Part Number: AM2634-Q1
Other Parts Discussed in Thread: TMDSCNCD263
Hi expert,
Customer reports they experienced warm reset issue after they issued software warm reset SOC_generateSwWarmReset(); System did not come back and WARMRSTn pin will keep low. This WARMRSTn already has 10Kohm pull up resistor. So customer is wondering what will cause AM263x keep WARMRSTn low while no other drive it low?
Customer also want to check SAFETY_ERRORn pin behavior when ESM is not enabled.
on TMDSCNCD263 control board, SAFETY_ERRORn pin doesn't have pull up resistor.
However, the datasheet describes SAFETY_ERRORn is OD pin and default pull down.
without external pull up resistor, this pin should not become high.
But customer observed this pin become high/low toggled during issue happen. Can you please check why this pin become high with pull up resistor and ESM is disabled?
