal, min, and max values for voltage. Are there any specifications similarly for current ratings?
Mari Tsunoda
Hi Mari,
In AM243x - the MCU domain is also the wakeup domain and the power to these pins need to be provided even if the MCU domain is not used.
For current ratings - the customer can use the power estimation tool at https://www.ti.com/lit/zip/sprm779 and the related App note at https://www.ti.com/lit/pdf/spracw6 to estimate the power for their application.
Thank you.
Anita
Hi Anita,
Thank you for your quick response! I've relayed this information to my customer so I'll mark this thread as resolved.
Thank you for your support!
Mari Tsunoda
