SYSCONFIG: F2838x: I2C Module: Default GPIO configuration wrongly set to Open Drain
Part Number: SYSCONFIG
I am using the sysconfig 1.20 to setup an i2c module of a F2838x device. C2000Ware 5.2
I realized that setting the pins as STD works, instead of letting the default Open Drain which pulls the lines somehow low.
From the TRM:
I saw the post asking for allowing that option: It might be a mistake as Open Drain should not be allowed on this module.
