Part Number: LP-MSPM0G3507
Other Parts Discussed in Thread: SYSCONFIG, MSPM0G3507
I'm starting a new project that uses different peripherals, including the ADC. I'm using the adc12_sequence_conversion example. I'm a bit confused about setting the timing of the sampling window and the conversion window using syscfg.
I've attached two images: Timing diagram block and syscfg of the adc12_sequence_conversion example.
1 - Regarding the sampling window: Where do I set the value of the sampling window using .syscfg?
2 - Regarding the conversion window: how do I determine this period? I know it is defined by RES and CLKFREQ (described in the diagram), but is there an equation or reference to estimate it? How are they related?
3 - What is the sampling window in the example?
Translated with DeepL.com (free version)
Thank you for the support.
