Part Number: AM2432
I can find an example of SBL for SD card boot in SDK, which uses FAT file system. So, we can just copy an image file into SD and can boot the system.
My question is whether or not we can boot the system from "OSPI Flash" in the same way with SD boot using the file system. If it is possible, I would like to know the relevant information or an idea about how to format the flash with FAT file system. Does TI flashing tool support this? I would appreciate it if you share how to put the image in the flash memory in this case, and the booting sequence.
Moonil
